Question about Cameras
Hello, My digital camera is Pentax Optio E30. After taking photos I tried to download them to my netbook using the SD card slot. I inserted the memory card into the slot but no files appeared but when I put the memory card back to the digital camera, the photos appeared. What should I do?
  • 747 Answers
Pretty cool that the newer computers are coming with an SD card slot. However the computer looks at this as an external hard drive and I don't think the pictures are just going to automatically pop up on the screen. You will need to go find the "drive" click on the folder and open, once you have the pictures open you can select all copy and then create a folder on your computer hard drive and paste the pictures in that. Once the pictures have transferred do a safe eject of the SD "drive" and remove the SD card. Don't forget to do a format to the card once back into the camera.
Posted on Apr 05, 2011
Why can't I download pictures to computer?
You can do that by two methods.
1. Memory Media
The E40 accepts SD and SDHC memory cards and has approximately 10MB of internal storage.
Insert the memory into your laptop SD card slot.
You may not need a SD Card carrier as the SD type for both Camera and laptop is same.
2. Connectivity
There is a USB/AV connector on the side of the camera as well as a dock connector on the bottom of the camera.
26041754-feum23phdkkiz3bf0e0pm1n0-4-0.png Pentax Optio E40 Review DigitalCameraReview
Jan 06, 2016 | Pentax Optio E40 Digital Camera
How to unlock card in pentax optio Says Card
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Aug 22, 2010 | Pentax Optio W10 Digital Camera
My Pentax Optio S5z does not store images to SD
Copy your photos to the SD card in the camera. http://www.pentaximaging.com/files/manual/OptioS5z_web.pdf p. 136
Transfer all photos to your computer from your SD card, and then put the card back into your camera. Try looking through your manual to see if there are any other settings that are required in order to save photos to the memory card.
Feb 22, 2010 | Pentax Optio S5z Digital Camera
My camera stopped uploading photos
If the camera still works OK otherwise -- you caN BYPASS THE PROBLEM with coimputer recognition simply by removing the SD card, and reading it directly. Most notebooks have a slot for plugging in an SD card. Otherwise -- there are some very cheap SD card readers (<$5.00) -- insert your card, plug into USB Port, then (on Windows) select "Open Windows Explorer" select and copy your digital images to your PC.
Feb 26, 2009 | Pentax Optio 60 Digital Camera
SD memory prohibits functioning of Pentax E30
I know that usually, you should format the card for the camera that your going to use. Try formating it in the camera and see if that works. Let me know if I can do anything else for you,
Rob
Feb 22, 2009 | Pentax Optio E30 Digital Camera
SD CARD LOCKED
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
Kind regards
Andrea
Dec 16, 2007 | Pentax Optio W10 Digital Camera
Card NO formatted
If u get a lock(A small switch on the left side of the card) on ur card try changing its position.Move it to other side.
Oct 25, 2007 | Pentax Optio E30 Digital Camera
Software Installation
Pentax camera creates an own folder at each inserted SD card. So, try to find your image and video files in the folder named 100PENTX. For example, my camera saves the shot images into folder: SD card:\DCIM\100PENTX.
Sep 08, 2005 | Pentax Optio SV Digital Camera
Cameras Logo
53 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
