Question about Garden
I am looking for a repair manual for a Rover 200ES Xl lawn mower. In particular repair of the pull cord mechanism.
SOURCE: Black & Decker Lawn Hog 19" Mulcing Mower MM875 won't start
The rectifier is a flat plate with 4 posts that attach the electric wiring inside. You will need a flathead screwdriver to remove the four screws holding down the cover on your mower. on top where all the wires run (you will probably see one burned) There is a screw in the middle holding down the plate, you will need to replace the plate and resplice the wires that may be burned.
Posted on Jun 28, 2009
huffman49
  • 235 Answers
SOURCE: cant get my mountfield lawn mower started, it is
make sure there is a spark plug in. that would be 1 reason why there is no resistance when you pull the cord. if there is a spark plug in then check to see if there is a clunking sound when you pull the cord if this is the case then the engine has a broken conecting rod..good luck
Posted on Apr 07, 2010
  • 2468 Answers
SOURCE: CHAMPION VANTAGE 35 PETROL LAWN MOWER
the recoil dawgs in the cover housing are either shot or not engaging into the top starter cone
Posted on Apr 14, 2010
  • 150 Answers
SOURCE: pull cord wont retract on
Sounds like a spring problem. Remove starter shroud, try pulling it and see if it works. If the spring isn't broke you may have to take another rap on the rope to gain more tension, or spray mechanism with some wd to free it up.
Posted on Sep 28, 2010
aquaman987
  • 927 Answers
SOURCE: How to I replace the
Remove the recoil assembly from the mower, there are 3 machine screws.
Remove the old rope and get matching cord, make sure you get the correct diameter, usually 3/16 or 1/4 inch, and type, I believe it should be nylon braided. Do not cut the new cord.
Use a match to light the end of the cord and once it ignites, use an old rag to pull and form the end into a point.
Notice which way the pulley in the starter assembly rotates and hand spin it in that direction until it is fairly tight. Once it is tight, rotate it into a position such that you can push the pointed end of the cord from the outside into the hole in the housing of the starter and directly into the hole on the inner pulley. Tie a tight knot in the end of the rope inside the pulley.
Remove the clamp and let the rope get rewound on the pulley. Cut the cord, point this end and run it into the handle and knot it.
Gary
Posted on Dec 19, 2010
Can't find battery on my lawn mower.
Probably under the seat. Look in the manual. Follow the wiring coming from the ignition (key). I assume this is a lawn tractor. If it's a push mower, naturally if you have to pull a cord to crank it it has no battery.
Feb 12, 2017 | Garden
Looking for Coleman modelPM0545305 repair manual
You might try Amazon.com. Enter your model number and "repair manual" . Good luck.
Nov 20, 2015 | Garden
Repair lawn mower pull cord
Home Depot sells a replacement pull cord kit that has great instructions. My mower, however, had pop rivets holding the cover on the engine, so if yours does too, get a pop rivet tool with the correct size pop rivets before you start drilling out the old pop rivets.
Aug 07, 2014 | Mtd 22" Yard Machine Push Mower
How to fix Mower cord stuck after hitting rock?
Pull the plug. MAKE SURE THE PLUG IS COMPLETLY REMOVED AND SEPARATED FROM THE MOWER!! Remove the cover with the pull start attached. see if you can turn it by the flywheel or the blade. If you can, you can just have the rewind repaired.
If not, then you have a probable bent or twisted crankshaft. Most likely not worth repair.
May 16, 2014 | Electric Lawn Mower
How do i start a rover 03026S
is there a prima at the front of the air filter if there is push it in 5 times then put throttle flat out ond pullcord,if dosnt have prima put throttle to choke pull cord and when starts pull throttle off choke,if dosnt start after five pulls take off choke and try starting again
Feb 04, 2013 | Garden
Apr 14, 2010 | Garden
Starting issues. Can't pull cord.
Make sure your flywheel brake is not engaged or the cover is hindering the mechanism somehow after it is installed
May 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
The string that you pull to start the mower has snapped. How can I replace it or where.
You can buy a new cord from a mower repair shop. The pull- starting assembly needs to be removed and the new cord installed. A repair shop can easily do this. You can do it, too, if you have reasonable experience with mechanical repairs.
May 04, 2009 | Garden
Cannot pull the cord more than 6 inches to start Toro lawn mower.
Hi Patti, If you can not pull the cord more that what you said, try removing the spark plug and see if that makes a difference, if not, leave the spark plug out to prevent accidental starting, raise up the front of the mower and see if you can turn the blade if not...it only gets worse from there. If you can't turn the blade from under the mower, the engine is more that likely seized up, sorry
Apr 25, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
255 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
