No power to unit - Heating & Cooling
  • Roger Jelinek Apr 05, 2011
    What type of unit is this? Breakers, fuses, fused disconnect? Panel door safety switch?
    Brigadier General:
  • 4,736 Answers
Whether this is a window unit or a built-in unit, check the source of the power. Is there a circuit breaker in your home's circuit breaker panel that has been tripped? If so, it's probably the one that serves the AC unit. Reset the breaker and see if it trips again, after you turn the AC unit ON. If it does, either that circuit is overloaded or there is an electrical short in the AC unit.
Hope his helps you troubleshoot the problem.
Posted on Apr 05, 2011
DAIKIN Aircon Multi Unit - One head unit not working, others are fine. No lights or response
Check for power at unit . If there is power to unit check for blown fuse on circuit board or bad board .
Nov 11, 2014 | Heating & Cooling
Honeywell hz-710
Hello, welcome to Fixya!
Your unit is having a power fault because it is not switching on. The unit might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. If it doesn't power on, plug it into another outlet, to make sure there electric current entering into the receiver.
If plugging into another power outlet doesn't power it on then it confirms that the unit is having a power fault.
When electric current comes from the power outlet into the unit, it goes straight into the power supply board which then circulates the current into the unit. So if the unit doesn't power on, the first thing is to make sure there is power entering into the unit.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board. Once you detect any bad component, you can make necessary replacement at any electronics accessories store within your vicinity. This is the only way by which you can detect and solve the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Take care.
Nov 05, 2012 | Honeywell HZ-710 Oil Filled Radiator...
Samsung SMT-H3270 DVR not responding at all
The DVR unit still have power and display functions on the DVR small LED screen indicator on the DVR unit correct?And the DVR unit have not been in used for awhile and alway been plug in the power outlet for power like 24/7 hrs for power correct?Yes to all these questions,possible the DVR unit have software lockup or power glities some where before,possible the DVR unit have lockup and looping the software firmware of DVR unit not responding correctly for to the DVR unit to work or responding to any screen display functions.Tries unplugging the DVR unit for like about an hour and plugging power it back in for the DVR unit for the software to reboot itself.90 to 95% the unit will work again as u first got the DVR unit.
Oct 28, 2012 | Computers & Internet
My printer is showing error oxdo5do1od recycle power how can i over come that
Please perform the following steps:
Step 1: Power Cycle
1. “Shutdown” your computer.
2. Verify that the unit is switched ‘on’.Unplug the all-in-one from power and ‘disconnect’ the connection port.
3. Wait 30 seconds.
4. Plug-in only the ‘power cord’.
5. Repeat steps 2-4 two more times.
6. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
7. Restart your computer and check the functionality.
Step 2: Partial reset:
1. Unplug the power cord from the unit.
2. Press and hold # and 3 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit
If the issue persists, perform the following:
Step 3: Semi ful reset:
2. Press and hold # and 6 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit.
If the issue persists, pleae conect the unit to a diffrent power out let. Also please chek if the unit works fine in the stand alone mode (with out connecting to the computer). If the issue persists, replace the printer
:) Dr Tony
Apr 19, 2010 | HP Officejet 5610 All-In-One InkJet...
The fax log will not load when prompted
Please perform the resets given below and check if you are able to print the fax log. Please perform all the resets.
*** Partial Reset ***
* Turn on the unit
* Disconnect the power cord from the back of the unit
* Press # and 3 buttons simultaneously while plugging the power cord to the unit.
*** Semifull Reset ***
* Turn on the unit
* Press # and 6 buttons simultaneously while plugging the power cord to the unit.
*** NVM Reset ***
* Turn on the unit
* Press OK and Cancel buttons simultaneously while plugging the power cord to the unit.
Wish
Jul 31, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
I also have HP 6310xi all in one printer with power reset message
1. Please make sure that the power adapter is working properly. Also connect the unit to a different power outlet and verify.
If the issue persists, please perform the following steps:
Step 1: Power Reset:
1. Disconnect the unit from the computer. Verify that the unit is switched ‘on’. Unplug the power cord from the back of the unit.
2. Wait 30 seconds.
3. Plug-in only the ‘power cord’.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
If the issue persists, perform the following steps:
1. Take the cartridges out of the unit. Unplug the power cord from the unit.
3. Turn on the unit and insert the cartridges.
This will solve the problem...
Jun 23, 2009 | HP Officejet 6310 All-In-One InkJet...
Power Unit VX475 Stops
Checked and found that motor is definitely overheating for unknown reason. Since power unit is still under warranty, solution was to contact local service company for NuTone power unit and have them come out and fix/replace it free of charge.
Jun 27, 2008 | Broan-NuTone VX475 Bagged Central System...
Delphi roady 2 won't power up
You have a bad power plug on the unit. The solder connection are loose. The one have is doing the same thing. The power plug pins have came lose and need to be resolder. Working on how to take the unit apart to solder the connection.
Jun 05, 2008 | XM Radio (XMP6000)
Dell Optiplex G110 power supply unit replacement
Yes you can replace the old defective power supply with the new atx but the problem is the size. It the size it fit to your computer nothing to worry because power supply now is almost the same output only the wattages changes.
Apr 11, 2008 | Dell NPS-110AB (NPS110AB) 110-Watt Power...
Heating & Cooling Logo
71 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
