Question about Samsung SCX-4216F All-In-One Laser Printer
ON Samsung SCX 4216 Error: Paper Jam 0 Open/Close Door Can't find any paper stuck in it. Error does not go away even when turned off and on or unplugged.
  • 196 Answers
Hello! Welcome to FixYa
Paper jam
means their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow" by compressed air.
more over roll the toner gear check if its not obstructing to something .
secondly try to cut/delete any pending print jobs thats right next to clock on your dektop.then restart PC and then plug the printer and PC on see if it works.
If still problem exist then, post your query here ,
I hope this solution will helpful for you
Anymore help regarding the issue, I am here to help
Thanks
Posted on Apr 05, 2011
Paper Jam 0 , OPEN/Close Door Message Samsung SCX4100
seems as if the motor responsible for taking in the paper has stopped working and may need to be replaced
Dec 26, 2016 | Samsung SCX-4100 All-In-One Laser Printer
Samsung SCX-4521 "Paper Jam 2" won't clear
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
Goodluck,
please don't forget to rate me as fixya..
Feb 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Paper jam 2, check inside
You should troubleshoot jamming error message by removing toner cartrige, check if the little plastic sensors on the paper path are not stuck somehow, reinsert toner,close door, open back door check if the fuser sensor is ok ( and not broken), clean the papertray roller, restart printer and it should work. If that doesnt fix your problem it can be a faulty sensor or some tiny paper left somewhere you can't see and sensor detects .. Hope it helps.
Apr 07, 2014 | Samsung SCX 4521F All-In-One Laser Printer
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
Machine says there is a paper jam when there is no jam. Shows jam in exit but the paper never even starts to get picked up from the main paper cassette but it will feed fine frome the mp tray. any...
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 08, 2009 | Samsung SCX-6320F All-In-One Laser Printer
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Paper jam --samsung SCX-4828FN
i found that paper jam was in the middle of the mechine. i opened the front door and removed papers.
Sep 17, 2009 | Samsung SCX-4828FN All-In-One Laser...
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Paper jam error, check everything but still showing paper jam
turn off the printer
Unplug it
open the paper jam door and gently push the paper roller forward until it clicks.
close the door
wait a few minutes
plug the printer back in
turn it on and see what happens.
I hope this helps.
Aug 18, 2008 | Samsung SCX-4725FN All-In-One Laser...
Samsung SCX-4216F All-In-One Laser Printer Logo
802 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
