Question about Cameras
I have conon 60D it is brand new that i have often used but pop up flash does not work after using external flash also I do not have flash indicator light on. inside light meter in the build in flash setting it shows the external flash is attached while there is no external flash light attached ...but all other functions of the camera is perfect and working great ..only the build in flash doesnot pop up in auto as well as manual settings...so plz help me best regard shreejen
  • shreejen Apr 12, 2011
    thanks....Tri3mast ....your soulution tips really works...as following your tips i take a small pin and clear the hot soe area of the camera ..and in some seconds the flash pops up...now my problem is solved ..thanks once again.
  • 747 Answers
The problem is under the hotshoe plate. There are extremely small hols where the sensor for the internal flash are positioned. These sensors tell the camera when an external flash or some other accessory is mounted on the camera and not to open the internal flash. What happens is because the alignment of these hols is so precise and critical any amount of movement or minute partial of dirt can upset or stick these sensors.
What has happened is that when you removed your external flash the sensors did not reset because of dirt or misalignment so show the setting as if the external flash is still mounted and that's why the internal flash won't pop up.
How to fix it, well for a repair person it may be a simple fix by slightly loosening the hotshoe and cleaning the dirt from under it and realignment. It'll work again until it gets dirt in there again or misaligned. This is one area that Canon shouldn't have been so precise.
I'm not suggesting you do this but when I had the same thing happen to one of my field cameras I took a hard plastic coffee cup and lightly started tapping on the edges of the hot shoe. After a few light taps around the shoe I the internal flash popped up. Once I finished my shoot I sent the camera to Canon to have the problem repaired properly. Repair and shipping to a Canon facility cost me $65.00 Canadian.
Posted on Apr 05, 2011
60d flash not working
Canon 60D Pop-up flash not working,
Ck to see if the Flash tube in the pop-up flash is Burnt or cracked, I can fix ether One for Ya!
Jul 12, 2017 | Cameras
Canon 60d built in flash will not pop up.
The external flash mount (hot shoe) has a small sliver of metal which when the external flash gun is slid on pushes it down to tell the body to not use the pop-up flash and some times the sliver doesn't return fully up to contact the underside of the hotshoe
Mar 14, 2017 | Canon EOS 60D Digital Camera
Canon 60d internal flash not popping up
Check the metal tabs inside the notable rails as they need to touch the upper part of the rails to allow built in flash to work
Use a micro screwdriver to push the tabs up to the rail
GENTLY as that was what was wrong with my canon digital body
Jun 21, 2015 | Canon EOS 60D Digital Camera with 18135mm...
  • is your settings set to manual ? if you are set to manual mode and the flash does not pop out try pressing the flash button located near the EOS 60d label
  • if the flash won't pop out after pressing the button try to follow the steps on this you tube link
How to fix the This menu cannot be displayed External flash is attached...
Aug 17, 2014 | Canon EOS 60D Digital Camera
Pop up flash does not work
Did you try to reset camera,or remove battery
Aug 06, 2014 | Canon EOS 60D Digital Camera
Use of Canon 60D's wireless function to control power on Canon 430EXII, being operated manually.
Your flash will fire optically. This is wireless but not radio.On the flashgun window move through the options until you see all of these in the window :- Flashing M, MZoom (24mm)
(the power output eg) 1/4
Flashgun icon CH1 Slave (blank)
The front panel should show a flashing red light. This means it is ready to receive the light signal from your onboard flash. From the camera menu select the in built flash control.
Set it to - Built-in flash - CustWireless
Flash mode - Manual flash
Wireless func - (single flashgun icon)
Channel- 1 ch
firing group - (flashgun icon)All
(flashgun icon) flashoutput - 1/64
selecting 1/64 should be sufficient to trigger the flash gun but not light the scene.
Manually pop up the onboard flash
In the view finder you'll see a number of green bars when half pressing the shutter and wait for them to go down to one which mean the camera and flashgun are communicating, fully press to take the shot and the flash (off camera) should fire.
Jun 26, 2017 | Canon EOS 60D Digital Camera
I was shooting tonight with the external flash on a bracket and the batteries died and when I tried to open the pop up it would not open , it says in the flash setting that the external flash is still...
Thats a big down fall with these cameras batteries that don't last. The LCD screens take alot of juice to run. One thing you can do is use rechargeable batteries. It will save you money. Good luck.
Jun 23, 2011 | Canon EOS 60D Digital Camera with 18135mm...
I bought my new canon eos 60D..i put on external flsah to use..then after i take off the external flash, my camera's built in flash cannot pop up to take flash even i had press the flash button. How?
Hi, What external flash did you use on your Canon 60D? The internal flash will not automatically pop up if in the "Creative Zone" it will pop up with the button in the creative zones (M, AV, TV and P) it will not pop up with the button if you are in the the full auto mode (that's the little green box mode) but, should pop up automatically if required. The flash should pop up automatically in the basic zone for Portrait, close up and night photography, the button won't activate (pop up) the flash. Also the internal flash will not pop up if there is an accessory in the hot shoe. Again what external flash was it you used and did it flash?
Jan 27, 2011 | Canon EOS 60D Digital Camera
After I have detached my external flash (Nissin Digital Speedlite Di622), my Canon EOS 60D does not recognize the fact that the external flash is already detached. Thus, this does not allow the built-in...
After I have detached my external flash (Nissin Digital Speedlite Di622), my Canon EOS 60D does not recognize the fact that the external flash is already detached. Thus, this does not allow the built-in flash to pop out when needed.
I have tried turning the power off and on again. The problem persists.
Dec 19, 2010 | Canon EOS 60D Digital Camera
My Canon 60D's internal flash will not pop up after removing my speedlite 430EX II. Carl
I encountered this same issue on new 60D. There is a micro switch under a guide blade in the shoe on the right side. Mine was not stuck down but bent just enough downward that the switch was being actuated. I used a pointed pocket knife blade to pry up on the guide blade making it arch slightly upward and everything is fine now. Now i wonder is this going to be a problem every time i mount and unmount my external flash. Time will tell.
Dec 17, 2010 | Canon EOS 60D Digital Camera
Cameras Logo
198 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
