Question about Dishwashers
I have a Kitchenaid Dishwasher Model KUDS01DLSS0, Serial No. FM4005048. The problem I have is that the timer gets down to 60 and stays there and does not finish the cycle. Is it the timer that needs replacing? Thanks!
jsrock516
  • 5911 Answers
SOURCE: Dishwasher wont finish cycle
I have experienced this problem before and it turned out to be the main control board in the console. Not a cheap fix, either. The control boards are not serviceable, and can run over $100. Sorry, I hope I was of some help.
Posted on Jul 10, 2007
dutchman05
  • 487 Answers
SOURCE: dishwasher doesn't drain completely at
filter or pump are obstructed. Clear out both and it will run. If not you pump is broken
Posted on Apr 26, 2008
  • 172 Answers
SOURCE: KitchenAid Dishwasher
Nick,
It sounds like you have tried all the normal things for this. It is possible that you have a stuck key on the panel. Try pressing all the buttons several times to see if they may be stuck. It may just pop it loose. If that does not work you may need to try kicking the breaker off overnight. If that does not work you may need the electronic control. Lots of luck to you. Mike
Posted on May 07, 2008
  • 172 Answers
SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Posted on Oct 30, 2008
  • 3 Answers
SOURCE: My normal cycle and cancel button lights are
Probably a keypad gone bad. Try replacing the keypad.
There is a troubleshooting guide behind the foot kick panel. It gives a sequence to test for a bad keypad. You can try that sequence to be sure.
Posted on Apr 27, 2009
Broken Timer? My OLD Kitchen Aid Quiet Scrub Dishwasher no longer advances through cycles automatically--I have to turn the knob manually for every step. It works fine other than that.
Hi Spring
All depends where you are and wether you can get Parts.
Is the timer accessible?
Timer is driven by a small clock motor.
Could it be fixed or lubricated.
Give it a service and save money!
Good luck
Free Online KITCHENAID DISHWASHER Repair Manual
http://www.diytroubleshooting.com/kitchenaid-dishwasher-troubleshooting
Jul 08, 2015 | KitchenAid Dishwashers
My kitchenaid DW kudc101xwho will not stay on. Runs a few min and shuts off. Is this the control panel or the timer?
May be this is the reasons.
a) May be your door latch is opening due to pressure inside the dishwasher. The door latch opens and the dishwasher will stop. Quite common problem on KITCHENAID. KitchenAid door is a heavier door compared to sister product WHIRLPOOL. If door latch problem then has to change the door lock along with the top latch.
Sep 25, 2014 | KitchenAid Dishwashers
Kitchenaid Dishwasher trips the 60-amp main breaker but not 20-amp.
Its possible that there may be load on that circuit from other appliances. Had an issue myself with stove and laptop on same circuit.
Check other appliance attached to the 60amp circuit (microwave, stove, kettle etc)
May 13, 2012 | Electrical Supplies
Blown fuses
Hi
You can get the manual for your kitchenaid dishwasher from this link---
Kitchenaid Kuds01dlss Dishwasher Manual
Please post back for any further assistance.
Daniel
Jul 22, 2010 | KitchenAid 24 in. KUDS01DLSS Built-in...
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140, THE DISHWASHER IS NOT RESPONDING TO ANY COMMANDS, THE RINSE LIGHT IS BLINKING AND THAT...
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140. The unit is not drying the dishes?
Oct 02, 2009 | KitchenAid Dishwashers
Kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Sep 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Cycle Sticks unless I manually move it along
Ya, the mechanical timer/dial is the problem. The heating element just got stuck on as the timer stalled in that dry cycle.
May 03, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
62 people viewed this question
Top Dishwashers Experts
