We just purchased a home with a beckett heater. we cant stop it from heating the house, it is 80 degrees in here and the heater is off! its burning up oil like crazy but we are only in need of the hot water to be heated,,,help!
    Brigadier General:
  • 4,736 Answers
Terry, most units like yours had a Winter and Summer setting. It should be located on the furnace itself. In the Summer mode, only the water is heated for domestic use and the furnace side of the system is shut down.
Posted on Apr 05, 2011
I have 2 zone gas hot water heat. When I turn 1st floor zone down to 60 degrees and 2nd floor zone up to 80 degrees why do I get heat on 1st floor.
Gas Furnace
If you are looking for a high efficiency furnace with up to 96% efficiency then Amana AMH95 forced air gas furnace is a considerable furnace for you home heating requirements.
- See more at: http://www.cleanairheat.ca/amana-amh95-gas-furnace.php#sthash.FeFfEH9f.dpuf
Oct 28, 2013 | Heating & Cooling
What's your problem? I have a Airtron furnace/air cond unit and last night I smelled a odor that of something electrical burning. I also noticed that the heating unit stayed on and continued to blow...
I'm willing to bet a relay burned up. You likely have your tstat set to auto changeover, meaning it automatically goes from heat to cool to maintain desired set points??
Jun 21, 2017 | Heating & Cooling
We have a Beckett Pond Heater and when we placed it in the pond this year it went to the bottom and will not float. It seems to heat, but we are expecting thick ice. Any suggestions?
The purpose of the heater is maintain an open water space on the surface for gases to exchange into the water. Whatever was in place to keep this unit afloat must be replaced (ie Styrofoam). Or, if the the unit has an air chamber to keep it afloat perhaps the element burned through it and it's filling with water.....try to plug it with some epoxy glue.
Nov 15, 2010 | Beckett Corporation Beckett 7137010 Rock...
Goodman model gmt090-3b ignator is staying lit all the time cause them to burn out .have changed board same problem.
Hi cannot find the problem for this but go to www.goodmanmfg.com
you can e-mail and ask them from the web page hope this helps
it could be the presure switch playing up
Jan 23, 2010 | Goodman GMS90703BXA Heater
HI I have my hot tub at 104 but it will only heat up to about 80 degrees. what is my problem
If its set at 104, but only heats to around 80 degrees, then your heater is not working. Either the heating element is bad, or the pressure switch is not closing. The reason why the water heats up to 80 degrees, is from the friction caused by the mechanical shaft seal when the pump is running. Either way, you should really have it checked by a qualified spa technician. It is not something that the average spa owner can normally repair themselves. Sorry.
Sep 27, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Goodman heats but defrosts turns on before desired temp.
Yes. The defrost cycle of a heat pump is actually turning on your airconditioning to heat up the condenser to thaw it out. During this cycle your electric strip heaters "should" be adequate enough to compensate for the a/c being on. At about 30 - 34 degrees outdoor temp there is not enough heat in the air to to adequately heat your home with the heat pump only. Some technitions will use an outdoor thermostat to turn off the heat pump when it is under 34 degrees outside. If you are to cold when its under 34 degrees intall more electric strip heaters.. But if you do this your electric bill may go up significantly.
Welcome to the wonderful world of electric heat pumps (lol).
Good luck.
Mar 29, 2009 | Goodman GMS90703BXA Heater
Furnace wont start when thermostat sends signal
by restart button you mean reset i believe,its located on top of oil burner and says only push one time .if thats the button your pushing it is the reset button or retry for oil burner if you are pushing this there is a problem with burner
Jan 04, 2009 | Honeywell Electronic Programmable...
3 year old Beckett AFG with Clean-Cut system. New inline filter new strainer, new nozzle, flame looks correct in pattern always. Flame does not sputter prior to shut-off. I did notice that when it shut off...
Called Beckett at 1-800-OIL-BURN and explained the problem. They told me that the solenoid on the oil pump (Clean Cut) was the cause. I purchased a new pump for $50 at the local plumbing supply and installed it. Problem solved.
Nov 20, 2008 | Heating & Cooling
My appartment does not have cenral AC/heat, it has a GE cooling/heater unit in each room. You can set up low heat or high heat but it continues runing on until you manually stop it when is to hot. Is there...
the unit runs all the time because of the fan (ventilation motor)-but it is not working on cooling or heating all the time - The ventilation motor pushes the air from the room through the machine and when the termostat is reading that you set it up for cooler air or warm air it will turn on the air conditioning part or the heating part of the machine-it is very good system actually
Oct 04, 2008 | Heating & Cooling
Heating & Cooling Logo
80 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
