Question about Maytag Neptune MDG9700A Gas Dryer
Mdg9700 need to remove front cover, which does NOT match normal maytag type bottom held by clips not screws, first look is that control panel needs to remove first but if so these are concealed.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Here is a video showing how
http://www.youtube.com/watch?v=APlWrIcP94g
Posted on Jul 05, 2014
    President:
  • 1,554 Answers
The top panel and the control panel need to be removed first before the front panel can be removed. Once the top panel is off, the screws attaching the control panel to the dryer cabinet are exposed. The screws securing the front panel to the dryer cabinet are exposed once the control panel is removed.
Disconnect power and remove the two screws attaching the top panel to the rear of the dryer.
Slide the top panel towards the rear to clear the screw head from the flange at the bottom side of the top panel then lift it from the unit.
Remove the screws securing the Heater PCB Assembly at the left side of the dryer cabinet then flip the assembly over and disconnect the black and the white connectors from the board.
Remove the four screws attaching the control panel to the dryer cabinet then rotate it down and remmdg9700 need to remove front - jahn27_269.jpge dryer.
Remove the two screws in the door area and the four screws from the top of tmdg9700 need to remove front - jahn27_270.jpg and attaching it to the dryer cabinet.
jahn27_270.jpgmdg9700 need to remove front - jahn27_271.jpgll the front panel forward then disconnect the interior light harness.
jahn27_27mdg9700 need to remove front - jahn27_272.jpgh_mi
Lift the front panel off the tabs across the bottom and remove it from the dryer.
Reassemble the dryer in reverse order of the disassembly steps.
Posted on Apr 06, 2011
I need to replace door seal on this machine but i dont know how to remove the front of the machine i have the top cover off
If it is Whirlpool / Maytag try parts diagrams at
www.whirlpoolparts.ca
Normal procedure to open front door panel on a front load.
1. Remove top cover.
2. Remove Control panel.
3. Remove bottom kick plate cover
4. You will see the door panel screws. Two on top corners and two on bottom corner.
5. Keep in mind, you have to remove the door lock (latch) from door panel before removing door panel.
Apr 25, 2015 | Washing Machines
Tip
Maytag Square-Front (1998) and Sloped-Front (1999) Dryers Front Panel and Top...
Most of the internal components of Maytag Square-Front (1998) and Sloped-Front (1999) Dryers can be accessed with the removal of the front panel and lifting of the top cover. The top cover can only be lifted after the front panel is removed. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
The first step is the removal of the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip. Open the door then lift the front of the top cover and tilt it toward the rear of the dryer.
The internal components of the dryer can now be accessed. Reinstall the top cover and the front panel in reverse of the removal steps.
This procedure is also applicable to Maytag Neptune Front-Load Washers. The only difference is the dispenser bezel removal.
on Apr 28, 2010 | Maytag Neptune MDE4000 Electric Dryer
Tip
Maytag Neptune Front-Load Washers Front Panel and Top Cover Removal
Most of the internal components of Maytag Neptune Front-Load Washers can be accessed with the removal of the front panel and lifting of the top cover. The top cover can only be lifted after the front panel is removed. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
The first step is the removal of the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the machine.
Remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Open the door then lift the front of the top cover and tilt it toward the rear of the machine.
The internal components of the machine can now be accessed. Reinstall the top cover and the front panel in reverse of the removal steps.
This procedure is also applicable to Maytag Square-Front (1998) and Sloped-Front (1999) Dryers (Maytag Neptune Dryers). The only difference is the dispenser bezel removal.
on Apr 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Dryer front panel
I just had to do this on my dryer. So without knowing your dryer type, I did the following:
1) pop the top which is held down by two fasteners in the front. I used some plastic pry bars used to remove door panels in cars. Basically you just jam something in the front on both sides under the top lid and force it up.
2) Then with tilt the top back and there is a screw on each side from the inside that holds on the front cover.
3) Once these two screws are removed you lift up on the front cover as the other point of attachment is two clips on the bottom that the front cover then lifts out of.
Apr 05, 2014 | Whirlpool Dryers
How do I get the top off
The front panel needs to be removed first before the top panel can be lifted. This is due to the top panel hold down brackets hidden behind the front panel posts. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. Reinstall the top cover and the front panel by following the removal steps in reverse order. Click on the link below for more detailed disassembly procedure.
Removing the Front and Top Panels of Maytag Sloped-Front Dryers
Mar 03, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I can't get the top off my Maytag performa MD2300 dryer. I used the putty knife idea but the clip won't budge. I'm pushing straight in from the front, cheating a little up, then down. It's like hitting a...
The top cover is held by two hold down brackets hidden behind the front panel posts. Lifting of the top cover requires the removal of the front panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening and securing the front panel to the front shroud assembly.
The front panel is held to the cabinet by clips on each side secured to the cabinet front flange. Small slots in each side of the front panel engage the clips and hold the front panel in place. Grasp the sides of the front panel near the top cover then pull the front panel away from the cabinet.
Tilt the top of the front panel away from the cabinet and lift it up to release it from the two clips retaining its bottom to the base of the dryer, and then move the panel away.
Locate and remove the 5/16" hex-head screw attaching each hold down bracket to the cabinet. Swing each bracket to the outside then unhook it from the slot in the lip of the top cover. Lift the front of the top cover and flip it to the rear of the dryer.
Reassemble the front panel and the top cover by reversing the given disassembly steps.
Mar 25, 2010 | Dryers
Maytag mce8000 ayw. Want to remove plastic cover
The font panel must be removed. This may be done by removing the control console (open upper cabinet doors to find screws behind the console). After you remove the control console, the screws along the top of the lower front panel are easily accessible. Disconnect the two interlock switches, remove the grounding clip attached to the bulkhead & lift the panel off the two lower clips. Inside the panel is the housing that leads to the exhaust blower. Just clean out the mess & reverse the process to replace the parts.
Feb 14, 2010 | Maytag Dryers
Removal internal front door panel
where the window controls are is where the screws are that hold the door pull,run fingers along under the bottom of door and look for any screws in the panel in this area,remove the window winder control panel by lifting it out,the door panel comes off by pulling it as its held on with plastic push on clips
Dec 31, 2008 | 2001 Jaguar S-Type
Gas Dryer LDG7304AAE making horribly loud noise while drying
Solution for the Maytag model is most likely to replace the blower wheel. Remove the two screws on the front panel (just a couple inches off the floor) and swing the front panel up to allow you to unhook the top side of the panel from the clips at the very top of the front panel. You do not have to remove the wires, just set the front panel to the side. Blower wheel is at the lower left. The old wheel most likely no longer has a D shaped hole to match the motor shaft, and spins freely. Remove cover. Replace the wheel part number Y303836 for a LDG7304AAE which is held on the shaft with a spring type clamp. Reassemble. Not really very hard to do. On a difficulty scale or 1 - 10, I'd rate it a 3.
Dec 06, 2008 | Dryers
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
Maytag Neptune MDG9700A Gas Dryer Logo
782 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
