Question about Sansui Televison & Video
The DVD tray will not open no matter how many times you press the eject button via the remote or direct on the DVD player. It just refuses to open.
  • 1,238 Answers
Good day sir...
your problem is on the ejecting motor,the broken rubber that connected to the mechanism or on the driver of the ejecting motor...you have to do is....
1. open the cover by removing all screws that holds the cover
2. try to remove the lens assembly one set including the cd tray..by unscrew the lock of that mechanism...
3. try to see the ejecting motor if the rubber is okay and remove the motor to check the resistance weather it good or bad the reading is not more than 25 ohms or or try the actual testing using a 1.5v battery if the motor spin up that's good
4. if the rubber and the motor is good..this is gonna be a major trouble when the driver is defective this not for D.I.Y..its better to it to the qualified service technician for immediate remedy or solution for that..
5. but when you found the trouble like on steps 2 and 3..replace immediately on the same type and ratings...
thank you and good luck
Posted on Apr 05, 2011
Testimonial: "thank you kindly. "
Cant get my akai DVD player to play all my cds and dvds
Instructions
  1. Changing Region Code on Oppo and Similar DVD Players
    • 1
      Press the "On" button on the remote control to turn on the DVD player.
    • 2
      Press the "Setup" button on the remote control.
    • 3
      Press the following buttons in this precise order: 9210.
    • 4
      Highlight the text field in the window that appears. Press "0" on the remote control to change the region code from one-region specific (the country the DVD player is sold in) to all regions so that any disc can be inserted and played.
    • 5
      Press the "Setup" button. Press the "On" button on the remote control to turn off the DVD player.
    Changing Region Code on Sony and Similar DVD Players
    • 6
      Press the "On" button on the remote control. Press the "Open/Close" button to eject the disc tray.
    • 7
      Press "Clear," "1," "4," "7," "0," "Clear" on the remote control. Press up on the remote control's directional pad until you see "1224" on the screen.
    • 8
      Press "2," "3" and the "Enter" button. Press up on the remote control's directional pad until you see "1401" on the screen.
    • 9
      Press "0," "0" and the "Enter" button. Press the "Return" button. Press the "Clear" button twice. The DVD player is no longer locked into the single region that it was designed for (being the country it was sold in) and is now instead open to all regions and so able to access any disc.
    • 10
      Press the "Return" button. Press the "Open/Close" button. Press the "On" button to turn the DVD player off.
    Changing Region Code on Denon and Similar DVD Players
    • 11
      Press the "On" button on the remote control. Press the "Open/Close" button to eject the disc tray. Press "Clear," "1," "4," "7," "0," "Clear" on the remote control.
    • 12
    • 13
    • 14
    • 15
      Press the "Return" button. The region code of the DVD player is now changed from being only for the country it was designated for and instead for all regions. Press the "Open/Close" button. Press the "On" button to turn the DVD player off.
PROCEED ACCORDING AND FOLLOW THE STEPS. God bless you
Apr 04, 2013 | Akai Dv-px6150k - Multi Region...
How to change toshiba sd-412v region 1 to free region?thanks
Hi friend. Try this:
Press the power button on the Toshiba DVD player remote. Press the "Open/Close" button to eject the disc tray. Remove any disc that might be on the tray before proceeding.
Press the following keys on the remote in this order: 2,4,0,3,9,6,0.
Press the "9" key on the remote.
Press the "Open/Close" button to close the disc tray. Press the power button to turn the Toshiba DVD player on.
Hope it works.
Jun 16, 2011 | Toshiba Televison & Video
JVC Model DR-MV99 tray door keeps opening and closing when trying to insert a DVD disk
This problem was driving me crazy, until I found a solution.
This is what you need to do.
When the tray is open grab the flap door that goes up when the dvd goes in. Hold it down as you the DVD tray goes in. (Its spring loaded) This allows you to have direct access to the front of the tray even when the DVD goes all the way in. Hold the tray in with your finger by pushing in firmly on the far right corner of the DVD tray. The DVD tray will try and come out, continue to hold it in while pressing the eject button on the remote. If you are firmly pressing in on the right corner of the tray it should only take a few times of pressing eject when you see the Disk symbol on the screen and you will here the DVD start loading. When you know that it is starting to load release the front door flap. You can then use the DVD player as normal.
Unfortuntely you will need to do this each time a DVD is loaded.
Jan 24, 2011 | JVC Televison & Video
Our Samsung DVD-H1080 DVD Player wont open, we've had it for a while, but the place where it opens is stuck, help??
Are you using the remote or touch button on case to eject tray?
Sometimes the top lid gets warped and prevents the tray from opening. Press eject and lift the front part of the lid at the same time.
Aug 17, 2010 | Samsung DVD-H1080 DVD Player
Unable to open the door of the dvd --when you press the eject button to open the slot---the door does not open---everything else works
Quick trick
First let's find out if the motor is dead or
the magnetic clamp is to strong for the motor.
Press eject then listen closely for the sounds of struggling motor
if you hear it trying SLAP the top right over the DVD drive
and that should break the magnetic seal and release the tray
you may have to try a few times Press eject and open hand slap kinda
hard the top of the DVD drive , don't worry you won't hurt it.
if that works email me and ill tell you how to fix this.
Rob
rsheehan@northernsteeldesigns.com
Oct 14, 2009 | GoVideo Go Video DVD/VCR Combo
Locked dvd tray.
with the unit off press and hold the stop button and the eject button.
Jul 08, 2008 | JVC TH-S11 Theater System
DVD-RAM will not eject via "OPEN" tray command
Hey I just found out how to UNLOCK the tray
Power up the unit, wait for it to read the disc if one is inserted.
hold the stop button and the power button down together for 5 seconds
the display will show UNLOCKED
Open/close button should be restored
Apr 03, 2008 | Panasonic DMR-T2020 DVD Recorder
DVD Tray will not open
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
Locked dvd tray.
Press and Hold EJECT Button, While UNLOCK Is Displayed :-)
Nov 12, 2007 | Sanyo DVD-7201 DVD Player
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Televison & Video Logo
264 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
