Question about Cycling
Specialised rockhopper bike. Loose front forks onto frame. How to tighten. When front brake applied, whole front fork moves 1-2 inches...
    Novelist:
  • 151 Answers
I believe this bike has a sealed cartridge bearing and cannot be tightened. a replacement should probably be bought.
Hope this helps.
Posted on Apr 05, 2011
98 W/Glide forks out of alignment how do I straighten them?
Hi, Max if your front forks are only twisted and not bent they can be realigned, start by jacking the bike up so the front wheel is off the ground; a half-inch or so will do it.
If the forks have been removed from the bike:
1. Set the fork height in the upper clamp, and then tighten the pinch bolts in 3 equal stages to the proper torque. If you're not convinced that the heights are equal, slip the axle into place. If it doesn't glide smoothly through the forks, one leg is higher than the other, so readjust them until the axle slides through them with little or no effort.
2. Install the front fender but don't tighten the bolts.
3. Install the front wheel and axle. If the axle threads into the fork, thread it in loosely, if it uses a nut, just snug the nut down by hand. Do not tighten the axle pinch bolts.
4. Spin the wheel as fast as you can and abruptly pull on the brake lever. Holding the brake lever on, tighten the front axle.
5. Lower the bike onto the ground, and, while holding the front brake, gently pump the forks a few times. You did remember to tighten those upper pinch bolts, didn't you?
6. Tighten the lower clamp's pinch bolts in 3 equal stages, followed by the axle pinch bolts to the proper torque.
7. Tighten and torque the fender bolts.
If you suspect the forks are tweaked but don't want to go through the procedure above there is an easier way.
A. Support the weight of the bike on the jack or center stand, and loosen the front axle.
B. Remove the lock nut, and then try to slide the axle out of the fork. If it comes away with little effort, the forks are in alignment. If the axle has to be pounded out, it's a safe bet the forks are slightly tweaked or rusted.
C. To correct a slight misalignment, loosen everything but the top clamp pinch bolts (you don't have to remove anything), and start at Step #3. Anytime the wheel is removed, perform steps #4 and #5: that'll center the wheel in the fork and provide better suspension and braking action.
If your forks are aligned but your handlebars are twisted start by loosening the handlebar clamp bolts, then in a criss-cross pattern tighten the bolts in 3 equal stages to the proper torque. You will see that tightening a specific corner pulls the handle bar in a specific direction you can loosen and tighten the bolts on one clamp to achieve proper eyeball alignment, it may take a few attempts to get the desired results.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Harley Davidson Manuals Mark Workshop
http://partsfinder.onlinemicrofiche.com/stcharlesharleydavidson/showmodel.asp?make=hdmc
https://serviceinfo.harley-davidson.com/sip/vehicle/lookupForm
Instant Tech Relief A must have !!! Absolutely Totally "FREE"
Nov 01, 2016 | Harley Davidson FXDWG Dyna Wide Glide...
What is the front wheel spacer placement on 2005 flht
Install or place the wheel into position between the forks with the valve stem on the right side of the vehicle. THEN coat the axle with bearing grease. THEN while supporting the wheel, insert the threaded end of the axle through the right fork leg and push it through the fork, the short external spacer and the wheel hub until it begins to emerge from the left side. THEN with the three notches on the bearing side, push the axle through the long external spacer and the left fork leg until the axle shoulder contacts the external spacer on the right fork side. THEN install the flat washer, lock washer and axle nut. THEN insert a screwdriver or a steel rod through the hole in the axle on the right side of the motorcycle AND THEN while holding axle stationary tighten the axle nut to 50-55 ft-lbs (68-75 Nm). THEN insert a 7/16 inch drill bit into the hole in the axle and pull the fork leg so that it just contacts the drill bit, and then tighten the axle holder nuts to 132-180 in-lbs or (14.9-20.3 Nm). THEN remove the drill bit from the axle hole. THEN install the brake caliper tightening the mounting bolts to 28-38 ft-lbs or (37.9-51.5 Nm). THEN BEFORE moving the motorcycle, pump the front brake hand lever until the caliper pistons push the pads against the brake discs because if the pads have not been hydraulically pushed out against the brake disk the brakes will not work when they are first attempted to be applied. SO, depress front brake hand lever several times to set the brake pads to the proper operating position within caliper before you attempt to move or ride the motorcycle.
Aug 05, 2014 | 2000 Harley Davidson FLHTCUI Electra Glide...
How to replace fork seals 2007 fatboy
To replace the front fork oil first support the motorcycle so the front end is off the floor and the forks are fully extended. Remember that the FLSTC and FLSTF models have a preloaded fork spring and that the fork tube plug is under spring pressure.Then you remove the fork tube caps. And then you drain the fork oil. ON FXSTD models, your remove the drain screws and washers from each fork and drain the fork oil this way. ON ALL MODELS EXCEPT the FXSTD, remove and discard the drain screws and washers from each fork and drain the fork oil and then you install new drain screws and washers. ON FXSTD models, apply LOCTITE THREADLOCKER 243 (blue) to the drain screws and tighten them to 12-18 inlbs (1.4-2.0 Nm). ON ALL MODELS EXCEPT FXSTD, tighten the drain screws to 52-78 in-lbs (5.9-8.9 Nm).THEN fill the fork with Harley-Davidson TYPE E FORK OIL (Part No. HD-99884-80).Either by installing oz or cc's of fluid if the forks were left in the frame or by measuring the amount of oil in the tubes in inches or mm if the forks were removed from the frame and disassembled. In the latter case the oil level is measured from the top of the fork tube with the spring removed and the fork fully compressed.
