Question about Toro 52" 27hp Z Master Zero Turn Lawn Mower
Not getting fuel to carburator have fuel and good filter have a solinoid on carburator bowl that is very hot could this be the problem
  • 577 Answers
Yes it is called a rollover valve so if machine rolles over it shuts fuel off preventing fire, remove bowl and clean it out and spray p.b. blast on the solenoid needle and keep working it till it moves free with the electricity from the batt should cure problem
Posted on Apr 05, 2011
My mower starts and then shuts off after 5 to 10 min or so, I'm thinking its a fuel problem. I replaced the fuel pump, added a new fuel and air filter. Still having a problem. need help!
Check the function of the fuel shut off solinoid in the bottom of the float bowl, this can be done by removing the unit fronm the base of the carb ( there will be fuel spill from the bowl once the solinoid has been removed, now switch the ignition on, the centre pin should retract into its housing.
Jul 19, 2017 | Husqvarna Garden
Must pour fuel into intake to keep running
This one is very obvious. For some reason you are not getting fuel to the carburator. It could be a clogged fuel filter, trash in the carburator bowl and/or a seat needle valve stuck in the closed position. Could be a bad diaphram in the carb.
Mar 11, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
X300 lawn tractor will not start. cranks fine, fresh fuel with stabilizer, new fuel filter, checked lines and pump, and replaced plugs. still will not fire or run
Not uncommon for the fuel solinoid to stop working on fuel bowl. You can try a small amount of fuel down throat. If engine fires for a second then its a fuel problem. Solinoid or blocked jet
Jan 29, 2012 | Garden
Replaced fuel line and now petrol comes from fuel bowl is there a gasket between fuel bowl and body please?
No, Go online to www.cycleparts nation.com and proceed to look up the part for carburator assembly that you need and at that point order the part that you need for your carb. You need to look for a carburator bowl gasket for your particular motorcycle.
Good luck my friend,
kd4rua
Dec 29, 2011 | Motorcycles
I have a1977 motor home with a 460 ford engine it runs good for 4-5 miles then looses power i can stop then take off again runs good a little ways then does it again getting worse the farther you drive it....
The problem is deffenatly fuel related. Possably a weak fuel pump if you have replaced the filters meaning all filters even in the pump . But the when hot could also be what is called vapor lock in the fuel line so air is getting in the fuel line for what ever reason and when the vehicle gets to opperating tempature its building up pressure inside the fuel line stoping the fuel flow to the carburator . If this is it you can fix it buy adding a accressery filter before the steel line begins . Or it could be the power valve in the carburator or the inlet filter in the carb or the carburator just need to be rebuild if its a 2 berral its not a problem if its a 4 it may be more of a problem . See what you can do with it
Sep 18, 2011 | Ford E-350 Cars & Trucks
Runs rough at idle and wants to quit when you give it gas unless it is on full choke
This is usually an indication of fuel starvation. The jets in the carburator are probably clogged or (if you have a fuel filter) the fuel filter is clogged. In a well ventilated area and away from any sparks or flames, remove the carburator drain plug (usually at the bottom on the side of the bowl or on the bottom of the bowl). (Turn off the fuel flow to at the tank first). Try to catch the fuel as it exits in a small container. After you've drained the fuel from the carburator, examine the fuel and look for small particles. If they are present, you need to clean the jets which requires disassembly of the carburator. You'll need a manual and a rebuild kit for your particular bike to go beyond this step. However, if you're lucky, you can try turning on the fuel and flushing the carburator(s) out. If fuel only trickles out, then you've got a clogged fuel system. Could be the float valve or filter in this case. If fuel runs strongly, then if you still may have to clean the jets. Turn the fuel off, replace the plug(s), turn the fuel back on and give a few seconds for the bowls to refill and trying running the bike again. If it is fixed, then no further action is required except to keep your fuel cleaner! If not, you'll still have to clean the jets.
Apr 10, 2011 | Honda VT 1100 C Shadow Motorcycles
Fuel pump is pumping fuel to carb, but no fuel going into carburator. can dump gas directly into carb and car will fire up. is there some kind of pump not functioning inside carburator
there is a float valve. There may also be a filter on the inlet. First check for filter, then remove top from float bowl to see why fuel isn't flowing in. You may want to get a rebuild kit. they aren't expensive and they usually come with instructions.
Oct 12, 2010 | 1985 Honda Accord
4390 15kw, it will start but only run for 15-20sec. Cleaned and replaced air filter, good oil qty. It's a negative 10F, I have cleaned around the pressure regulators. Again, it starts just fine, does not...
remove the carburator sediment bowl just on the underside of the carburator and see how much sediment is in the bowl,if theres a lot you may need to flush out the carburatror to rid it of these contaminents,also pull out the choke part way when it wants to die,if this keeps it running,this also is an indication of a dirty carburator restricting fuel flow through carburator to the engine intake,sometimes if you can keep it running,spray some carburator cleaner into the throat opening of the carburator and see if this helps
Jan 02, 2010 | Electrical Supplies
Broken fuel line, can't figure out where to attach fuel line coming out of the fuel filter
Typically it goes tank outlet to fuel filter to carb. Which end is confusing you? If its a 2cyl engine, with 2 carbs, then it may go to a split to feed gas to both carbs, but that's not likely on a 110cc.
Oct 17, 2009 | 2006 kawasaki KLX 110
Riding lawnmower wont run long
Check for dirt in gas tank some times stuff will fall in when filling and block the hole in bottom of gas tank and wont let gas flow clean everything out and see if it works. Also check that all kill switches are tight and not moving.
Oct 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Toro 52" 27hp Z Master Zero Turn Lawn Mower Logo
242 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
