Question about Kenmore 64802 Top Freezer Refrigerator
Bulb quit working replaced with new one still doesn't work
  • Kenmore Master
  • 5,370 Answers
The bulb still not working after replacement, this means the new bulb is working, but its not getting power.Either is short in the wires connecting to the bulb socket or the bulb/ light switch is faulty.In most of the cases, the switch gets shorted internally and , this causes the problem.Get the connections in the switch and to the switch checked, by meter as well as visually.This will confirm the problem.--------- This should help.Thanks.Helpmech.
Posted on Apr 05, 2011
Inside light bulb quit working the bulb is good but doesn't turn on when door opens
Hello Rick Cieri - From what you have described it seems like the unit could possibly be experiencing a wiring failure or communication problem coming from the main control board. Connect with a certified technician to accurately pinpoint any potentially more serious issues.
Jan 19, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
1989 F150 one brake light works, the other doesn't but bulb is good
check for power at the socket. socket may be bad and may need to be repalced
Sep 27, 2012 | 1989 Ford F 150
Mazda cx7. both high beams work and one low beam works. how can i tell if its a headlight or some other problem
Thanks for choosing FixYa and welcome. These new lights have two types lin one bulb, one for the low beam and one for the high beam. Find the bulb that isn't lighting for the low beam and replace it with a new bulb. If it doesn't work, you need to check the wiring to that specific light. Since it is only one, the new bulb should work.
Oct 01, 2011 | 2000 Mazda MPV
Pentair PG 2000 light stopped working. Replaced metal halide bulb, worked for a few hours then stopped working and wouldnt come back on. Replaced capacitor, but light still doesn't work. Have verified...
Have you replaced the ballast or did you just replace the capacitor? If you did not replace the ballast I would start there. Also if you have a multimeter check your bulb for continuity you may have gotten a bad bulb.
Jun 11, 2011 | Home
The service engine soon indicator light is burned out on my 1998 Ford Windstar. There are no codes, it passed inspection for everything but the bulb. The owner's manual doesn't give info on bulb...
The bulb replacement is quite simple - at least once you've disassembled the dash and have the instrument cluster in hand and can access the bulb in the back.
May 26, 2011 | Ford Windstar Cars & Trucks
Turn signals quite workin
first, check your fuses on the blinkers.
1. open up the fuse console located either under the steering column, under the hood in a rectangular plastic box, on the passenger floorspace wall or the driver's floorspace wall.
2.look at the fuse diagram and there should be a fuse category for your turn signals. switch the fuse with a new fuse or a like fuse that you know works (check the voltage;5,10,15,20,25,30).
3.try the signal.
-if that doesn't work it's most likely the bulbs.
if THAT doesn't work then you need a multimeter voltage detector and/or one of those wire tracers to locate the short in the wiring.
May 06, 2011 | 1993 Nissan Pathfinder
2004 elantra dome light quit working. Bulb has
Hello Janet. Begin by removing the bulb again and cleaning the contact plus the end of the bulb with the eraser at the end of a common pencil. That alone may solve your problem. There is also a fuse. look in your manual to determine which fuse it is and replace it even if it looks ok. Finally, if these things do not solve your problem it may be the switch. If that is the case call an autoelectric shop and they will change it for you for a few dollars.
Nov 20, 2009 | 2004 Hyundai Elantra
96 ford explorer headlamp quit working on low beam
check for power at the bulb socket also check for poor contacts in the socket
Aug 18, 2009 | 1996 Ford Explorer
Kenmore 64802 Top Freezer Refrigerator Logo
132 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
