Question about Samsung SyncMaster 940N Flat panel Monitor
My Samsung Syncmaster 931c is about 3 years old. Screen goes black PC is on but not in use. it is not in standby mode as blue light not on. The only way I can reactivate it is to unplug, fiddle with fuse, and then re plug in. Replacement power cable makes no difference. No problem (as yet) when PC being used.
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Posted on Apr 05, 2011
My Samsung 2493HM Monitor wont turn on, the blue light just blinks, then after some undetermined amount of time the light goes solid and all is well. It took over an hour today to start working. This just...
sales660, Monitor should not be doing that!!! Use Samsung warranty if available. Complain about "premature failure". Examine black screen for very faint displayed image with aid of bright flashlight(test all owners of CCFL back-lit lcd displays should know) to determine full or partial SMPS shutdown mode. Read more in my fixya profile for more that you can do. It could be bad capacitors or a thermally intermittant solder connection that you or qualified electronics tech will need to fix if warranty not option. After reading and surfing net you will understand your CCFL back-lit lcd display and how it works. Your monitor no different than ANY other brand of CCFL back-lit lcd monitor in it's basic design and operation!!! 12fixlouie
Mar 07, 2010 | Samsung SyncMaster 203B LCD Monitor
My screen began to take longer and longer to come on in the morning, up to 5 minutes. Then throught the day if my computer went on standby power, it would take 2-3 minutes to come back up..(and both ways...
kvons, Your monitor's behavior common to all brands not just Samsung. May need servicing by electronic technician. Read my and other tech's FIXYA profiles about solutions to BLACK screen problems and the two most common failure modes. 12fixlouie
Feb 04, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
I have a Samsung SyncMaster 931c monitor (2.5 yrs old). Sporadically during the last month, I'd lose the screen image and get vertical stripes on the display. I'd turn the monitor power button off and on...
jcacolice, Most likely your 931c will need work done on it. When strange things start to occur with any LCD CCFL backlit display I would suspect the "switch-mode-power-supply" first thing!!! If unit is out of warranty you or someone will need to inspect and troubleshoot it. A good place to start will be to see some DIY videos on YOUTUBE. Try search of "lcd monitor disassembly" and "lcd monitor repair" and learn all you can about the TOP CAUSES of monitor failure. Then visit (FYI) www.ccl-la.com/badcaps.htm and www.badcaps.net for more info. Explore ALL your options before you do anything. Then get back to us here at fixya if you still need some asssistance. Read some of my other responses in my fixya profile and other those of other tech's on fixya.
Hope to see you back on fixya with a plan of action!! 12fixlouie
Dec 23, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Monitor turns off after about 3-5 seconds
I would say your monitor is bad if you have tried it on 2 different monitors and it does the same on both. Check your warranty expiration date, some monitors have 2 or 3 years warranty. If it's still under warranty, you may be able to have it replaced or repaired.
Aug 14, 2009 | Samsung SyncMaster 920NW Monitor
My TV is going into standby mode whenever it is turned on
My screen turns black and the TV goes into standby mode (I get an Amber Light) within 3 seconds after turning the TV on.
Dec 16, 2008 | Televison & Video
Samsung SyncMaster 712n monitor will have small blue & white tiny checkers on the screen. will go away if i click the mouse. sometimes the entire screen has those tiny blue & white checkers.
Surely the monitor lets you change it's 'standby' settings so that it doesn't show that; or change your computer's power savings modes not to include standby?
May 29, 2008 | Computers & Internet
Samsung SyncMaster 17" LCD Blacks out
If you have a second monitor, you could use your computer until the monitor goes black... then plug in a replacement monitor. My guess is that one will display black too...
My gut feeling is that your VGA card is on the fritz... I'm not convinced it's your monitor. Do you have a replacement VGA card you can try? I'll bet that'll take care of the problem.
Apr 22, 2008 | Samsung SyncMaster 17" LCD Monitor
Samsung Syncmaster 940n - white screen
This is a known symptom of a failed power supply board. Here is a repair guide for this unit that shows how to dis-assemble the unit and then what to look for and replace to rebuilt the power supply board and bring the monitor back to life.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is a picture of the power supply board.
I hope this helps you, if so please rate my solution.
BuddyMc
Mar 25, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Samsung SyncMaster 940N Flat panel Monitor Logo
1,009 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
