Question about Dell Latitude CPX Notebook
Fn key on keyboard seemed stuck
My Dell Latitude pcx's Fn key on keyboard seemed stuck. therefore i have to hold Fn key down type uiopjkl ect...how do I get out of this mode. Fn key has been depressed a number of times to cancel this mode but unsuccessful.
please help.
[email protected]
  • Anonymous Mar 06, 2009
    i have the same problem as well
  • 3 Answers
Hit shift and "Num Lk" at the same time. Num Lk is abov the F11 button on some Dell keyboards.
Tony Nguyen From Pasadena, CA
www.connectionzpcrepair.com
Posted on Apr 26, 2009
    Genius:
  • 2,028 Answers
You have enabled the numbers lock. Hold the fn key and press the Num lk key. Num lk is the numbers lock key and the Num lk is in blue, same as the fn.
Posted on Aug 07, 2008
I think I have the same problem as what vltruong on my Dell Latitude CPx. I've been ignoring it for years using an external keyboard but finally tried different things (changing BIOS settings as well as this Fn+F12+NumLk that jackie1969uk describes in http://www.fixya.com/support/t1629106-fuction_botton_stuck_press_fn_button and it's healed! Thank you!
Posted on Apr 12, 2009
SOURCE:
My Compaq laptop keyboard seems to be stuck in ALT mode. All the keys which have an alternate character in the upper right corner, will only type those characters. For example, the "m" key will only type...
Never ran into this problem myself but a friend of mine has. He said what fixed his what holding Fn + Num Lock and it remedied his problem.
Unless your key is stuck/broken you can also try a can of air and try to blow it out and or pull the key and make sure its not stuck down.
But deff try the holding Fn + Num Lock method first.
Jul 18, 2010 | Compaq Presario 700 470024-192 Notebook
My laptop is a dell latitude d610. I know i somehow lock my keyboard but I dont know how (what keystrokes) I need to unlock it. I have restarted the laptop and am stuck at login screen. Curser is there but...
have a look at ur keyboard,,,while holding the fn key press the appropriate function key,,these are the f keys across the top of ur keyboard,,look for the picture of ur keyboard or a padlock
Jul 08, 2010 | Dell Latitude D610 Notebook PC
I would like a manual for the latitude D610 keyboard to know how to use the symbol that are highlighted in bleu
In the lower left hand corner of your Dell Keyboard -- you will see a Blue Key labeled -- "Fn". This key allows you the use of ALL of the other blue labeled keys on your keyboard. You must press the FN key and the other "blue" key at the same time for them to work.
The keys on the right side of the keyboard with the blue numbers on them are controlled by the Numlock key and Fn key. The light at the top of the keyboard near the power button, with the number "9" inside a picture of a lock, will be lit if the Numlock is enabled.
You may need to press the Fn key to type numbers even if the Numlock is turned on. There is a setting in the BIOS called Enable Keypad and if you set it to By Numlock you will not have to hold down this key to type a number.
If you are still having trouble with these keys, please see the general keyboard troubleshooting guide
http://ftp1.us.dell.com/diags/R65848.htm#Key not responding or typing wrong character
Jan 13, 2010 | Dell Latitude D610 Laptop Computer -...
Function Key Issue
Use air compressed can to clean under and around key (if issue could be mechanical)
Jan 12, 2009 | Dell Latitude CPX Notebook
Fn option appears in place of letters on keyboard
Sounds like you need the keyboard replaced...
Jan 08, 2009 | Acer TravelMate 2300 Notebook
My speakers do not work
The Dell has a "Fn" key. The "Fn" used with other keys control special features. I have a Dell keyboard here, on it holding the "Fn" and pressing "End" will alternately mute/unmute the speakers. "Fn" + "Page up" will raise volume, "Fn" + "Page down" will lower. You may have the volume muted, or turned all the way down.
The keyboard I have is from an 1100, your "Fn" key combinations may vary from mine.
Jan 02, 2009 | Dell Latitude D600 Notebook
Ibm t30 keyboard stuck in odd mode
You've activated Euro mode. This is toggled by pressing holding the Fn key plus an Fkey that has an icon in the same color as the lettering on the Fn key that looks like the Euro symbol. Press the Fn key plus the Euro key to toggle out of Euro mode.
Regards,
Worldvet
Aug 03, 2008 | IBM ThinkPad T30 2366 Notebook
Blue numbers
Make sure Num Lock is on (the light belonging to numlock is on).
Then use Fn + Keys with a blue number on it to use the keypad.
Make sure you hold the fn-key, for each number you want to type...
If this doesn't work, try Fn + Esc. If your laptop goes to standby mode, The Function key is allright, and there is another problem. If it does not work, your keyboard may not be installed probably, or may be defect.
Please post some feedback,
Good luck
Apr 04, 2008 | Dell Latitude D600 Notebook
Dell Laptop - Keyboard "Fn" is causing problems!
I think it is not the Fn key but the NumLock that is activated. Look for the key labeled NumLk , this is the number lock. Also check if the light on the notbook with a number (usually number 1) is on. If it is on, yo must deactivate the numlock by pressing it again. It works in toggle mode. Sometimes the numlock is activated together with the shift key, sometimes with the function key.
Jul 06, 2007 | Dell 0Y3740 Keyboard
Dell Latitude CPX Notebook Logo
2,242 people viewed this question
Ekse
Clive
Clive
Alun Cox
