Question about Maytag Dryers
What does error code f 02 mean? - Maytag Dryers
  • Kelly
    Kelly Apr 05, 2011
    Is the F 02 code on a MAYTAG dryer? Can you please provide us with a model number so that we can use your model number to properly respond with a professional answer and possible solution to your prioblem?
    Thanks,
    Kelly
  • matthew356 Apr 05, 2011
    Maytag Dryer Model mgde300vf0
  • Maytag Master
  • 3,740 Answers
Noted this is a Red Maytag Gas Commercial Dryer.
Using this parts link:
http://www.kitchenaid.ca/assets/pdfs/literature/Repair%20Part%20List%20-%20W10222090.pdf
And this Owners manual Link:
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10057350A.pdf
I do not have the service manual for this dryer and I have yet to locate it via any source. The dryer appears to be made by KitchenAid. Even checking the KitchenAid service manuals has yet to be successful.
Inside the dryer there is a tech data sheet enevelope that will either be on the left side / inside the top console or taped to the left side of the dryer cabinet on the inside left as your facing the dryer. The F02 code should be listed on one of the 4 data sheets in that Technial Data Sheets packet. The sheet your looking for will have this number printed on it:
W10057359 Tech Sheet
I wish I could be more helpful but this one has me baffled as to why I can not locate a service manual.
Now.. having said that... are there any symptoms that you noticed before the dryer displayed the F 02 code. Like clothers were taking longer than usual to dry? Odd burner operation?
Anything out of the ordinary?
Kelly
Posted on Apr 05, 2011
I'm looking for an error code meaning that appear on my krups coffee machine the error code is "code error 02"
You will probably get some proper help if you identify the exact model. I don't expect "error 2" to mean exactly the same on every model Krups have ever made, narrow it down a bit for us please.
Mar 22, 2017 | Krups Coffee Makers & Espresso Machines
What does a error code 02
02 SENSOR MALFUCTION
Oct 09, 2014 | Cars & Trucks
Error code 02 ewd6505gso
Sandra Lawson,
Getting an Error Code 2 on your dishwasher, means there is something going on with the turbidity sensor. This is the sensor that determines how dirty the water is which in essence determines how long the cycle will run.
What you can try to do is to reset the appliance for 30 minutes. You will do this by cutting the power at the circuit breaker and leaving it off for no less than 30 minutes. Try running the cycle again and if you are still receiving the Error Code 2, I would recommend contacting the manufacturer for further assistance.
-Best Regards-
Jan 06, 2014 | Electrolux 24 in. EDW5500DSS Stainless...
Samsung scx 5635 has error code 02-000 is this a fuser problem and how do you reset.
I have a samsung scx-5635 Fn and im getting an error message of 02-0000. what does this code mean?
Sep 12, 2011 | Samsung Office Equipment & Supplies
Error code f5-02
Hi1
The f5-02 error code means that the exposure lamp is deffective.
Regards,
Bogdan
Sep 12, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sony UVW-1800 error message: 02-274 -- What does this mean?
I found a site where the error code are.
http://z.baidu.com/question/97641503.html
02-274 Failed to detect the T reel FG during threadingI hope this helps
Sep 26, 2009 | Fuji M321SP Betacam Tape
I receive an f 02 error on delicate cycel and it won't finish the load
Hi!
Error F 02 means the drain time is taking longer period then normal. If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed. To resolve the issue you are facing with you need to follow these steps---
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the ‘sud’ error will be displayed, then 4 minutes later the F/02 error code will be displayed.
To clear this error code—
Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
If still the error code exists then you need to replace the pump.
Thanks for using FixYa and revert for further assistance.
Thanks
Rylee
Jul 19, 2009 | Whirlpool Duet 4.0 Cu. Ft. 14-Cycle Ultra...
Washer stops mid cycle and displays F 02 error code.
it means that your pump is clogged you need to take that bottom panel off the washer and twist the white cap slowly so it can drain put plenty of towels down once it is done draining pull the cap and clean the trap behind it
Dec 25, 2008 | Kenmore Elite 45986 Front Load Washer
Avh-p5900dvd... I keep getting error -02-9e and it wont play cd,s or dvd,s can you help.
Owner's manual doesn't really say what the -02-9e error code means other than a disc error. They do recommend resetting the unit as a possible solution:
  1. Turn the ignition off.
  2. Remove the faceplate.
  3. On the right side of the front of the head unit (with the faceplate removed), press the reset button with a ball point pen.
You may have to call Pioneer directly to find out what the -02-9e code means specifically. 1-800-421-1404
Apr 03, 2008 | Car Audio & Video
Dryers Logo
120 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
