Question about EMC 500GB 7200RPM SATA DISK DRIVE FOR AX100 (AXSA07500) Hard Drive
I need to get a new drive caddy can you help?
  • EMC Master
  • 27,725 Answers
You could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Posted on Apr 05, 2011
How to remove hard drive from fujitsu n6000
On the bottom of your Fujitsu N6000 laptop, find the hard drive door to access the hard drive.
2. Remove the Screws.
3. In this step, you will either need to pry out your Fujitsu N6000 hard drive caddy, or simply remove the door.
4. Once the Fujitsu N6000 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Fujitsu N6000 hard drive.
Good Luck
Aug 31, 2014 | Computers & Internet
I have the aspire 3680 but it hasa mk8034gsx-si hard disk that has gone bad what do i do?
Hello
You may need to re-place the hard disk if it gone bad, the picture shows it procedure of replacement.
The hard drive can be easily accessed from the bottom of the laptop. Simply remove the hard drive door, remove four screws securing the hard drive caddy, disconnect the hard drive from the connector on the motherboard and remove it from the laptop.
After that remove all screws securing the hard drive to the caddy and transfer the caddy to the new hard drive.
Hope this helps, if so rate the solution
Jan 20, 2011 | Acer Aspire 3680 Laptop
I need to re-connect the internal DVD drive in my daughters Gateway MX6428 laptop. She apparently dropped it and it no longer registers it's connected. We've taken all the panels off of the bottom. No...
How to Remove Replace and Install Your Gateway MX series MX6428 Laptop Hard Drive
1. On the bottom of your Gateway MX6428 laptop, find the hard drive door to access the hard drive.
3. In this step, you will either need to pry out your Gateway MX6428 hard drive caddy, or simply remove the door.
4. Once the Gateway MX6428 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Gateway MX6428 hard drive.
Nov 12, 2017 | Gateway MX6428 Notebook
Need to import 3M PiN files from an old HD to a new HD Have v2.0 Office Not computer literate Can you help
If the old hard drive is connected, just copy them over, either cut and paste or just drag and drop them onto your new drive.
If it is no longer attached to your computer, you will need to buy a caddy, or enclosure to fit it itno, then just attach via usb.
Google hard drive caddy
Sep 30, 2010 | 3M Post-it Software Notes 3.1 Professional...
What do i need to install a WD Scorpio Blue 500Gb hard drive in my HP dv90052us laptop - i've got the drive but it does not fit in it's slot like the original drive does - i'm putting it in the second...
You may need a "caddy" -- a metal shell that wraps around the disk-drive, in order to line-up its "data" and "power" connectors with the matching "sockets" inside the second drive-bay.
Order the caddy from http://support.hp.com
Apr 18, 2010 | HP Pavilion dv9005us Notebook
Specifically where is the hard drive for the toughbook cf- 27 - i've looked all over
Flip the laptop over and slide the 2 tabs that are near the carry handle to the unlocked position. This will allow the metal cover on the underside of the laptop to hinge up and be removed.
With the laptop upside down and the carry handle facing you, you should see the battery on the left of the laptop. On the right, there is a silver case about 4 inches long and 2.5 inches wide. This is the hard drive caddy.
To remove /this/ part, carefully push the connecting cable towards the battery until it smoothly disconnects from the hard drive caddy. Remove the caddy from the laptop. Using a small phillips screwdriver, remove the 3 small screws which hold the top of the caddy on. Remove the top, and you will see the hard drive.
As a note - be sure you do not remove the gel lining. This is 99.9% of the hard drive's shock protection. When you remove the hard drive, the cable should come out of the caddy as well. Put the new cable on a new hard drive (HDD must be smaller than 65,536MB), put the new hard drive into the caddy with cable attached, make sure the cable assembly is fitted into the caddy slot, replace the caddy cover, replace the screws, replace the caddy into the laptop. Then, make sure you connect the cable from the laptop PC board to the caddy cable assembly. Replace cover, turn on computer, and set up your Operating System (if needed).
Nov 10, 2009 | Panasonic Toughbook CF-27 Notebook
I have an E1505 with no hard drive, no dvd drive. 2 questions: Is there a special "sled" or tray needed for a new drive, and do the connectors for any new hard drive line up and plug into the bay...
Answer for question 2 is yes, get into the BIOS and change the boot menu to include a ISB device if one is not enabled. I am unsure of the factory default, but once you are in the BIOS you can check that usb booting is enabled.
The hard drive of the E1505 use a "caddy" which consists of a smooth plate and a caddy head that screws to the hard drive and allows easy access to the drive by allowing you to pull it free of the side of the computer. Some people do not use the flat plate and just screw the caddy head atraight to the drive itself. I would recommend the whole caddy setup. Ebay sells them by the hundreds. Dell does not use an adapter on the hard drive to get it to connect with the motherboard. Your drive should be a SATA interface and that is what is on the motherboard as a connection. All you need is a "caddy" to be able to easily remove and secure the hard drive.
Oct 28, 2009 | Dell Inspiron E1505 Notebook
I have windows vista just had a new hard drive installed the data off the old drive has been put onto an hdd caddy how do I load it back onto the new hard drive of my computer, the caddy is a plug in via a...
When you insert the usb cable from the caddy into a USB port on your notebook, Vista will automatically recognize it and open a dialog box. Choose to view files and folders.
Open another Window using Explorer and resize it so you can see the contents of your C: drive.
Then simply drag your files and folders from the caddy to the C: drive where you want them.
Remember that transferring program files will NOT help you as many of the files needed to run a program are located in other folders such as yours Windows directory. You will need to reinstall any software you wish to use.
This method is strictly for data transfer, as an example all your pictures, documents, spreadsheets, etc.
Sep 24, 2009 | Dell Studio 15 Laptop
This external drive isn't recognized by any of my computers. HELP
If it is not showing up on any computers there's most likely a hardware problem in the drive or AC adapter. Do the lights come on when you plug the power in? If not you need a new adapter, if they do the failure is either in the drive caddy circuitry or in the drive circuitry. You can take it to your local PC shop and have the techs test the HDD in a new caddy, if it works in the new caddy your done, if it doesn't you may need the help of a pro to recover your files off of the drive. Hope this helps FixYa, if you need additional assistance or a referal to a pro comment back here with questions or your country and city. Chris
Jun 06, 2009 | Verbatim SmartDisk Firelite Portable USB...
Hi, i buy used laptop L355D-S7815 without hard disk i put a new 1 work fine but i don`t know if must have a caddy or something else because feel like is loose please help. thanks.
Some laptops need a caddy, but if the hard drive can fit in without a caddy then don't worry about it. If the drive is a bit loose then wrap or add some paper around the hard drive to stop it moving about.
Apr 02, 2009 | Computers & Internet
EMC 500GB 7200RPM SATA DISK DRIVE FOR AX100 (AXSA07500) Hard Drive Logo
259 people viewed this question
Top EMC Computers & Internet Experts
LP
charlie rodriguez
charlie rodriguez
Michael Harrier
Are you an EMC Computer and Internet Expert? Answer questions, earn points and help others
