Question about Refrigerators
Door seal on hotpoint fridge cracked. Have obtained new door seal C00282948, but cannot work out how to attach to fridge door. Please can you help?
  • 3,740 Answers
If you lay the gasket flat on the floor with the side that mates to the chassis of the compartment... you will note that there appears to be a split on the inside of the gasket.
On the OLD gasket you loosen all of the screws by gripping the gasket and rolling it until the mounting screws are exposed. Just loosen the mounting screws as you go and pull to old gasket off starting on the bottom and working your way up both sides until you finish to center. DO NOT remove any of the screws unless you have no other choice. If your removed them to begin with... reinstall all the screws and mounting plates VERY loosely before attempting to install the new gasket.
When you install the NEW gasket.... hang the gasket under the TOP mounting plate by separating / rolling the NEW gasket until you can slide it into place. Once you get about 12 inches in place on both sides from center TIGHTEN the top center mounting screw so the gasket does not keep falling out of place. Align the rest of the top of the gasket to both TOP corners. Make sure it is centered and the corners match. Then work your way down each side to each of the corners. Tighten a few screws until they are just snug to hold the gasket in place. Then align the bottom with the gasket mouting plate and push the gasket into place under the mouting plate. Center the gasket and tighten the center bottom screw and one screw on each corner.
Now go back and tighten all the rest of the screws by rolling the gasket back to expose the screws. You do not have really tighten the screws super tight. Only tighten them until it grips the mouting plate firmly against the gasket. It is best to work from a center point to the corners on each side of the gasket so the mounting plates do not warp when doing the final tightening process.
Should your model NOT have the mounting screws and plates it is a matter of aligning the part of the gasket that locks over the lip on the door. (See video)
Hopefully my "How to" steps are understandable to you.
If not the 2 min 30 second video below should help you. (not your model but the concept is the same) Pay particular attention to the steps at the 1:27 mark of the video.
Thanks for choosing FixYa, Kelly
Posted on Apr 05, 2011
How do I replace the front door rubber gasket and seal ring?
Greg, new seal but need to know how to swap it out. Check the attached links,instruction and guides, If you want to google your make and model Washing Machine door seal replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Replace Washing Machine Door Seal
How to replace washing machine door seal on Hotpoint washer
http://www.how-to-repair.com/help/how-to-replace-whirlpool-washing-machine-door-seal
How To Replace Front Load Washer Door Boot DIY
Jul 25, 2016 | Washing Machines
Refrigerator door suction
Double check all shelves and drawers make sure they are all pushed back and nothing stuck behind them. If food is hanging over the edge of the shelf that would prevent your door from closing correct. If you check these and still have issues you need a new gasket
Aug 10, 2013 | Refrigerators
Kenmore elite refrigerator is not cooling, but the freezer seems to be working fine.
Kenmore Elite refrigerators come in several styles, including units with a freezer at the top and units with freezers at the bottom. The top and bottom of the fridge work on different systems. Sometimes the freezer may function perfectly, while the fridge performs poorly. Most issues with the fridge cooling are due to incorrect settings or poor cleaning practices. Checking common problems with the refrigerator will help you diagnose the situation and keep expensive repairs to a minimum
1. Check that the Kenmore Elite refrigerator is plugged in. Inspect the circuit breaker of the home if the refrigerator is plugged in but not running.
2. Pull the unit out from the wall and vacuum the condenser coils at the back of the unit.
3. Turn the temperature control in the Kenmore Elite refrigerator to the "On" position.
4. Turn up the temperature on the temperature control, located inside the unit on the wall.
5. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the Kenmore Elite fridge door.
6. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the fridge door.
7. Move food away from the vents inside the Kenmore Elite refrigerator.
I hope i solve you problem.
Have a nice day : )
Sep 04, 2011 | Refrigerators
I need to replace the rubber seal on my Hotpoint ice diamond freezer door I can't find any fixing screws on the inner door panel can I assume then that the panel clips on.
Me too, I have a Hotpoint Iced Diamond Under counter fridge that needs a new seal and i also cant see any fixings to remove it. I did read somewhere that you can't replace them you need to buy a complete new door.
Dec 14, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Needs a new door seal the seal now on the washing machine is leaking
Hi.
You need Hotpoint part number: 1605550.
if having problems obtaining one please call me on 01733 307019
aardvark repairs
Nov 24, 2009 | Hotpoint Ultima WF860 Front Load Washer
No model number on fridge
Open the door, crouch down, then look up - it's under the top on the left
Oct 18, 2009 | Refrigerators
Outside of fridge door turns brown in color with high humidity
Check your door seals or for cracks in plastic shelves. Sounds like condensation getting to metal causing rust.
Jul 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
Condensation problem hotpoint mistral 8596
if the door seals are both ok, check and see if she has any open containers in the fridge juice ect that may be allowing moisture to escape. a model number and serial nuber off the sticker in the fridge would help me with more ideas.
Sep 25, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
