Question about Elna 945 Computerized Sewing Machine
The presser foot lever on my Elna 945 is breaking/broken. I have ordered a replacement part and I'm wondering if I can do the replacement myself. Or should I take it to a pro?
  • Elna Master
  • 1,133 Answers
Here is a link to the service manual for the 925 http://www.arizonaexpressionz.com/elna_service/925_704%20suppl.%20service%20manual.pdf
I can't see one for the 945 but the above manual may give you some guidance as to what the replacment involves.
945 is a fairly new model so you may find that taking it to a pro and getting the timing and loopers checked at the same time is worthwhile. Also being computerised model, if you get something wrong and the computerised part is affected it could turn out more expensive to then take it to an Elna dealer.
I get my Bernette serger serviced every 2 years and it is now over 19 years old, and still performing well.
Posted on Jun 07, 2011
  • sharaliz Jul 05, 2011
    Hi Moseleybarb
    I have the same problem and ordered a replacement part but am having trouble fixing what appears to be a simple fix. Did you have any luck?
    Thanks!
    Best,
    Shara
Elna Pro 4De serger thread breaking
Be sure to thread each in the ORDER specified--for most machines (but yours may differ) upper looper, lower looper, then needles. Follow (closely) the threading diagram on the machine. Missing one guide or hitting the guides out of order will throw you machine into a tizzy! On my serger, the lower looper has to lay over the top of the upper looper/thread before it all gets pulled under the presser foot toward the back of the machine.
It also may help to RAISE the presser foot when threading the machine.
Having problems threading my Elna Pro DE 4 sewing discussion topic...
Threading elna lock pro 4 DE green knob
Oct 06, 2017 | Elna Sewing Machines
Why the foot for elna 9020 sewing machine is not working
IF the presser foot lever is not working, the linkage may be broken and needs to be replaced. This is a common issue and will require a new lever or armature so you can operate the presser foot properly. Please have a trained technician do the repairs for you. There will be affordable parts necessary to fix the machine.
Cheers,
Embroidery Services
San Diego, CA
Sep 09, 2017 | Elna Sewing Machines
Hi, My Elna 7000 doesn't easily feed medium or thin fabrics. Presser Foot tension lever is position 2 and the Feed Dog is rising normally. Any thoughts please? Does the F Dog wear out in any way?
Generally, the lighter the fabric weight, the heavier the presser foot pressure. Yes, feed dogs do wear with use. Do not run the machine without fabric between the presser foot and the feed dogs--the feed dogs constantly rubbing against the presser foot will quickly wear the feed dog points. Store the machine with the presser foot down with a pad between the presser foot and feed dogs (even a scrap piece of fabric will do). Also, be sure to clean the feed dogs of any gunky build-up. If the feed dog points are worn, it may be worthwhile to have them replaced.
Jan 23, 2017 | Elna Sewing Machines
Where is the foot lever on the Elna Pro 4 DE,
Am unable to locate information on your machine. However, the presser foot lever is usually located behind and above the presser foot.
Instruction Manual Elna Lock PRO 4DC 4DE Overlocker
Nov 14, 2016 | Elna Sewing Machines
How do we fix reverse lever on Elna 3230 sewing machine?
This sounds like a job for a repair shop. More than likely the presser foot lever is broken internally. Newer model or not. I think a repair shop will be able to repair this easily.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Nov 29, 2014 | Elna Sewing Machines
Where to purchase a serger 945 presser foot controller
Try Central sewing Machines in Edmonton Alberta. Looks like they have it in stock
May 02, 2014 | Elna 945 Computerized Sewing Machine
I have a Elna Pro 945 serger. I would like to use the piping foot #396013-82 however I don't have the directions on how to use the foot. Please let me know where I can get directions., Thank you Greta
try this link http://www.youtube.com/watch?v=bC-bJE5zwzw&feature=related for movie of a Pfaff piping foot in action, the principal would be similar, you are wrapping bias strip around cording on left of foot and overlocking right side. You can also do this with fabric top and botton thereby inserting the piping as you make it.
I have not tried this technique myself as I've only bought a blind hem foot for my Bernina but must admit I have used that a bit in the past.
Most serging techiques are very similar across the brands.
Mar 03, 2011 | Elna 945 Computerized Sewing Machine
Elna serger 925 presser foot lift lever broke off.
Here are 2 dillers that will repair it for you.
Sew Pros Inc 393 Broadway
El Cajon, CA 92021 (619) 442-3100 4.61 mi Burdick's Chula Vista Sew 278 Third Ave
Chula Vista, CA 91910 (619) 422-5325 10.56 mi
Good luck and please rate
Sep 16, 2009 | Elna Sewing Machines
Elan Pro 5 DC
Try contacting Elna directly, or find your nearest agent thru their website, if in USA ....here
having this photo should help trace a part number if you can get onto an Elna service technician, if it were Janome, I could look up our references, so it should be straightforward.
Feb 15, 2008 | Elna 1010
Elna 945 Computerized Sewing Machine Logo
332 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
