Question about Dryers
My dryer turns on heats up but wont tumble. Happened all of a sudden.
  • Dryers Master
  • 3,361 Answers
Replace the broken drive belt.
Posted on Apr 05, 2011
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
Jan 25, 2016 | Dryers
Maytag neptune dryer heats but wont tumble
When you spin it by hand, is there resistance? Can you hear the motor turning? In fact, when you switch it on and it starts to heat, can you hear the motor turning, or is it silent?
Sounds like the belt is broken, in which case there will be little resistance.
If there is resistance, it may be the motor or circuitry controlling the motor.
Aug 24, 2015 | Maytag Dryers
How do i figure out the problem with my dryer
I assume it still turns on and tumbles. I also trust that you have tried running it on different settings and it produces heat in none of them, correct? If it's an older, mechanical type, you might start by taking it apart to look for broken connections. If it's a newer, computerized one, you'll probably want to contact the supplier or manufacturer and see if it's still covered under your warranty or at least get them to point you in the direction of where to find the problem. If you need more help, please provide full details about the issues you're having, the make and model (including model number) of your dryer, how old it is, if the problem happened suddenly or gradually, etc. Good luck.
Nov 02, 2014 | Speed Queen Dryers
Where is the belt located?? This maytag legacy elec dryer is 4 yrs old. over the last few mths it has made louder sqeaky noises but now all of a sudden it stopped tumbling!! It still heats up like it's...
it is inside the dryer, you will need to disassemble the dryer here is a website that may help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
diagram of belt routing:
http://www.applianceaid.com/images/belt-config.JPG
Good Luck Tim
Feb 09, 2011 | Maytag MDE308DAYW Electric Dryer
Hi. DLEX8377WM - no heat...dryer tumbles and there are no errors, but no heat. Happened a few months ago, but started working again.
sounds like the heating element is out, you can disconnect the vent hose turn on dryer and see if heat comes out.
Aug 03, 2010 | LG Dryers
Dryer heats but wont tumble/electric
Broken belt due to bad rollers or idler or simply rotten belt. GUIDE
Jun 30, 2009 | Kenmore 63942 Dryer
Dryer heats but won't tumble
Assuming, the timer is ok and that you can hear the the dryer motor running, it sounds like a broken belt. These kind of failures generally occur suddenly - one day it works, the next day it doesn't.
May 03, 2009 | Dryers
TUMBLE DRYER WONT WORK
It will most probably be the door switch which is either sticking, give the door casing latch a gentle knock with the back of a screw driver, or is just broken. Try and get to the two wires at the switch and shorting them out i.e. linking out the switch. Make sure the dryer is UNPLUGGED when you do this.
Nov 28, 2008 | Dryers
Dryers Logo
Top Dryers Experts
