Question about Epson Stylus CX6000 All-In-One InkJet Printer
I downloaded drivers for my Epson printer so thaat it would work on my new computer which has windows 7 on it . I no problems when I scan an item but when I go to print something from my computer the printer will only print the pictures and no words. Can you please help because this is very aggrevating. When I had it on my old computer windows xp I had no problems with it, but the disk that came with to upload it will not load on my new computer this is why I had to download the drivers from the Epson site online. Please help me if you can because I do not want to have to buy another printer I have always liked this one up until now.
  • Epson Master
  • 17,130 Answers
If you can it will be ideal to have the printer crossed checked than to come to an early inference.
I would suspect that the drivers has some errors and so it has not meshed up. If so remove the printer connection from the PC and un-install the drivers.
Now reinstall the drivers and then connect the printer which will be detected and installed as a new hardware. if then the printer behaves the same manner, I would suggest that the printer be checked on another PC with the same drivers.
This will confirm if the OS has some errors with the downloaded printer drivers or that the drivers are faulty.
Also you can uninstall and remove the drivers and then download once again the drivers to make sure there were no errors.
Please check this out.
Posted on Apr 05, 2011
Can I use my Epson RX630 printer/scanner with windows 7 ?
Yes, the RX630 can be used with Windows 7 (x32 or x64). See http://tech.epson.com.au/downloads/category.asp?sCategory=Multi_Functional&id=stylusrx630&SelOS=Y for the available software. This printer is very similar to the RX620; thus those drivers/utilities may be useful. https://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=44341&infoType=Downloads&platform=OSF_W_7-64 . Use the Control Panel Add a Printer feature if the printer is not identified by the New Hardware Wizard with the USB connection. (First make sure that you have the printer connected directly to the computer's USB ports and that it is in a working port.) If Windows 7 doesn't automatically find the driver for the scanner of the all-in-one, load the appropriate driver for Vista. However, the buttons on the printer may not work to launch the scan to computer applications. If that happens, launch your scans from the computer. Windows 7 comes with Windows Fax and Scan to handle basic scans.
I hope this helps.
(The Epson Event Manager is needed to launch the scans from the all-in-one. It's not listed separately at the first link to Windows drivers/software for the printer given above.)
Jan 06, 2016 | Epson Office Equipment & Supplies
EPSON L355
EPSON L355 EPSON Drivers and SW
Jan 27, 2014 | Epson Office Equipment & Supplies
How do I make my epson stylus NX330 printer recognize my computer so I can scan to it.
  • http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=183403&prodoid=63091347&infoType=Downloads&detected=yes&platform=OSF_W_7-64
    Drivers and Utilities Combo Package 11/17/11 90.5 MB DownloadDescription: This file contains everything you need to use your Epson Stylus NX330 wirelessly or wired.
    This combo package consists of the following items:
    • Printer Driver v6.91
    • Scanner Driver and EPSON Scan Utility v3.781
    • Event Manager v2.50.00
    • Network Installer
    Compatible Systems: Windows 7 32-bit, Windows 7 64-bit, Windows Vista 32-bit, Windows Vista 64-bit, Windows XP 32-bit, Windows XP 64-bit
Not what you are looking for?
View all downloads for Windows 7 64-bit in the sections below, or select a different operating system above to reveal other downloads for your product
Nov 09, 2012 | Epson Stylus NX330 All-In-One Printer
I have windows vista. epson stylus cx4200 will print but does not scan. installed windows 7 64 bit drivers but not successful. need help. thanks
Download & install the "Epson Stylus CX4200 All-in-One Printer" @ Drivers and Utilities Combo Package
Windows 7 64-bit compatible, Windows Vista 64-bit
epson13071.exe - 20.9MB
- posted on 07/07/09
This file contains everything you need to use your Epson Stylus CX4200 with Windows Vista 64-bit.
This package consists of the following items:
•Printer Driver v6.5
•Scanner Driver v3.04
•Epson Status Monitor 3
•Epson EasyPrint v3.10
Uninstall your previously installed AIO drivers before installing the downloaded installer.
