Matsushita ac compressor with serial no. k34b cdo52540
I need the cooling capacity of a matsushita cnr05-980270 compressor. can anyone please assist?
I would need more information to properly answer your question.
What are you removing this compressor from?
The cooling capacity can vary greatly depending on the Evaporator size, the Condenser size and the fan speed that is moving the air. Also there are some other figures needed.
But if you could give me the application that you are using the compressor in I might be able to better answer your question!
Oct 11, 2013 | Matsushita DD73C14GAU6 1/4 HP R134...
I need the capacitor size for a Matsushita compressor model #2P19C3R126A Thanks
It just so happens that I am about to replace the compressor,on a marine A/C unit that uses the Matsushita 2p19c3r126a compressor. I believe it uses a 30 mfd capacitor.
Jun 10, 2011 | Heating & Cooling
Where can I get a manual for a panasonic microwave convection oven serial number 863170033 model number NN-2909 manufactured in June 1993.
Partstore.com has the owner's manual for sale: http://www.partstore.com/Model/Matsushita/Panasonic/NN2909.aspx ; scroll through the parts list in the All Parts section or limit your search to the Microwave documents in the box on the left. http://www.partstore.com/Part/Matsushita/Panasonic/NN2909/Matsushita/Panasonic/OMNN2909/New.aspx is the direct link.
Unfortunately, I do not see the NN-2909 listed at any other site.
I hope this helps.
May 28, 2011 | Smeg FMC24 850 Watts Convection /...
I'd lke know, the HP of this compressor MATSUSHITA DB91C14RAW5 thanx
According to the information you have given it is a one quarter horsepower compressor
designed for R134 refrigerant. It runs on 115 volts.
Apr 03, 2011 | Matsushita DD73C14GAU6 1/4 HP R134...
I don't know my matsushita radio code; serial;96D313901 Ref.No.CQ-jh2610A Model; 39100-S30- A100
If this is the Matsushita fitted into a Honda, then try here
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} HONDA codes may be available here
https://radio-navicode.honda.com
You will require the car VIN number and Radio serial Number
If they cannot provide your code then you will have to try your HONDA Main Dealer .....or a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM)
May 18, 2010 | Car Audio & Video
Hi i am a refrigeration mechanic and i need a compressor for a chest freezer, here are all the reference numbers on the compressor, can you tell me the specs so i can get a match. SMH 2598133 Model no:...
i think any 1/3 hp 134a compressor will work you just have to make sure the fitting are in the right place,i got mine on ebay for $50 or you can check sears.com(parts) or repair clinic .com,let me know how you do-mike
Oct 28, 2008 | Refrigerators
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
