Question about Ludwig Classic Maple Power Drum Set Shell Pack - Red Sparkle Finish
Hi, I have a Ludwig Classic Maple drum comprising: Bd 16x24, Sr 5x14 , Tt 7x10, Tt 8x12 , Ft 14x14 , Ft 16x16 . I am very happy with the sound of this drum, very powerful, resonant, and easy tuning, I have some problems with the kick, the sound has much attack, but lacks body and is weak at low frequencies, you tell me how can I have a sound Kick better? .. Thank you very much. David.
  • 51 Answers
Here I've listed valuable reference information on bass drum tuning and achieving the lowest pitch possible. Some things are trial and error but once you fully familiarize yourself with drum tuning you should be able to achieve the sound you want. Hope this helps.
Kick Drum Tuninghttp://home.earthlink.net/~prof.sound/id6.html
Bass Drum Tuning Lesson http://www.drummerconnection.com/drumlessons/youtube/46667-bob-gatzen-bass-drum-tuning-lesson
Posted on Apr 05, 2011
Ajuste de maquinaria
Mida, you are in the LAWN MOWER section
Aug 28, 2013 | Ludwig LM 410 Super Sensitive Snare Drum...
My ludwig L315FP bass drum pedal keeps bouncing and i have loosened the spring all of the way. I still cannot get it from multi hitting the bass drum. Help?
Go to YouTube and search for "Bass pedal" There are many videos. Select and view ones on "setup" and also view "technique". These will solve the problems you are having.
Apr 02, 2011 | Ludwig L315fp Accent Custom Single Bass...
I'm trying to use the pads of my Yamaha DTXplorer drum kit as triggers for the sounds stored on my Alesis SR-18 drum machine. I have seen that Alesis markets a trigger module of their own which they...
Actually, ONLY TWO pins are used in the MIDI cable. The data is sent serially at a 31.25KBit rate.
You probably need to "map" the ones that aren't working into the appropriate codes to trigger the SR-18 sounds.
You need to COMPARE the codes sent from the DTX to those needed by the SR-18.
There also may be options in the DTX for type of drum kit such as "Latin" and selecting one of those may have the mapping already done.
In the literature of each device will be a list of the MIDI codes the DTX generates and those required by the SR-18.
essentially the percussion codes are NOT standardized completely between devices... but there is usually a way to "map" them to make it work.
Mar 09, 2011 | Yamaha DTXplorer 5 Electronic Drum Set
you need to determine what midi note the DTXplorer is using for the snare, kick and 3rd tom, and set the SR-18 accordingly, or vica-versa. the midi notes for each instrument has to be the same.
if you cannot change the midi note in either unit to make them correspond, you can download a "midi mapper" program (i think e-drum might be one), there is freeware available if you search CNet. with a midi mapper program, you would have to get a midi/usb adapter for your computer and rouite the midi signal through a computer. midi mapping software allows you to change the midi note, when the hardware itself is incapable of doing so.
Mar 09, 2011 | Yamaha DTXtreme III Drum Trigger Module
In play mode the sr 16 goes beserk. It makes a pulsed buzzing sound and plays back the drums distorted. any ideas?
The SR-16 uses an external transformer as the power supply which provides 9 volts AC. This ac power is converted to DC positive and negative voltages for the digital and analog portions of the circuit. Although the unit has been reliable generally, this symptoms sounds like of of the main filter capacitors in the DC converter circuit(rectifier, filters and voltage regulator) has broken loose or is defective. This will affect both channel equally. If the problem is in one channel, a broken shield on a cable or the output jack ground connection might have broken on that one channel.
Jan 22, 2011 | Alesis Sr 16 Stereo Drum Machine
How to use alesis 16
Here is a direct link to the full manual:http://www.google.com/url?sa=t&source=web&cd=1&ved=0CBQQFjAA&url=http%3A%2F%2Fmedia.zzounds.com%2Fmedia%2FSR16_Manual-9d796d56d2c465f19b598d39a29c8d8c.pdf&ei=Xl5jTPnqJ4H58AbV8cmnCQ&usg=AFQjCNFpvmSElGQGM8nwuB3AJl1gmao82Q Here is a link to the quick start manual:http://www.alesis.com/sr16?tt=5
Aug 11, 2010 | Alesis Sr 16 Stereo Drum Machine
Alesis-sr 16 sound low
Buy the correct adapter that matches the voltage AND current requirements of the unit. MANY universal ones do not and the original MAY have built in filter that universal does not.
You MAY also need to do a factory reset on the unit.
Oct 18, 2009 | Alesis Sr 16 Stereo Drum Machine
Need a user manula for ION iDM01 Electric Drum by alsis
Here is the link:http://ionaudio.com/contentmgr/showdetails.php/id/1137/tt/4 As far as I know they have nothing to do with Alesis.
Aug 27, 2009 | Alesis Sr 16 Stereo Drum Machine
For Sale Brand Korg OASYS 88 88-Key Workstation ????2100.00 EUR
If you scroll to the bottom of the page and click on Advertisers the site can help you.
Aug 05, 2009 | Music
Alesis SR-16 distorted sounds
The distorted and low volume output plus noise is usually caused by using the wrong power supply adapter. The Alesis SR-16 takes a 9V "A/C" supply not "DC". The A/C supply provides a negative voltage swing which wouldn't exist with a DC supply. So check and make sure you have 9V A/C output supply not DC.
Nov 18, 2008 | Alesis Sr 16 Stereo Drum Machine
Ludwig Classic Maple Power Drum Set Shell Pack - Red Sparkle Finish Logo
278 people viewed this question
Top Ludwig Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Ludwig Music Expert? Answer questions, earn points and help others
