Question about Whirlpool Washing Machines
My washer (Whirlpool StyleMaster 907675) is leaking into the wash basin (inside where the clothes are placed)constantly, without any drainage. This is when the machine is off, and it simply drips water from where the water usually comes out of. What can I do to stop it and how serious is this damage? Would it be costly to fix?
    Novelist:
  • 116 Answers
This usually indicates that there is a problem with the inlet water valve. This can only be corrected by replacing the valve. It is attached to the plastic hose connections on the inside of the washer.
A quick temporary fix is to shut the main valves off behind the washer when it is not in use. This may be a little inconvenient until the problem is fixed. It will still leak a little but not enough to worry about.
The valve itself is not too expensive is should cost between $10 and $35. The labour charge will be what is standard in your area. Possibly around $100. About 1 hour labour.
Posted on Aug 06, 2008
Why won't my Whirlpool Washer Stylemaster #907675 fully drain?
The pump may be failing. That's where the leak is coming from.
Jul 28, 2014 | Whirlpool Washing Machines
Hey I'm an expert on this! You have a bad Drain Pump. It happens very frequently because of the amount of work it does. Replace it and your machine will return to Glory!
Jan 16, 2014 | Washing Machines
We have a stylemaster #907675 Heavy duty. It will not spin anymore, can you help diagnose?
It is a computer problem and you can get it fixed free, due to a recall by Whirlpool. Call the company and complain. My daughter had the same problem.
Jul 16, 2011 | Whirlpool Washing Machines
Water is trinkling down the bello and filling drum after wash is complete
Theres an electric water valve. You have to find out if its the hot or cold thats leaking and replace it.
Jan 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool stylemaster 907675 Washer wont spin.. The lid switch is fine.. Washes fine and all other cycles work.. just wont spin.
Hi, stylemaster washing machine won't spin on the top half. The bottom part spins perfect. the top doesn't seem connected. What
should I do ?
TIA
RJ
Jan 08, 2010 | Washing Machines
Cold water hose or seal leak inside machine leaks into basin
Replace the water inlet valve. That is where the hoses connect.
Here is a link to show you how to access the inside of the washer..
Mar 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have an older Whirlpool washing machine (Stylemaster # 907675.) It leaves behind lint galore and white smudges that are almost impossible to clean off. Do you think it has a filter that might need...
WHIRLPOO STOP USING FILTER IT MAY BE COMING FROM THE TUB. TRY RUNFIN A WASER CLEANER LIKE C.L.R. CAUSIM LIME AND RUST REMOVER. AND TAKE THE SOFTER OUT BY PULING THE BLUE RIND UP AND PULL THE SOFERNER UP AND PUT IN WASHER TO GET CLEAN IN HOT WAER LOW CYCLE.
Jan 25, 2009 | Washing Machines
Open Questions:
Washing Machines Logo
661 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
