Question about Roland BR900CD Digital Multitrack Recorder
My adapter or plug is broke and i need a new one. last night i used an adapter from the br-800 and it worked except that when i used the cd option the screen would flicker then it would shut off?
  • 28 Answers
Sounds like the adapter for the 800 isn't quite up to delivering the required current, If it is a standard barrel plug type, you should be able to get a low cost replacement from a local electronics store like Jaycar (Australia) or Radio shack (america) to name a few examples. If possible, take the failed adapter from the 900 in with you when you go to get a replacement as this will help the staff get you the right adapter.
Alternatively you could try ordering one from roland, but that would be a much more pricey venture.
Here is the support site for roland products, it will give you an idea of how to go about having your adapter repaired or replaced.
http://www.rolandus.com/support/?tab=service_repair
Posted on Apr 05, 2011
Koehler and Campbell upright piano model 1951 serial 764863...value?
use this link to get more historical information
contact us
http://antiquepianoshop.com/online-museum/kohler-campbell/
only worth what a person would pay you for it
the only way to get top dollar is to have it fully reconditioned back to looking new by .Kohler & Campbell themselves
.internals and outer casing
lots of pianos out there for sale
a basic upright .lucky to get .$800 or less
1951 ..not that much in demand not rare
iron framed and depends on what the condition
Jan 13, 2017 | Music
My church is looking for brass band instruments funding,but we don't seem to get one
.try lots of fund raising activities
using church hall and car park
church fete
baby sitting
games/movie nights ,
plays ./drama /choir nights
dances
cake auctions,
car washes
car boot sales
bingo ,
brass instruments are never cheap
you need to look around...for used brass instruments and brass sheet music
in second hand shops , garage sales , online sales newspaper ads
never knew any government or corporate companies to throw money into brass bands
Oct 18, 2016 | Music
Is it possible to connect my Boss multiple effects ME-25 to my BR-800 recorder. If so how, and can it then be linked to an amp (again how)
Hello Alan.
Yes you can connect your ME-25 to the BR-800, there is no risk to damage any. it is simple, you may use both outputs of the pedal and send them via two normal 1/4 plug guitar cables to two of the channels of the DR (i.e. ch 1 & 2) to avoid an initial saturation of the recording preamp, set the input sens pot at minimum and the sliders very close to minimum as you try playing and looking the levels on the display and adjunting them to the optimum.
To connect the DR to an amp you should use the pair of RCA jacks named LINE OUT (R & L) depending of the amp you have there might be the need for a conversion cable or plug adapters. The out put of the DR is stereo, and if you want to use a guitar amp, commonly mono, you should mix both channels to send them to one input, this can be done by putting two 10 kohms resistors in series with each channel output and joining the other end to the input.
Good luck and best wishes
Nov 20, 2014 | Roland Boss BR-800 Digital Recorder
I lost my adapter to my keyboard and I need to find either a substitute or a new way to turn it on without the adapter, HELP!!!.
Some Casio Keyboards use 9V DC (center negative) others 12V DC (center negative).
If check what voltage your Keyboard use. Generic AC adapters are usually center positive. So you have to invert the wire with a new DC plug to make it center negative,
Easiest is to buy a Casio ac adapter made for your keyboard from a Casio retailer.
Sep 12, 2013 | Casio Keyboard Power Adapter
Roland TD8 has no power
I would try another ac adapter. Plug in that one and stick it on your tounge and see if it bites. It should only be 9-12 volts, just to see if it works. It may have a fuse inside but I doubt it, if you have to replace the adapter, there is a diagram on the back below the plug showing polarity and specs. Voltage must be the same and mA must be as specified or higher. NOT lower except for checking for lights or signs of power. Normal usage would need its requirements or higher. Make sure the + and - are correct to avoid damage.
Feb 20, 2013 | Music
Hi. My boss br 1600 will n ot start. I turn on the power source and it will blink for a split second and then nothing. I checked for loose connections but everything seems ok. Any suggestions?
I have this problem with mine. I've did some research and with the boss br 600 this problem can arise quite often .it's caused by a faulty power diode apparently except in that case I've never heard ofrom the screen blinking at all (which my 1600 also does) I wonder I'd this problem can be the same for a br 600 as the br 600
Sep 08, 2011 | Boss BR 1600 Cd Br1600 Cd 16 Track Digital...
I cannot turn on my Micro BR - its plugged in and has new batteries but still won't work Does this mean it's completely broken or is there some sort of stand by phase that may have initiated itself?
The devices that have battery AND adapter capability OFTEN have a switch that the adapter opens when powered by the adapter. Often this switch contact gets bent and units won
t run on battery, so try it on an adapter... if the adapter works and battery doesn't, this contact whcih is a part of the input power connector has failed.
Sep 06, 2010 | Boss Micro BR Digital Recorder
Micro BR power Adapter
You may have damaged the data on the memory card. If you have no display at all carefully read page 125 of your manual.If it doesn't display with the adapter plugged in try new batteries. If it still doesn't display anything, contact the dealer you bought it from or try contacting Roland. This site should help:http://www.rolandus.com/support/service_centers/
Jan 29, 2010 | Boss Micro BR Digital Recorder
What do I need to burn a cd from my pc with the br 1180
This Is real simple grab a cable that goes from rca jacks to a headphone jack then plug the rca jacks into the br-1180's audio out jack and then plug the other end into your computers mic port.
Download Audacity From www.Audacity.com and then use it to capture you audio and then you can burn that when complete.
Its real simple I do it all the time even though I have the br-1180cd the cd burner burns real quiet so I don't use it. The cable can be bought at radio shack, best buy, wal-mart and I have even seen them at 99 cent only stores.
If you have more question let me know This Is my main unit so I know a lot about it.
Sincerely,
Michael Scott
Apr 29, 2009 | Boss Micro BR Digital Recorder
Roland BR900CD Digital Multitrack Recorder Logo
74 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
