Question about Bosch HGS3052U Gas Kitchen Range
I just converted from NG to LP on a HGS345UC DF the top works good the broiler runs OK also, However the oven has a heat shield over the lower burner with a large slot on both sides, When the oven runs a 2 " high gas flame is visible on both sides is this normal ?
  • 122 Answers
The oven orifice hasn't been tightened all the way down. sometimes it feels like it is down and tight so you need to look at the orifice and see if it's all the way down. if not tighten it some more.
Posted on Apr 05, 2011
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
I got a GE gas range (model JGBS22) from a co-worker. She had converted it from gas to propane. I just had a plumber hook it up to natural gas but, even with the conversion manual, he couldn't change the...
There should be a set of orifices for each burner as well as the oven and broiler. When the unit was converted to propane, these orifices should have been replaced and the ones for gas put in with the conversion kit installation information. The kit should have been reattached near the pressure regulator.
If the kit was missing the orifices, then, yes, you are missing pieces. Check with your coworker if the conversion kit was missing. If you have the kit, it can be easily done by any appliance installer (or repair person) licensed for handling NG. (At least on our range, the conversion kit installation was straight forward. Every orifice was clearly labeled with the labels different for each burner and for the gas/LP kits (ABCD (NG) vs MNOP (LP)) .) The regulator is the only part that switched for LP or NG without the kit.
As I recall, the only tools we needed for the top burners were a small wrench (10 mm) and a small flat blade screwdriver. Remove one orifice and put in the appropriate replacement. Then adjust the burners so that they didn't blow out when the oven was opened or quickly turned from high to low (for the simmer burner). The oven and broiler took a bit longer. Several screws had to be removed to get at the orifices. Then the air flow had to be adjusted for the incoming gas.
I hope this helps.
(the conversion installation manual was on the counter during installation; I read it while it was open.)
Jan 14, 2011 | GE JGBS22 Gas Kitchen Range
Need to convert from lp to ng on a kenmore 362.7556191
conversion should be done by a qualified tech. you need ng orifices to replace the top lp orifices on top burners, you need to turn top of regulator over to ng, this is located behind bottom door and you need to adjust your orifices in your oven burner back up, should be screwed complerely down now and same for broiler also air adjustment may be needed. do not recommend you try this yourself
Feb 05, 2010 | Kitchen Ranges
The oven and broiler work but the broiler flames up like its not getting enough air. the flame burns yellow
you may be correct with the air? is it LP or NG? air adjustment correspond with type of gas also the brass orifice you see going into the burner may be in need of ajustment, if its LP its needs to be screwed all way back even if it seems tight, screw it out away from burner ( clockwise) if NG then it's oppisite. hope this helps
Feb 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
2002 GE XL44 converting from LP to Nat Gas
the jet sizes will have to be changed due to the weights of different gasses
Jan 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Convert Kenmore 790 from LP to Natural
The conversion manual that came with my 790 specifies 2.5 turns (approximately) from the LP setting to the NG setting.
Dec 29, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Dec 20, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Upper & Lower Broiler Flame Adjustment
MY KENMORE OVEN BURNER FLAME IS TO HIGH AND IT WILL NOT TURN LOW
Jul 16, 2008 | Ovens
Bosch HGS3052U Gas Kitchen Range Logo
163 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
