Question about Sharp R-402J Microwave Oven
Model R402J ---lightbulb replacement. Can I do it myself? Any danger involved in doing so? What is the replacement bulb part# so I can locate one--and where?
    President:
  • 2,992 Answers
If you unplug the oven and let it sit a while to make sure that the capacitor has discharged, and you're careful, there's no problem with changing the lamp yourself. You need to remove the cover to get at it, and it's a special lamp with a mounting tab that secures it to the plastic duct covering the magnetron tube. I don't recall if this oven uses tamper-resistant screws, the Torx type with center pin that requires a special driver. If it does use these screws, you can find driver bits with little trouble today.
The Sharp part number is RLMPTA087WRZZ. Here's one source I use frequently, and there are many more appliance parts sellers online. You might also find a suitable replacement lamp if there's a well-stocked appliance parts store in your area.
Posted on Apr 05, 2011
How do I replace the lightbulb in the microwave and what light bulb do I need to purchase?
to replace the bulb in microwave ovens you will have to take the outside case off the unit as the bulb placement is not accessible from inside the oven
when you get to the bulb take it to an appliance repair shop and they will have a bulb
Sep 09, 2015 | In Microwave Ovens
How to replace light bulb in combination oven model acm1580ab
Cannot find your model number, please provide make and model.
Jul 23, 2008 | Amana Microwave Ovens
How do I change the lightbulb on a GE Monogram Microvae
The lamp is located inside the microwave housing which has to be removed to gain access for replacement. I agree with GE that removing the housing exposes you to dangerous voltages (even with power removed). The old lamp is removed from its socket and the new one installed, then the housing is reinstalled.
Mar 21, 2015 | GE Monogram ZEM200SF Microwave Oven
How do I replace the lightbulb in a GE Advantium 1200 microwave oven?
The outside cover has to be removed to get access to the lamp.
Jan 22, 2015 | GE Microwave Ovens
How to replace lightbulb
Is this a countertop microwave or an over-the-rang (OTR) microwave? If it's a countertop model, you need to completely remove the outer case to get to the lightbulb. If it's and OTR microwave, there usually is an access cover located behind the grill vent. You can remove that grille vent by removing the 2 to 4 screws above the grill vent. Then either slide the grill vent 1/4" to the left to remove it, or else (depending on the model), just pull out the top of the grill vent, followed by the bottom. Then you should be able to see the lightbulb access cover. Usually there is 1 screw that you have to remove. But unplug the microwave before you to any further! Now remove the screw, lift up and remove the cover, and you should be able to get to the light bulb.
Aug 10, 2014 | Kenmore Microwave Ovens
Replace a lightbulb in a microwave
That's covered on page 24 of the owner's manual.
If you've misplaced yours, you can download it online here.
If you need to order a bulb or other part or accessory, visit here.
May 31, 2010 | Maytag MMV5207A Microwave Oven
HOW TO CHANGE VIKING MICROWAVE LIGHTBULB VMOS200
The Viking VMOS200 is essentially a rebranded Sharp R-530E.
One or both of these service manuals should cover disassembly and location of the bulb:
http://www.microwavedisplay.com/r530ekt_r530est_r530ewt_sm.pdf
http://www.microwavedisplay.com/r530es_sm.pdf
May 28, 2010 | Viking VMOR205SS Microwave Oven
Need a replacement lightbulb for the Delongi AD1099 Rotisserie Oven and can't locate. It is not a microwave, though.
You can locate the correct bulb that you need at www.repairclinic.com. They have an extensive assortment for all appliances. When you search for your bulb keep in mind to put in the complete model # that is on your unit. Also this site can help you find a different replacement since it shows the type and size of bulb. Go by the wattage rating and what it looks like to fit right in. There are other similar sites and even belonging to Delonghi.com but I believe the repairclinic site is better.
Jan 23, 2009 | Microwave Ovens
Lightbulb no longers turns on!
They do this to avoid liability from your exposure to the instantly lethal voltages present in and generated by your microwave oven. For important safety and disassembly tips, search on Yahoo.com (not Google) for all this at once (copy & paste): microwave disassembly.txt safety.txt The oven must first be disconnected from the power line. The outer cover is held in place by several screws on the back and sides, then you lift up and back from the rear to remove it. You need to avoid the sharp metal edges on thge cover and inside the oven. Note there are also catches built into the top & sides of the cover which must be re-engaged upon reassembly, or the cooling efficiency will be compromised. Once the cover's off, if there's any chance you might come into contact with any of the high voltage connections, the high voltage capacitor should be discharged for safety's sake. Once the bulb is located, it can be unscrewed and replaced.
Nov 22, 2006 | Panasonic NN-T990SA Microwave Oven
Sharp R-402J Microwave Oven Logo
355 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
