Question about Garden
Hello my husqvarna 137 chainsaw wont start at all what should i do? it has fuel and oil but still wont start
  • 2,239 Answers
Start with basic things first, drain the fuel tank and re fill with fresh fuel, remove the spark plug, is it soaked with fuel? if so dry it , put the ignition unit to off, with the plug still out crank the engine a number of times to remove any excess fuel in the bore, check there is a spark at the plug, if yes leave the saw to dry out for a couple of hours, refit the plug and try again, remember to switch the ignition on
Posted on Apr 05, 2011
Were is the fuel filter on a husqvarna 142 at
Its in the gas tank, also check for dry rotted gas line.
Oct 02, 2014 | Husqvarna 141 142 136 137 Cylinder Piston...
Fuel mix
The oil ratio is 50:1
Here is the website: http://homeguides.sfgate.com/oil-fuel-mixture-farm-tough-husqvarna-chainsaw-83933.html What Is the Oil Fuel Mixture for Farm Tough Husqvarna Chainsaw
Aug 19, 2014 | Husqvarna Chain Saw Handle Models 362 365...
What is the fuel & oil mix for a chain saw
Husqvarna chainsaws run at a 50-1 fuel oil mix with Husqvarna two stroke oil, with other two stroke oils they recommend 25-1 fuel oil mix as they do not know the quaility of other manufacturers oil, always try to use Husqvarna oil.
Sep 25, 2011 | Husqvarna Chain Saw 20" Bar
Fuel mixture for a Husqyarna E-series 137, mod/137802010
The mixture should be 50-1 with Husqvarna rwo stroke oil, it is recommended that you use a mixture of 25-1 with other brands of two stroke oil, this is because they do not know the quaility of other brands, always try to find genuine Husqvarna oil.
Aug 27, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a husqvarna 137 chainsaw. The problem is with the bar oil. When the saw runs oil is flowing but where the rubber corner piece which allows the oil to flow out of appears to be just dripping the...
Hi marcus,
The bar and chain oil goes into the oil tank on the side. The oil for the engine is mixed with the gas before filling the gas tank.
Hope that helps.
Handy Andie
Mar 20, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna 137 E series chainsaw wont start.
Back to basics, drain the fuel in the tank and refill with fresh, make sure the ignition switch is on, check for a spark at the plug, does the plug get wet after cranking engine, remove the muffler and check for any piston damage through the exhaust port, let us know your findings.
Jan 07, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 350 has spark and fuel wont start just quit running while in use
1- Is the mix (gas & oil) right? If its 2-cycle,check the manual.
2- Is the choke set?
hope this helps
Jan 06, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
How do you start a husqvarna 137 e series chain saw
Hello Sally;
A link to an OM for a Husqvarna 2005 137 (no e listed, the procedure is the same) can be found here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2005/HOUS2005_O0501001.pdf
The start procedure begins on page 9.
The part that says once it attempts to start open the choke is often overlooked and they flood.
This is the only 137 listed, normally there are many to choose from. If you need additional help Husqvarna can be contacted here:
http://www.husqvarna.com/us/homeowner/support/customer-support/)
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Aug 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What is fuel oil mix for the 136
Page 8 of your manual says 40:1 (3.2oz/1gal) Stihl or Husqvarna 2 cycle oil.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 3 months old use up in a 4 cycle engine. HTH
Lou
Oct 30, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
137 stalls
Sounds like an air leak somewhere. Or possible a clogged fuel filter.
Mar 14, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
140 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
