Question about Refrigerators
My refrigerator is set at the coldest setting but is only mildly cold. And, I think it's been like this for about the last 48 hours. What do I do? Do I need to call a service repair person?
  • 122 Answers
If your freezer is cold enough you probably have a defrost issue. check and see if there is frost build up on the back or bottom of freezer. If so then you should call a technician, unless you are comfortable taking things apart.
Posted on Apr 05, 2011
Costway EF21967 ice maker won't make ice/temperature never goes below 24 degrees/Doesn't sound like compressor is on/brand new/water is only Mildly cold/Display looks correct/Any ideas?
Unplug unit. Turn cold control to Off.
Open unit (door) and let it defrost for 4 hours. Close up.
Plug in. Turn cold control to coldest and listen for compressor. If not running, then a defective control, safety or compressor. Return for warranty repair.
It's possible the unit froze up initially, usually due to low refrigerant charge. It should have defrosted itself. Slow to make ice at 24 degrees. Ought to be near zero or at least below 10 degrees, I would think. If it doesn't perform after the defrost attempt, box it up and return.
Mar 31, 2017 | Kitchen Appliances - Others
The bottom freezer is not getting cold even though I set it on the coldest setting. The refrigerator is not getting cold when I set to the coldest temp.
If there is no cooling at all , check to see if compressor is running, if not check for power at compressor if no power see if themostat is open
Jun 22, 2011 | Amana ABB1927DE Bottom Freezer...
When set at the coldest setting the refrigerator will not go colder than 48 degrees. The freezer is holding at 10 degrees.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 21, 2011 | Frigidaire Refrigerators
Kitchen aide fridge model# ksrf22dtal00 serial# 590727330 transported horizontally and then left upright for 19 hrs before plugging in. Runs but does not cool
leave it switched on,and set to its coldest for about 48 hours.then check for levels/door fit and seals seating correctly.its only gas bubbles.....
Jul 08, 2010 | Kenmore 50522 / 50524 Side by Side...
Freezer cold, not fridge
24 hours It should be good Do check temp settings.
Aug 05, 2009 | Candy CPCA240FFK Bottom Freezer...
The fridge stop working when I changed the freezer setting
it seems the cooling coils have "iced"over .get the thermostat control changed.get the cooling fan checked .And for the time being turn OFF the refrigerator for 2-3 hours,turn control to MILD and switch it ON .
Aug 03, 2009 | Goldstar Refrigerators
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Freezer -5 Fridge 50
You have a defrost problem. Refrigerator gets cold via freezer. If blocked with frost, will restrict cold air into refrigerator.
Apr 26, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
