Question about Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White
I am replacing the pull out hose with a danco universal hose which having trouble on how to connect and which adapters do i use
Hose/ Adapters for older Maytag Portable Dishwasher
The sink faucet may have to be modified by installing an adapter.
Jun 22, 2017 | Maytag Dishwashers
Need to replace rubber on Grohe Ladylux Plus Pull out spray handle. How to get spray handle apart.
I bought DANCO "universal faucet pull-out spray hose - fits all facuet brands" from Lowe's, which came with all kind of adapter and the hose quality seems to be better than overpriced Grohe spray hose replacement (Grohe part # 46092). The only problem is that you may have to prepare a large rubber washer in order to the handspray (Grohe part#46298) as I don't see this large washer in the package but it is very important to fit in place to prevent water leakage. - Michael
Jan 13, 2012 | Plumbing
I have a danco spray head, it broke at the pullout part where the head connects to the hose. the base of the spray head is stuck in the hose, the threaded part and i can't get it out
no one can get it out, sad as it is you just might as well contact Danco and see what they will want to send yu a new handle and hose.
They might do it for free. Most companies are doing that today in order to keep people in the product.
Thanks for using FIXYA to help you out
Tom
Sep 06, 2011 | Plumbing
Re: danco universal tub spout I cannot get the white plastic insert (with O ring) to fit over my half inch copper pipe. I have used sandpaper to shine it up, but it appears to be way off. and tapers too...
Apply heat proof plumbers grease on the copper shaft and o ring. Be sure end of copper pipe is reemed. Line it up and apply pressure firmly and twist gently back and forth until it slides on.
Apr 23, 2011 | Danco Home
The handle on my outdoor faucet is broken. I
Have you checked with a plumbing supply hose if it is a square slot you may could use a handle off a boiler drain for a washing machine .
Check it out if it is a metal red or blue metal it may be the same type used on your washing machine cut off valve
Apr 26, 2010 | Danco Clear Faucet Decorator Handles
DANCO brand generic hose not connecting to supply
You have to buy a Genuine Delta Part because Delta uses a proprietary quck connect fitting at the end of the hose.
May 28, 2009 | Delta Faucet 470-DST Signature Diamond...
Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White Logo
373 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
bwbconstruct
Level 1 Expert
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
