Question about GPX S7799 Shelf System
My GPX S 7799 doesn`t play cd`s. The cd belts are
My GPX S 7799 doesn`t play cd`s. The cd belts are ok. What could be the problem?
How to set turntable for 78's on GPX Model 7799
The only way I think they did that would be if there are speed preset buttons somewhere on the unit. These might be found under the turntable. Perhaps covered up with stickers. What you would do is put tha screwdriver in one if there's two! and adjust it while the disc was playing. To play it at 45 or 33 again you would need to reset it. Best to mark it where it is positioned before adjusting.
However if you are recording the 78's then you need only play them back at 45. The software should have an option to convert it to 78.
Feb 08, 2013 | Audio Players & Recorders
Can't play the cd
After putting in the CD, move the switch on the back to the CD/Line In position. (The other switch positions are Off, AM, FM.) The switch is next to the Line In (3.5 mm) jack. Then press Play/Pause on the front of the boombox. This is the single button on the left side (The adjacent pair of buttons are the search (reverse/forward tracks). On the other side of the LCD display are the Stop, Repeat and Program buttons.
GPX has the manual for the GPX BC232 on the product page: http://www.gpx.com/store/p/822-BC232R.aspx . Click on the tab for Downloads to get the manual link. The direct link is http://www.gpx.com/owners_manuals/BC232-578-01-IB.pdf . You will need Adobe Reader or a similar program to access the manual.
I hope this helps.
Jan 08, 2013 | GPX BC232R Radio CD Player Boombox
GPX HMW5034DT CD Tray will not open
Most likely the belt has lost tension to the motor that drives it- this is very common with all belt assisted drawers.
Dec 22, 2012 | GPX Audio Players & Recorders
GPX plays music cd's only not dvd's
You need to replace the motor disc spindle because with time lose some velocity and thats why don't play dvds
Sep 30, 2012 | GPX D200B Player
LID WON'T CLOSE ON CD PLAYER
The CD loading mechanism have the fault. Check its loading belt. If loading belt has broken, the try wont close of open. If loading belt is OK. replace the loading motor.
Aug 12, 2012 | GPX Audio Players & Recorders
I ripped a CD on my computer than tried to play it on the GPX it wouldn't play but the screen said "File". What does that mean and can I get it to play a ripped CD?
You have to burn a CD in "CD/Music" format. You can't burn it as a data CD. Which just sucks cuz doing it in CD format, you can only fit 15 or so songs on each CD. And I wasted a CD finding that out.
Aug 31, 2009 | GPX HM3817DT Shelf System
Will not record but will play cd's
You don't say what the recorder does do when you try to record. Any messages?
One possibility - You have to use CD-Audio or CD-Music media for consumer CD recorders.There are probably a zillion logos plastered somewhere on the unit that say what media are compatible with it.
May 16, 2009 | GPX CDRW3500 CD Player
GPX S7799 Shelf System Logo
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
