Question about Zebra DS3508 Barcode Scanner - P/N DS3508-DP20005R Barcode Scanner
I have just received ds3508 scanners, when I connect them to a Wyse terminal they do not work. No lights no beeps, nothing. When I disconnect the scanner it beeps, I can scan barcodes just fine. I hook it back up to the terminal and I get the same problem.
SOURCE: the scanners won't scan information after being programmed
I would scan default barcode again. If you are using PS2 connectors. Scan barcode for PS2 keyboard. And USB for USB connectors. Most likely it is not seeing the device. Or treating as a keyboard as it should.
Posted on Jul 06, 2007
Corster
  • 79 Answers
SOURCE: problem with scanner
Yeah, from the manual, scan the following settings:
Scan Suffix
7
0
0
9
Scan Options
<DATA> <SUFFIX>
Enter
It's best to copy the necessary barcodes from the manual at 200% zoom, into a Word document and print it out.
Posted on Jan 03, 2008
SOURCE: Barcodes print too long
This is defendant on the program you use to print labels with. The printer responds to either a print job sent to the driver (like a standard windows printer). Or you can send an EPL program to the printer in order to use internal barcode generating features of the printer. The dimensions of the barcode are controlled via the EPL script. See the EPL programming guide avaialble on Zebra's website for more info.
Posted on Jul 28, 2008
thesuperdude
  • 97 Answers
SOURCE: Types of Barcode that can be scanned using Symbol MC9090
It can read all standard symbologies apart from PDF symbologies unless it is equipped with an imager scan engine.
Posted on Mar 26, 2009
thesuperdude
  • 97 Answers
SOURCE: scanner beeps but doesn't enter data into system
Have you scanned the configuration barcodes on the manual? For example if you are using keyboard wedge cable, you will need to scan the keyboard wedge barcode from the manual. Page 20.
http://www.handheld.com/download.aspx?download=/data/ffdefe60-2c7a-423f-a204-ee2450b7c4d9.pdf&filename=IT3800PDF+Linear+Imager+PDF
Posted on Apr 02, 2009
WYSE 50 beeps at turn on, but no data on screen. Seem to recall that you could hold down some keys when powering on, but do not recall which ones.
On powerup, you can get to options screens by pressing one of the F-keys. It varies between computers, but it's usually either F2, F8, or F12. If in doubt, try all of them until you get a menu screen, then go from there. The beep at turn-on is an indicator that something isn't hooked up right, usually, so recheck all your connections, then take it from there. If you still have your manual, it will tell you the powerup options, and how to access them. Good luck!.
Mar 26, 2010 | WYSE 50 Terminal
Connection reset by peer
is this a citrix environment? have you just applied a rollup pack to your terminals?
You need to speak to Wyse!
Apr 27, 2009 | WYSE S10 (90210501) Network Terminal
Wyse S10 RPD to Server 2008
you have to buy 1 terminal license for you S10 also.
Apr 23, 2009 | WYSE S10 (90210501) Network Terminal
Does other terminal emulation VT220/VT100 work on WYSE?
vt220 on wyse
Sort of but f3 and f4 wont work and f1 would be ctrl + o
Dec 11, 2008 | WYSE WT3235LE (902032-68) Network Terminal
Wyse S10 and Windows 2008 Terminal Services
The Wyse S10s require a firmware update to connect to Windows Server 2008. This is due to lack of support for RDP 6.1.
The update I've found to work best is 6.4.0.18.
The only way to get this update is to contact Wyse. However, I have deployed it on numerous clients (our entire base is S10s) and had great success.
Nov 12, 2008 | WYSE S10 (90210501) Network Terminal
I have Wyse V50L termimals that cannot connect to Terminal Server 2008. Connections from XP Remote Desktop Client work fine. The server is configured to not use Network Level Authentication. The...
Have you tried the latest V50L firmware version? There was a major revision lately?
http://www.wyse.com/serviceandsupport/support/downloads.asp
Oct 25, 2008 | WYSE Computers & Internet
Wyse 3150 terminal - yellow light
Does it boot into BIOS if you hold down Delete while powering up the terminal?
Sep 03, 2008 | WYSE Winterm 3150SE Network Terminal
Zebra DS3508 Barcode Scanner - P/N DS3508-DP20005R Barcode Scanner Logo
82 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Lawrence Oravetz
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
