Question about Samsung SGH-A707 Cellular Phone
Shg-a707 i just bought my phone today and when i put my sim card in it and turned it on the signal bars turn gray and the phone says "for emergency calls only
  • Anonymous Aug 20, 2008
    Phone is horrible.... I've been fighting w/ it for a year!!! I get the "emergency calls only" EVERYDAY .... the only way to remove it & get phone working again is to turn off. I have also removed the battery, & cleaned the sims card several times, still no help!! I have already done a warranty exchange and problems are actually worse than before. I never had so many dropped calls or "emergency only" problems with any other phone. I have actually switched phones w/ my daughter & I am using my sims card in her phone (Sony Ericson slider) and have had absolutely no problems at all!!! I put her sims card in my (Sync SGH-A707) and guess what....... yeap... same problems as before!!! Go figure..... My advise is to Go trade it on another phone before your 30 days are up..... this phone is HORRIBLE!!!!
Posted on Aug 20, 2008
My new phone says "emergency calls ony" after dialing. Help! Thank you.
this message shows up when the sim card is locked... insert some other sim card and try calling.. if u can call successfully.. then u should solve the sim card problemss
Apr 07, 2010 | Samsung SYNC SGH-A707 Cellular Phone
My Samsung F480 has decided to put emergency calls only on my phone? I have contacted my network provider and no problems with SIM they say it must be phone. Any suggestions why?
No Signal At The Time Of You Trying To Make A Call...Both My 439 & a707 Samsungs Have Done This Very Same Thing...I A'm Not A Pro Here Just A Poster Like You But I Hope This Helps ....aasieb
Nov 21, 2009 | Samsung SYNC SGH-A707 Cellular Phone
I turn on my phone it goes to a screen saying Emergency Download
Wait does it say emergency mode only? If so this has happened to me many times on this phone.
Turn off the phone and remove the battery. In there will be you should see the SIM card. Pull out the SIM and put it back in. Put back the battery and turn on your phone.
For some reason on these phones the SIM card gets dislodged. When it does the phone won't work because the SIM card is what makes the phone your number etc. All cell phones, that have no service otherwise will be able to call 911. Apparently it is a law, so that is why your phone is on emergency mode. Without the SIM card the phone is a phone without service and will therefore only work in emergency mode.
I hope this is what you meant.
Aug 13, 2009 | LG Vu CU920 Cellular Phone
My Sci phone 68i will not pick up a signal.
If you are trying to dial in only one place and it is reading emergency calls only that means you are not getting signal. Mine stays on emergency calls only while in the house using a T-mobile sim card. I don't get very good signal here. Try it in other places and see if you catch signal. If it's stuck on emergency only make sure the slot is turned on under dual sim settings in settings. If it still doesnt work I'd send the thing back :P
Aug 02, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I bought the samsng sync A707 on ebay and everything works except can't make or receive calls. says Emergency calls only
 If the phone is saying emergency calls only it is because you need a registered sim card from a cell provider. So you just have to go and have the phone activated at AT&T or whom ever you are going to use as your carrier.
Mar 21, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Unlock a Samsung A707
Insert ANY unaccepted SIM card in the phone and then turn the phone on, follow the steps in 1 to 4 below to enter all the codes. The phone will states "Wrong card" at the end of step 2 and "network lock deactivated" at the end of step 4 if you do everything right so pls take your time to enter the code or follow the instruction correctly at each step. When entering some of the zeros at steps 3 and 4 your phone may display the zero as hyphen or minus (-), dont worry, just count when entering the zero to ensure you enter just the right numbers of zeros. Now let's begin... 1/ Put any unaccepted SIM card in your SAMSUNG SGH Phone, turn the phone on, it will display "WRONG CARD"
2/ At the wrong card screen, type *7465625*638*00000000*00000000#
3/ Now remove the battery with the SIM card, Put the battery back and turn the phone on again without the SIM card, it will display "Insert SIM card" 4/ At the insert SIM card screen/end of step 3 above type #7465625*638*00000000#
At the end of step 4 phone will show "network lock deactivated" 5/ Now Reinsert your unaccepted card or any other unaccepted SIM card in the phone and enjoy your unlocked phone!
Jan 27, 2009 | Samsung SYNC SGH-A707 Cellular Phone
I can't make calls from my Blackberry 7290
Check on the right hand corner of your device for the vertical signal bars - 5 bars indicate full strength and 1 indicate very low signal. "OFF" indicates the radio is off and need to be turned on.
In case signal strength is good, you should be able to make and receive calls. In case it does not work, just try taking the battery out and put it back after 15 seconds and try again.
In case signal strength is low , either you are in a low signal zone or your SIM card is bad. Take the SIM card out, wipe the gold plated surface using a clean tissue, put it back and try again.
In case the radio is OFF, turn it on by clicking on the icon (Turn Wireless on) on the home page.
Dec 27, 2008 | RIM BlackBerry 7290
Emergency call only
give phone a reset.....or change network settings..
Oct 18, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Cect A380I
Switch the sim card to the secondary slot as it is often set as the default SIM.
Mar 16, 2008 | Cell Phones
Samsung SGH-A707 Cellular Phone Logo
124 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
