Question about Dishwashers
First light on washing cycle flashes continuously
  • ben1773 Apr 05, 2011
    Model is an Ariston LS245, recently had the motor/pump replaced, as water from the overflow tray had gotten into the motor and it would continuously short out the house safety switch ( the Residual Current Device, a safety switch that is in all Australian houses, to prevent electrocution) as well as drain hose, as the hose was damaged when the motor/pump was being replaced.
    When you go to run the machine on the 'Daily' cycle, the machine starts or certainly sounds like it starts when it was working in the past, and then the first cycle phase starts to blink continuously, whilst at the same time the machine does not sound like it is washing, it making noise but it does not sound like that normal cycle.
    I thought that it could possibly be the time delay option, but we do not use this function, I also tried pressing the 'Delayed start select button' as suggested in the user manual, to reset it, as suggested, but this does not do anything. The first cycle phase light blinks continuously.
    Any ideas
  • 4,323 Answers
Hi
Please elaborate and post back with the manufacturers name and model no. for further assistance.
Daniel
Posted on Apr 05, 2011
  • Daniel Scott
    Daniel Scott Apr 05, 2011
    Thanks....The issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling and/or draining ability. Use your voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If your switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
    Daniel
3 Suggested Answers
  • 58 Answers
SOURCE: Frigidaire Dishwasher Console/Lights Flashing
which light flashes?
Posted on Nov 02, 2007
  • 3247 Answers
SOURCE: Hi I have a Haier
It is possible the door switch is not making contact.
Can you see any difference if you press the door lock firmly?
Posted on Sep 28, 2010
Signal light flashes between cycles
Check the door switch... it is probably getting bad or pin is bent where it contacts switch
Oct 09, 2015 | Washing Machines
Lights keep flashing
I would check the water pump for a blockage, there could be something in the pump preventing it from doing its job as the machine cant go to the next cycle until the water has been expelled before the machine can continue eric
Jan 16, 2018 | Indesit Washing Machines
Dishwasher won't start - lights for Normal Wash and Cancel are flashing
check the controls,make sure that they are not stuck.
Dec 31, 2011 | Dishwashers
We have a Whirlpool 7KG frontloader washing machine (6th sense) model AWM8121. The problem is that the door light is flashing, the cycle has stopped at rinse (rinse light is on) and the machine is not...
We have an awm8121 and there seems to be a fault on the Spin cycle indicators with th 0 RPM and the 800 RPM flashing..
We can't seem to get the frontloader to finish the drain cycle and continue into the next was.
The last load of washing was still saturated when we managed to open the door.
Apr 20, 2011 | Whirlpool AWM8123 Front Load Washer
Whirlpool Cabrio wtw6600 stops at rinse and flshing light and sound, then afert pressing pause resum washing
Press STOP/CANCEL to clear the display and completely cancel the cycle
flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
Mar 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
When I start my LG WM2101HW washer, the spin light
sounds like a clitch under warrenty would call them out so you dont void warwrnty
Dec 06, 2009 | Washing Machines
All Lights Flashing on Hotoint Aquarious WF310 Washing Machine
Means that the heat sensor is broken.
Replace that and it should fix your problem
May 09, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Dishwashers Logo
Top Dishwashers Experts
