Routers
Problem for Routers
Generic problem for all Routers
360 mtu test keeps failing
By curtdogg on Aug 06, 2008
360 says mtu failed how do i change routers mtu settings it used to work fine
Same Problem
Apr 05, 2009
-   360 mtu test keeps failing
-   Guest
Feb 11, 2009
-   i have a 2wire gateway from at&t and idk wat to do i NEED help-   Guest
Jan 27, 2009
-   i must of tried 20 times, but the password for the prompt won't accept admin as the password.
-   Guest
Jan 26, 2009
-   how do u change MTU settings
-   Guest
Jan 06, 2009
-   I cannot figure out how to set my MTU setting higher
-   Guest
Solution #1
posted on Aug 08, 2008
Somewhat Helpful)
kakee
Rank: Wiz
Rating: 81%, 457 votes
Using the main computer, open your Internet Explorer and on the Address Bar type http://192.168.1.1
It will prompt your for username and password. By default leave it blank on username and type admin on the password
Under SETUP tab, you can see there MTU, set it to Manual and set the size to 1400 then click on SAVE SETTINGS at the bottom.
Now powercycle your devices. Turn off router first and then modem. Wait for 30sec. Turn on modem first, wait for lights to stop blinking then turn onrouter.
That's it..
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Oct 24, 2008
Not Rated)
PANKACKES
Rank: Apprentice
Rating: 0%, 0 votes
well i did that but the thing is it does not do anything i put in the password admin but nothing happens at all just a error page
Was this helpful?
Yes
No
Solution #3
posted on Sep 30, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
whenever i type in my ip address it just says there are no search results found
Solution #4
posted on Sep 29, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
XBOX LIVE IS CURRENTLY UNDEGOING SOME CHANGES THAT IS WHY YOU CANNOT ACCESS IT
Solution #5
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Isn't XB Live offline today for updates? I wouldn't mess with any settings right now!
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,... (More)
Answer
br-6104 kp windows7 add port on client for printer server use
Answer
Hi, I'm considering purchasing an HS-100W. How would I sign up for the parental controls?
Answer
Two windows 7 PCs connected to DLINK DGS-1005D gigabit switch. Switch is commected to DSL-G604T... (More)
Answer
I recently purchased a Belkin N150 (during the walmart black friday sale) and it has been running... (More)
33 Other Users Have The Same Problem - Continued
Comment by Bigpajog, posted on Dec 31, 2008
man m havin the same problem i typed in http://192.168.1.1
an that **** didnt work im lost an confused?!?!?
Comment by Guest, posted on Dec 28, 2008
mi xbox say mtu failed how do I change the mtuof my router
Comment by Guest, posted on Dec 26, 2008
trying to connect new ipods cant remember password to the wireless router
Comment by Guest, posted on Dec 15, 2008
The MTU setting keeps failing for xbox live connection test
Comment by Guest, posted on Dec 14, 2008
where can I find the MTU setting????????
Comment by Guest, posted on Dec 07, 2008
When i try to set up Xbox live using this router it says i do not have the minimum MTU
Comment by sunsballa, posted on Nov 23, 2008
when i type in "192.168.1.1" it claims that the site doesnt exist
Comment by Guest, posted on Nov 14, 2008
yes, need to be set to the designated amount. need to know how to fix it.
Comment by pics1493, posted on Oct 09, 2008
Keeps failing when im trying to use Xbox LIVE.
Comment by Guest, posted on Sep 30, 2008
i've been having the same problem too
but i think its just the update.
Same problem very frustrating.
Comment by goose_rocks, posted on Sep 30, 2008
same prob here...i tried that solution on the bottom but the http addy doesnt take me anywhere....whats up?
Comment by ben-burgin, posted on Sep 30, 2008
i have the same problem. i kno xbox live went down on the september 29th. but xbox said that it would b bac on the 30th. iv checked time zone an so on an as far as i kno xbox live should be bac on. but i cant connect my dashboard is tellin me i need 2 change my mtu settings. so i went 2 my router settings but i cant find anywhere 2 change my mtu settings? can any1 help me? iv already tried 192.168.1.1 web adress aswel but i cant connect 2 it. is xbox live takin longer than it should in comin bac online? cos iv never had ths problem b4?
Comment by niktwikoli, posted on Sep 30, 2008
I thought it was just my evil bad luck playin up again but seems its not just me,am havin same problem with mtu failing but have still been getting maximum down & upload speeds through my pc....??it must have somethin to do with the update but i dont understand how or why its affectin the routers transmission..?please someobne enlighten me help fix it am gettin withdrawls lol thanks
I'm having the same problem, the MTU test keeps failing. MY Xbox360 was working fine until about 1 day ago, possibly the start of the update. I've heard that Xbox live went back online, yet I'm still having the MTU failure.
how long will live be down
Comment by ArenaBritt, posted on Sep 30, 2008
I am having the same problem, but I am thinking it is because of the update they are doing. They sent an E-mail saying it was going to be down Monday the 29th...
it is because live is down i have the same problem
Comment by trilobyt, posted on Sep 30, 2008
Me also. Started after downloading most recent xbox update. Can't find ANY MTU settings on router and have never had problems before. Powercycling didn't work.
Comment by KOKs112, posted on Sep 29, 2008
now i dont know if its because the network for live is down right now or not but, my router worked great last night and now it doesnt work at all, the mtu test keeps failling and i dontr know why. anyubody have a clue????
Comment by Guest, posted on Sep 29, 2008
Same thing
Comment by WOODS7927, posted on Sep 29, 2008
I have the same problem,but I have a D-Link(DI524) wireless router that is failing the MTU ON MY XBOX360. The default MTU is higher than the minium MTU THAT XBOX NEEDS, BUT STILL FAILING
Comment by roger771, posted on Sep 29, 2008
Have now seen this:
As we gear up to bring you the New Xbox Experience, Xbox LIVE and the Xbox LIVE page on Xbox.com will be down for 24 hours, beginning on September 29, 2008 from 12:01 AM PST until 11:59 PM PST. During this time you will not be able to access Xbox LIVE.
Comment by dylanrchiles, posted on Sep 29, 2008
i cannot connect to the http://192.168.1.1 either, it shows page load error.
Same problem here. Have checked MTU on router & it is fine. I now suspect an XBL issue if we all have it?
but i cant connect to that 192.168.1.1
Same problem here xbox 360 worked fine for two years. suddenly MTU faillure noe ( 29 september 2008 ) Live Poblem?
Holland
yea i have the same problem,but when i get 2 my router's main menu,i see no mtu settings or anything like that,i checked all of the routers settings and i can't find it, i own a belkin wireless 54g router. any help would be appreciated
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Routers Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
