Question about Electronics - Others
ERROR IOCTL CALL..CAN'T FORMAT MY 2GB MICROMAX FLASH MEMORY..
I have 500gb removable hard disk i cant access it and i cant format it it shows IOCTL error help help
yhabtea@yahoo.com
Posted on Nov 23, 2012
4 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: ioctl error . unable to format
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 22, 2009
  • 145 Answers
SOURCE: Micromax 2GB usb key cannot be formatted
Dear, Its is a know issue to microsoft, you try after installing latest service pack http://support.microsoft.com/?kbid=836618
And while formating from my computer, instead of FAT32, you can use NTF and try
Posted on Oct 17, 2009
Geekman
  • 32281 Answers
SOURCE: I have a 2GB scandisk pendrive, I unable to format
Try formatting the flash drive using this method.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Posted on Oct 22, 2009
I have micro cruzer 4GB USB and it givim me a error in IOCTL call how can i fix this
Usually this means the system can't detect the structure of the filesystem. You may have to format the drive.
In Windows, you can right-click the drive and choose "Format..."
In OSX go to Disk Utility, select the drive on the left, and click "Erase"
Mar 06, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I m getting problem with IOCTL error with my sandisk 2.0 pendrive..i m unable to format of open..will u plese send me solutions how to get rid of this error...??
I m getting problem with IOCTL error with my sandisk 1gb pendrive..i m unable to format of open..will u plese send me solutions how to get rid of this error...??
Nov 28, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My flash drive have an ioctl error. the drive can still be recognized only can be accessed. how can i fix this problem. my usb flash drive is a kingston 16GB?
I have a kingston usb flash drive 256mb but it shows 0mb in windows when I format on cmd prompt it shows IOCTL error does any one have a proper solution or utility to remove this problem
Nov 01, 2010 | Computers & Internet
Cant format sd card shows error ioctl
Have you tried to format this unit on another computer. If you get the same error on another computer then it is a bad sd card.
Oct 29, 2010 | Electronics - Others
When i format my kingston usb it shows IOCTL error ...
change it port then follow these
first you install yours device then logoff yours system then logon again and click on start--->run --> write command cmd then click on ok,Now write commands step by step
1) cd\ press enter
2) c:/>format drive letter (eg d: f: e: etc) press enter
3) read message carefully and then press y
now yours flash drive formatted
May 17, 2010 | Electronics - Others
I have a 2GB scandisk pendrive, I unable to format it, Whenever i tried to format it in command. Msg appered IOCTL call error. how can I format it. Pl help me
Oct 22, 2009 | Transcend (589307) Media
Oct 17, 2009 | Electronics - Others
Open Questions:
Electronics - Others Logo
2,620 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