MODELs FLSTC, FLSTN use 13.4 OZ 395 cc4.41 inches 112.0 mm
MODEL FLSTF uses 13.4 OZ 397 cc5.04 inches128.0 mm
MODELs FXST, FXSTB, FXSTC use 12.5 OZ370 cc 6.69 inches170.0 mm
MODEL FXSTD uses 11.6 OZ343 cc 7.48 inches190.0 mm
FINALLY tighten the fork tube caps to 40-60 ft-lbs (54.2-81.3 Nm).
Jul 10, 2014 | 1993 Harley Davidson FLSTF Fat boy
Replace front wheel
Hi Anonymous, start by jacking up the front end of the bike until the front wheel is about 6 inches off the ground. Have an assistant hold the handle bars and steady the bike during this procedure. Safely with wood block the frame and front wheel, let the jack down until all the weight is on the blocks. Remove calipers from fork leg brackets and let hang or use bungie cords to hold them out of the way, do not pull in brake lever while calipers are off. Remove axle nut and washers, loosen right fork slider axle cap nuts and with a long screw driver or drift take a mallet and bang out axle from left to right. Remove block under wheel then remove the wheel. Replace in reverse order, tighten slider cap nuts then axle nut to 50-55 ft lbs. Loosen slider cap nuts to allow right fork to find its center then retighten cap nuts to 15 ft lbs. of torque. Re-install calipers and torque bolts to 28-38 ft lbs. Jack up bike remove blocks, pump front brake lever and your good to go. Good luck
Apr 22, 2014 | 2001 Harley Davidson FLHTCUI Electra Glide...
Adjust tension on wishbone rear
For a 2004 Softail - you never gave a model year.
1. Place rear fork (3) in the frame so that
the bores in the frame align with the bores in the fork.
Insert the bushings (10) into the spherical bearings (7)
from the inside.
2. Install pivot shaft.
a. Apply LOCTITE ANTI-SEIZE to pivot shaft (4).
b. From the right side, install pivot shaft and spacers
with spacer collars facing transmission case.
c. Apply LOCTITE THREADLOCKER 262 (red) to
threads of pivot shaft nut. Install and tighten pivot
shaft nut to 90-110 ft-lbs (122-149.1 Nm).
NOTE
Proper pivot shaft tightening is important to maintain rear fork
alignment.
3. Check for freedom of rotation of the rear fork around the
bearings and that the fork and frame side members have
not been distorted when the pivot shaft nut was tightened.
4. Install the canister (California models),
fender extension (2), brake caliper and rear wheel.
5. Install both rear shock absorbers (9) using bolts and
washers (8).
Aug 31, 2013 | Harley Davidson FLSTC Heritage Softail...
How do i tighten the fork/handle bars on a genesis v2100
where the handlebar goes into the frame, there is a nut that goes around the gooseneck loosen that, and below that is a bearing race that you tighten by hand ( it has a knurled edge) tighten that by hand...just enough so there is no play, and then retighten the locknut
Jul 26, 2013 | Genesis 26 Inch V2100 Dual-Suspension...
I just bought a Schwinn Discovery and the front fork is loose in the frame. When I hit the brakes, the fork rocks back and forth. I am not sure how to tighten it up?
If you bouht it from a Bike Shop, make them do it. And complain.
If you bought it at a box store don't bother, they're incompetent.
http://www.parktool.com/blog/repair-help/threadless-headset-service
Scroll down to Headset Assembly
Remember, the side bolts on the stem loosen it so adjustment can be made with the top cap bolt. You tighten the side bolts to lock in that adjustment. The top cap bolt is only for MAKING the adjustment, not KEEPING it.
Mar 21, 2011 | Schwinn 405 Full Suspension Mountain Bike...
How do I put front wheel on without making the forks lock up it keeps doing that when I put it on my02 cr250
Putting uneven loading on the forks(twist) may cause binding and harsh action but I haven't heard of them locking up. Try the following order of installation. position the wheel and slide in the axel. Tighten the axel, leaving the pinch nuts loose. Spin the tire and stop it a few times using the front brake. Tighten the pinch nuts. Put bike on the ground and see if forks still bind. If they do then loosen the pinch bolts, lock the front brake and try to compress the forks. This should align the forks. Tighten the pinch bolts. Check forks again. If you still have problems someting is wrong like bent fork tube or slider, misaligned triple clamp, maybe a bent axel.You might take off the fork tubes and push on them seperately to make sure they feel ok. Then do the install checking the forks at each step to find the place where binding starts. Good luck.
Feb 20, 2011 | 2002 Honda CR 250 R
I have a 26" Huffy men's mountain bike with shocks on the front forks. When ever I apply the front brakes the bike shakes badly and the front forks flex forward and backward rapidly. I couldn't see any...
Sounds like you have brake chatter. You need to "toe in" your pads on the front brake. Most new brake assemblies have a wedge shaped washer between the pad holder and where it mounts. If you loosen the nut that that holds the pad holder to the assembly and turn the washer you can see the relationship betwween the pad and the rim change. Turn the washer so the pad is toed in slightly(the end towards the front of the bike). If your brakes don't have the shaped washer you can put a crescent wrench on the brake arm and CAREFULLY tweak the toe in. Be gentle and good luck!
Oct 06, 2010 | Huffy Men Mountain Bike (26")
I cant the handlebars to turnh the wheel doesnt seem to grasp am i missing a part
Tighten the 7/16 inch bolt that goes down into the neck where the front wheel attaches to the frame.
Jun 26, 2010 | Huffy 26 in. Cranbrook Cruiser Bike
Cycling Logo
95 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
