Question about Sony KV-27S10 27" TV
Sony KV-27S10 In the old days this problem of multiple lines across the screen could have been corrected with horizontal hold or horizontal linearity. How do you fix that problem on this model?
  • swifty945 Aug 06, 2008
    Thanks, Maciso. I can't tell. It has horizontal lines across the screen about 1" apart on a 27" screen. The are slightly angled down from the left side of the screen to the right side. I thought that with the old horizontal controls you could adjust them until you increased the space between the lines until they straightened up. Is that a horizontal or vertical problem?
    Thanks, Swifty
    Thank you Maciso. Will get checked out by tech.
    Swifty
  • 125 Answers
Is it vertical problem or retrace lines can you tell
Posted on Aug 06, 2008
  • Anonymous Aug 06, 2008
    most probably is overscreen adjustment, defective crt or open res.in screen control circuitry
SOURCE:
My tv sony kv-xa21m61 display too bright and many horizontal lines. no picture
Vertical retrace lines is the problem. Thin white lines runs across the entire screen, at about an inch apart to each other. Check its video output supply voltage. Reduce the screen voltage to a little bit down and check. If you still wish to know more about this fault, check this site. Pull up older posts there.
Feb 09, 2013 | Sony KV-XA21M61 21" TV
Sony KV-27S10 has intermittent tuner issues. moving the cable connection on the back of the set sometimes clears the picture.
This was a common problem with the Tuners of these models. The replacing of the Tuner should fix the Problem. You may be able to order it from Sony.
Here is their Customer Service Number.
1800-222-Sony
I hope this helps,
Skyassoc
Oct 27, 2009 | Sony KV-27S10 27" TV
Sony TV not turning on
Chances are the Power Supply failed because the Horizontal circuit failed. It would not be out of line if the repair cost ran 250.00 plus.
It is probably not worth fixing due to the age of the set.
Hope this helps,
Skyassoc
Jul 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV36XBR400 fragmented picture horizontal overlapping lines
this will continue to degrade, almost any failure that can be affected or temporarily cleared up by hitting the set is caused by bad solder joints.
A good shop should be able to find and fix the bad solder connections for probably a little under $100
if you bring it to them and pick it up.
Feb 10, 2009 | Sony KV-36XBR400 36" TV
My Siny Trinitron G21M1 is producing horizontal lines across the screen
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
Oct 26, 2008 | Sony Televison & Video
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
Sony kv36fs76u
hi there, your set has a capacitor problem, most of it are on the horizontal section and video section., usually 100 microfarad electrolytic capacitor with a high voltage is damage. try to test some parts. ty
Dec 02, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Televison & Video Logo
140 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
