Question about HP OfficeJet 4255 All-In-One InkJet Printer
The paper is not getting in the printer whenever the command is given HP - 4255 all in one
    Scholar:
  • 83 Answers
Product Does Not Pick Up or Feed Paper:
Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent. NOTE: Use only plain, white, unused paper in the product until the issue is resolved.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper. NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again. If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
    Step four: Clean the rollers
    1. Turn off the product and unplug the power cord.
    2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
    3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
      4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
      5.Close the access door and plug in the power cord. 6.Try printing again. If the issue is not resolved, continue to the next step.
Posted on Apr 05, 2011
Hp officejet 4255 black colour print not very clear
Select print in grey scales only in printer properties while shooting the print command, printer is using color cartridge instead of mono cartridge..
Jan 11, 2012 | HP OfficeJet 4255 All-In-One InkJet...
Head is making noise of printer hp officejet 4255
Hi.
That's problem noise head of printer hp office jet 4255.
some paper and dust there in the head mechanical area.
you need to cleaning using vacuum and check-up inside printer.
to get paper and dust covering printer censor.
if you already get-off paper and dust.checkup also ink cartridge's black and colored.
power on printer if same problem you need to replace main board.
Jun 14, 2011 | Office Equipment & Supplies
Hp 4255, if i send five pages, it shut first five blank pages
check your settings in Start->Settings->Printers->HP4255 rightclick ->properties-> preferences.....
Oct 29, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Paper jam in HP 4255 office jet all in one printer
the paper path may have some jam. It may have some solid particle or paper that's causing disturbance.
If not the paper moving mechanism is having problem.
Better get your printer serviced.....
Jul 17, 2008 | HP OfficeJet 4215 All-In-One InkJet...
No printout
did you try to print a test page from the printer from setup button
Jul 05, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Printer, fax ,scanner,copier hp officejet 4255
hi....
pls click this link below. this is a link where you can get the software to download and select your operating system first.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=351125&lc=en&cc=us&dlc=en&lang=en&cc=us
May 10, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Failed to print
Uninstall the printer driver and restart the computer! Disconnect the printer from the computer and then reinstall the printer driver.
Dec 05, 2007 | HP OfficeJet 4255 All-In-One InkJet...
Paper is getting twisting during printer
If it prints but comes out curly then
Paper is damp, try fresh paper.
Aug 16, 2007 | HP LaserJet 1010 Printer
HP OfficeJet 4255 All-In-One InkJet Printer Logo
64 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
