Question about Refrigerators
Have a hotpoint side by side ref. The water in the door works great, but when you try to get ice or crushed ice you get nothing. The lights change on the readout. It only has one dispensor. It does not make any sounds. Could we have a bad drive motor?
  • 2 more comments
  • davidgalb721 Apr 05, 2011
    The ice-maker is working fine. I have no activation on the auger motor. It will not dispens any ice at all. When you press in on the dispensor lever the pass through door opens like it should, but there is no auger movement.
    I have removed all ice from bin! Including the ice in the front of the bucket.
  • davidgalb721 Apr 06, 2011
    What is the tap valve?
  • davidgalb721 Apr 11, 2011
    thank you!
  • 5,370 Answers
The auger should move, remove the ice and empty the bit manually, then manually move the auger and see, is it moving or is it stuck.If its easily moving then its faulty auger causing the issue.If its stuck , then motor is not functioning.In any such cases replacing the auger assembly helps.If there is any blockage then clearing that blockage helps. Otherwise replacing the auger assembly with motor helps. ----------. You can get required parts from from online sites like: --- www.repairclinic.com ----------
This should help.thanks.helpmech.
Posted on Apr 06, 2011
    Genius:
  • 1,196 Answers
If the ice is not getting ejected and seems to be stuck in the ice maker, the defect lies in the ejector mechanism. Since the ice maker cannot eject the ice, you need to put it to the manual shut off mode, so that ice maker doesn't continue to make more ice. In such a scenario, you will need to shut off the power to the freezer for carrying out the repair, so if you are not comfortable with handling electrical appliances, you could call repair person to help.
Posted on Apr 05, 2011
  • Ishola Olayemi Apr 05, 2011
    I think the problem is linked to a defective tap valve, you might need to replace it
LG REFRIGERATOR DISPENSER NOT WORKING
x1 sonny ericcson widows mobile 6.1 version i want to change my language to english
Jan 05, 2014 | LG LSC26905TT Side by Side Refrigerator
Cubed Ice selected, crushed ice comes out
ice maker works. water thru the door works. lock works. light works, alarm works.
when i try to get crushed, ice cubes or quick ice.
nothing happens
Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
No water from water dispenser on my ge hotpoint refridgerator
its possible the water tank or tube is frozen up. try turning off the refrigerator and leaving the door open for about 10-15 minutes and see if it will start working again. if that works adj your temp settings to warm the fresh food section up just a little to prevent it from freezing again..
Dec 12, 2007 | Hotpoint HSS25GFP Side by Side...
Ice dispenser only dispenses crushed ice
Check and make sure your switch is okay. Some have a switch that controls whether you want crushed or cubes. If it is defective replace it.
Oct 23, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
