Question about National (=Panasonic) CordCordless Hair Clipper ER230 Beard Trimmer
I have national hair/beard trimmer er 203. The battery has become very weak. I would like to replace it. What is your local support office in Karachi. Could you please send me the address and phone number of your local branch
Ni Cd Batteries for ER203 Panasonic
I have purchased ER203 6 Years back now its not working i found battery end life, can i use this battery AA 1.2V 1300mAH for this trimmer, can i charge above battery as it is like ER203, Please suggest
Aug 12, 2013 | Panasonic ER 203 Beard Trimmer
Need a replacement blade for ER240 beard trimmer in bangalore
panasonic WER961P replacement blades for beard trimmer panasonic er240 cutter replacement parts.
panasonic er240 replacement blades
Sep 06, 2011 | Panasonic ER 240 Beard Trimmer
NEED A REPLACEMENT BLADE FOR TRIMMER ER 240
May 12, 2011 | Panasonic ER 240 Beard Trimmer
ER203 NOT CHARGING,INDICATE THE RED LIGHT.WHAT IS THE PROBLEM PLEASE.
Your Trimmer uses Ni-cd battery, which provides 40 minutes of shave time with one full charge of 8 hours. It seems that either your battery is dead or the cutting element is clouged. I'd suggest that you wash the cutting elements with warm soupy water and then try to turn it on again.
If that doesn't work, your battery is probably dead. If the unit is within warranty, you can contact Panasonic support for a replacement or else try replacing batteries with the help of a local technician or a repair center.
Hope this helps..
Mar 06, 2011 | Panasonic ER 203 Beard Trimmer
My Panasonic ER 203 with problem spring of
If the spring on the blade has come out, the blade has to be broken. The manufacturing process for this type of blade makes it impossible to take it apart without breaking the plastic that holds the spring. There is simply no way to effectively repair the blade.
You will need to replace the blade or the entire unit.
Feb 14, 2010 | Panasonic ER 203 Beard Trimmer
Opening the Panasonic ER203
just insert a thin bladed knife between the two parts and gently lever apart
Jun 04, 2009 | Panasonic ER 203 Beard Trimmer
THE BLADE HAS COME OUT, AND IAM UNABLE TO REINSERT IT
poor website to get any helpful information, don't waste your time
Jan 29, 2009 | Panasonic ER 203 Beard Trimmer
National (=Panasonic) CordCordless Hair Clipper ER230 Beard Trimmer Logo
217 people viewed this question
Top National Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a National Health and Beauty Expert? Answer questions, earn points and help others
