Question about Motorola Mobility H700 Wireless Headset
Can't pair my h715 Bluetooth headset with my 4GS iPhone, though it is "discovered" by it.
  • 794 Answers
Hi hyacinth29,
What is the PIN that you used in pairing? The pairing code should be "0000" (these are zeros). You may want to try pairing your bluetooth headset again to your iPhone 4G.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 06, 2011
Can't get my iPhone to Pair with new Jensen SMPS-650
Hold botton down until it flashes blue AND then red it will continue To flash now pair ur headset
Dec 09, 2012 | Jensen Bluetooth Wireless Stereo Speaker...
My bluetooth isnt synced to my phone and it isnt. how do i restart the process so that it syncs to my phone??
I have the H715 but my iPhone only showed the H721 instead of the H715. I selected the H721, entered the passcode and connected. Called my home phone with the earpiece in and it works.
From user guide and other user comments...
Make sure the H7xx is fully charged up (not necessary but you'll probably begin to immediately use it and it would be bad to have it discon because the battery is dead). Turn off the H7xx (the ring around the talk button should not be flashing blue every few seconds), push the talk button, thats the oval button on the face of the headset, for about five seconds, until the ring around it displays a purple color. Immediately let go of the button and flip open the tiny microphone extension. Now it's in pairing mode and you can leave it while you fiddle with the iPhone.
From the iPhone main menu, select the "Settings" button, then in the Settings menu, select the "General" option.
Touch the "Bluetooth" menu item on the General menu. when the next screen appears, if your Bluetooth is already turned on it will start looking for (discovering) your H7xx. If Bluetooth is not turned on, slide the gray button so it displays "on" instead of "off". Your iPhone should now start discovering your H7xx. It should automatically find your H7xx, then display another screen that prompts you for a code. According to the manufacturer's guidelines, the H7xx requires you put in "0000" that is 4 (four) Zeros as the code.
If everything went well, the "Bluetooth" screen should be displayed again and the Motorola H7xx should show up under the word "Devices" showing that it is Paired.
Your H7xx should now also blink Blue around the talk button.
If things didn't go well. I suggest navigating back to the bluetooth menu. Turning bluetooth off on the iPhone. Flipping closed the microphone boom on the H7xx and starting over again. I had to do it twice because I fumble fingered the 4 zeros.
NOTE: it is not necessary to have the H7xx right on top of the iPhone, but I'd have it within an arms reach, just to be sure you get a good signal and you actually pair to your Bluetooth headset.
Once the iPhone has discovered the H7xx if it continues to state "Not Paired" simply tap the Motorola H7xx box and it will take you to the next screen. Enter "0000" as the security code. The iPhone should now successfully pair with the H7xx.
Apr 01, 2011 | Motorola Mobility H700 Wireless Headset
Iphone 3GS not pairing to plantronics voyager 520
Without turning the headset on, turn the bluetooth on for the phone. Select the headset that is paired, and select Unpair. Then turn bluetooth off. Put the headset into the "discover" mode, by holding down the power button until the light flashes red and blue. Then turn the bluetooth on for the phone, and it should "discover" it. It should ask for the passcode, normally 0000. Once you enter that, it should pair. After that, you should be alright. You can turn the headset off and back on again and it should connect right away.
Hope this helps.
otherwise try this : http://www.plantronics.com/media/media_resources/easytopair/
Jan 12, 2011 | Apple iPhone 3GS Black (16 GB)
I just had to purchase a replacement iphone. Tried to pair it with my Motorola H715 earpiece and it will not recognize my pin #
Which PIN have you tried? You see, the pairing code for this headset is hardcoded to '0000' (four zeros).
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Sep 28, 2010 | Motorola Mobility H710 Bluetooth Headset
Motorola h715 bluetooth pin number
Try '0000' (four zeros), which is the code chosen by the vast majority of bluetooth devices' manufactures.
I was able to find the user guide for the H710 headset, but unfortunately not for the H715. It's here, anyway. Hope you find it useful, somehow.
Cheers! Carlos
Apr 18, 2010 | Motorola Mobility H710 Bluetooth Headset
How to pair with iphone
Hello
1.From the main home screen of the iphone open "SETTINGS".
2.From the setting menu go to "GENERAL".
3.From General go to "BLUETOOTH".
4.In the Bluetooth menu you will see an on/off switch. Make sure you turn the switch to "ON".
5.From here you want to go to your bluetooth headset. Hold the on button for about 5-10 seconds until the light starts blinking. Once light is blinking go back to iphone.
6.In the Bluetooth menu (same as step 4) your iphone should have discovered your bluetooth headset. However if it is not paired yet. Open the headset menu.
7.In the headset menu you are required to enter the appropriate PIN number (which should be given inside your bluetooth headset instruction manual).
8.After you have entered the correct PIN number press connect.
9.From here your Bluetooth Headset should be connected and ready to use.
NOTE:Fully charge your bluetooth headset before syncing it to your iphone
Goodluck
Apr 16, 2010 | Samsung WEP410 Bluetooth Headset Wireless...
I can't sync my motorola H715 bluetooth head set with my Iphone 3GS, can you help
Jul 06, 2009 | Motorola Mobility H700 Wireless Headset
My iphone is not discovering my blue tooth head set, why?
Make sure the bluetooth headset and the iPhone are both in pairing mode. Set the headset in pairing mode first and once set then go and turn on the iPhone bluetooth. It may take about 30 seconds to a minute for it to find the headset. Once the iPhone has found the headset make sure you select it on the phone and it will pair from there - Hope this Helps!!
Jun 08, 2009 | Apple iPhone Smartphone
Lost headset manual & code
it is universal procedure to pair up all devices like this
first if ur hedset is switched on switch it OFF by long pressing the main button in the centre it will blink blue light twice or thrice and will switch OFF after that u can touch any button it will not respond with blinking lights
Now press again that centre main button long press for like 10 sec until that blue light comes on and become STABLE when it is stable it means it is ready to pair up with any bluetooth phone now go to ur phone switch the bluetooth ON and select search u will find ur headset with its model like H715 just select and when asked for pairing code enter 0000 Zero four times or try 8888 if it doesnt work , now u will see that ur headset light will start blinking and u will see a headset sign on the screen of ur mobile phone it means now it is paired up
now u can try to talk thru headset make a test call any number for voulume control there are two buttons on headset on upper sie with arrows u can select them to increase headset sound
pls rate me well for help ! Fixya rating is encouraging !
Apr 25, 2009 | Motorola Mobility H710 Bluetooth Headset
My iPhone 3G does not discover my Motorola H500.
Try this link. It solved my issue www.scribd.com/doc/280088/motorola-h500-bluetooth-earpiece-manual. Basically what you need to do is power the earpiece off. Make sure that your IPhone is not currently attempting to discover bluetooth devices (i.e. Bluetooth is OFF). Hold the On button on your earpiece (it has the symbol of a phone on it) for 6-10 seconds. The light on the earpiece remains lit. Now your earpiece is in discovery mode. On your IPhone, go to Settings, General, Bluetooth. Turn Bluetooth ON. Now your phone and your earpiece are both in discovery mode. When you see "Headset" listed, select it and enter the password "0000". Your IPhone is now paired with your H500 headset.
Mar 24, 2009 | Motorola Mobility H500 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
149 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
