Question about AKG Perception 420 Microphone
Sometimes my AKG Perception 420 won't record properly, when played back it sounds like white noise with the faintest sound of what i'm trying to record in the background
  • 51 Answers
All microphones have a signal to noise ratio. Basically defined as the level of desired sound to background noise (unwanted sound). Microphone phones also have self noise which should be considered when choosing a mic. There will be noise in every mic, some more audible than others. Condenser microphones require phantom power (48V). This can be supplied by mic prea
mps, mixers, and similar equipment. *Note that phantom power (mic pre amps) must be on or engaged, this can be specific to different types of equipment.
Troubleshooting:Has your microphone been dropped or exposed to moisture? Internal damage to your microphone will be hard to assess but this could possibly be the issue. Inspect the microphone cable, check for damages. Try using a another microphone cable-- preferably a new one. Next to check would be your mic's power supply. Make sure all connections are made properly (mic to cable to power supply). If you are using a mixer or pre amp with multiple inputs, test the mic on each input. (You should test by making recordings and comparing with each change to isolate possible causes). Also test the mixer or pre amp by slowly sweeping the input gain feature while recording an audible source such as singing into the microphone. Typically next in the audio recording chain would be your DAW (digital audio workstation) or computer, but problems with noise most likely precede this.
I could possibly provide more useful information if I know your exact setup.
Provided that you have your equipment setup properly, the microphone or mixer/preamp could possibly be damaged/malfunctioning. I suggest taking your equipment to a trusted repair shop, or if still under warranty, returning to the manufacturer for repairs or replacement.
Hope this helps
Posted on Apr 05, 2011
I recently bought the AKG Perception 120 and have a macbook pro. I also bought a XLR to usb cord to record it in Garageband... But there is no sign of any sound going through the microphone. Please he
Make sure your preferences settings in the MBP are set to use that input. USB recording is not the best way to do things. I'd look online and buy an inexpensive interface, like a Lexicon or Presonus etc, then the interface will connect via USB, but your mic will go into a genuine XLR input on the interface. You'll also benefit from much more gain and level control.
May 14, 2014 | AKG Perception 120 Microphone
Akg perception 220 professional microphone
Try building a little mike-preamp with an opamp to boost the signal.
Enough schematics on internet.
Or walk into an electronics shop for a ready to build package.
These are the things I can suggest; I don't know your audiobox.
Perhaps there is internally a pot-meter to adjust the gain of your mike; that would be the easiest solution.
Mar 06, 2014 | PreSonus AudioBox 22VSL 2x2 USB Interface
AKG 120 on Mac, I don't get feedback on headphones or internal spekears . Recorded voice , I can see is there but can't hear anything....
Sounds like you have a computer sound issue. If the waveform is shown, and the amplitude is sufficient then it should playback audio. Not familiar with Mac but check mute settings, sound card volume, input/output config., audio routing, etc.
Feb 18, 2013 | AKG Perception 120 Microphone
Crackling noise and low volume
If the mic is a condensor you would need to have phantom power, or it will not work. Use a small mixer or externat power supply. We here at Pro Line Music Have small mixers that have phantom power. 215-736-8055
Dec 26, 2009 | AKG Perception 120 Microphone
My mic only records on the right side
This is a single condenser cardioid pattern mike, it picks sounds only from the front - maybe all you have to turn it in the right direction Have you checked the mike in another place? If it's the same then the condenser inside is misaligned - if it's out of warranty open it and replace correctly the condenser mike.
Oct 25, 2009 | AKG Perception 120 Microphone
AKG Perception 200 Mic stopped working. I use it
The simple thing to check would be to see if your 48V phantom power switch on your mixer is turned on. Sometimes there is an individual button to turn it on and off for each channel strip. Good Luck
Oct 06, 2009 | AKG Perception 200 Microphone
My AKG Perception 200 Cut the signal suddenly
Sounds like a loose connection. Try duct taping the microphone cable in place where it enters the microphone.
Jul 27, 2009 | AKG Perception 200 Microphone
AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Dec 03, 2008 | AKG Perception 100 Microphone
AKG Perception 420 Microphone Logo
393 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Ben Armstrong
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