Hope it helps.
Jun 02, 2011 | Epson Stylus CX4200 All-In-One InkJet...
Can't connect printer.
Hi, It seems that the you might have upgraded your computer to Windows 7 and you are not able to get your printer work. In this case you need to download printer's driver for the operating system that you are using that is Windows 7 64-bit. Download the driver from: http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX5000-all-in-one-printer/Drivers-Support
Once downloaded, install the printer using the new obtained driver. Hope the new driver would work on your computer. Moreover, you may change the USB port to which the printer is connected, meaning unplug the printer from the computer and re-connect it to different USB port of your computer and try to install printer.
Cheers!
Mar 02, 2010 | Microsoft Windows 7 Ultimate for PC
EPSON RX620 PRINTER WILL NOT INSTALL ON NEW WINDOWS 7 COMPUTER
This is where most Pc user fell prey to the new features of Windows 7. I agreed windows 7 is far more secure than any other Operating system that Microsoft has release till now.
But many forget to consider the point of hardware whihc they are going to use in day to day life really support Windows 7.
Only the scanner driver has been release by epson for your printer for windows 7. So there's no work out as they haven't even release drivers for windows vista too.
And you won't find the driver on net as nobody will write the driver program for any printer without the blue print of the printer hardware.
Soory again.
Jan 12, 2010 | Epson Stylus Photo RX620 All-In-One InkJet...
Windows 7 is not recognizing me Epson RX595
The following steps may help:
  1. Remove all the drivers and software installed for this printer.
  2. Restart your computer.
  3. Click here to go to the driver download page. Download the driver for Win 7 and install.
  4. Connect the printer to your PC, the installation will continue.
  5. After installation, you should be able to use your printer.
Nov 03, 2009 | Epson RX595 Photo All-In-One Printer
Software
Here is the link where you can download the drivers for your printer
EPSON
You will have to donload 2 driver, the printer driver and the TWain driver and epson scan utility for your operating sytem
Pls dont forget to rate solution, thanks!!
If you have issues still feel free to email me back
For scanner
Install
1. Go to www.epson.com/support
2. Under Welcome to Epson Support click on ALL-IN-ONES and select FLATBED and then your Stylus model name. Under the Drivers & Downloads section select WINDOWS.
3. Select and download the most current Epson Scan driver for your operating system.
4. Follow prompts through survey and license agreement and downloading will begin. When prompted, choose to SAVE this file; SAVE it to your desktop so it will be easy to find.
5. Once download is complete, close your internet browser. To install simply double-click the file you downloaded and follow the prompts.
6. Turn your unit on and reconnect it to the computer after the installation is complete. Windows should detect new Hardware and complete the installation automatically. (If a New Hardware Wizard appears, allow it to search automatically.)
7. Restart once installation is complete.
Once the computer has restarted you are ready to scan. We recommend starting with a test of Epson Scan itself. Simply go to Start, (All) Programs, Epson Scan and launch the Epson Scan utility. In File Save Settings you can select the location, prefix (name) and format the scan will be saved as. When ready click OK or Scan and the scanning process will begin.
Installation
2. Under DOWNLOADS AND SUPPORT click on ALL-IN-ONES and select FLATBED and then your Stylus model name. Under the Drivers & Downloads section select WINDOWS.
3. Download the most current driver for your printer and operating system.
4. Follow prompts through survey and license agreement and downloading will begin. When prompted, choose to SAVE this file; SAVE it to your desktop so it is easy to find.
6. Do not reconnect the unit until the point in the printer driver installation where you are prompted to check that the unit is on and connected to the computer. Installation should complete automatically.
May 01, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Microsft Vista doesn't support 4990 negaives scanning
trash and reinstall the epson scan software and download latest driver for your devices use this link support.epson.com and download drivers for win vista.
Apr 01, 2008 | Epson Stylus RX425 Multifunction...
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
16 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
