Question about Sanyo VPCE1090 Digital Camera
My camera (sanyo vpc-e1090) did not turn on. But when it is on charging then it work properly. and charging light also not blink on charging... please help me.
  • 11967 Answers
SOURCE: my sanyo camera vpc-t850 s/n 08061106261 will
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 01, 2009
SOURCE: sanyo vpc e1090 says lens error 0x0311 when i turn
I have one of those and had the same message. Go to the menu and then into the "settings" section. One of the settings will be "digital zoom". You will have to enter into that setting and set it to "ON". Worked for me!
Posted on Jul 09, 2010
SOURCE: I have a VPC E1090 Sanyo, I just purchased it
I have one of those. As noted to someone else, go to the menu and into the settings. One of the settings adjustment is "digital zoom". Press OK to enter into that digital zoom and then press the down arrow to highlight the "ON". Then you can get back out of everything by pressing MENU a couple of times.
duane_wong
  • 6826 Answers
SOURCE: Hello! I have a SANYO VPC E1090 digital camera.
The lens error refers to a 'binding' in the mechanism for focusing.
The camera will not operate if this error exists. So, it's important for the owner to try to seek repair service for the camera.
http://us.sanyo.com/Customer-Support-Service-Center-Locator
Posted on Aug 07, 2010
ginko
  • 19396 Answers
SOURCE: I get Lens error 0x0311
Hi.
This is a common problem.
You can send camera for repair here: Repair.
See here an article: Sanyo digital camera is not starting and you get lens error
Posted on Jan 20, 2011
I have a sanyo vpc e1090 digital camera. it is reading lens error 0x0000 when it is turned on. it makes a hum noise then shuts right back off.
The lens is stuck. If you can't GENTLY pull it open, try lightly tapping the camera on a firm surface to see if it dislodges any debris. If that won't work it must go in for repair.
Oct 13, 2014 | Sanyo Cameras
I have a sanyo vpc-e1090 which displays a Lens Error 0x0311. The camera powers up then shuts down. I am unable to get into the menu to check any setting. Any ideas on how to fix this issue?
Maybe the lens are blocked.
Try :
1.- Turn OFF the camera and push softly the lents
2.- Turn ON the camera and PULL softly the lens.
Is importan to people who share knowledge hear your comments or received rate points
Sep 16, 2011 | Cameras
When we turn on our Sanyo VPC E1090 digital camera the lens does not appear to come out completely & we get an "lens error 0x0311" message on the screen then it turns off. WHAT IS WRONG!! ...
If lens does not appear to come out completely and camera gives error that means lens mechanism got broken internally and lens assembly will be replaced to solve the issue.
Lens replacement is not user level repair and local camera repair shop[ will do this job for you if camera is out of warranty.
Thanks.
May 28, 2011 | Sanyo VPCE1090 Digital Camera
I recieved a camera for christmas but there was no manuel how to operate it it is a vpc=e1090
You can download from:
http://www.sanyo.de/produkte_daten/digitalimaging/digicam/manual/SANYO_Manual_E1090_EN_E.pdf
Jan 13, 2011 | Sanyo Cameras
Hello! I have a SANYO VPC E1090 digital camera. When I turn iton the LCD screen has a red bar across the top and says "Lens Error 0x0311" and then powers down. Do you have any suggestions other than...
Aug 07, 2010 | Sanyo Cameras
The battery for my sanyo digital camera won't charge.
I had this same problem with my Sanyo. I went on E Bay and purchased a new battery.. It was about 8 dollars and shipped from China. But it worked when I put the new battery in and charged it.
Jul 30, 2009 | Sanyo Xacti VPC-T700 Digital Camera
Sanyo VPCE1090 Digital Camera Logo
140 people viewed this question
Top Sanyo Cameras Experts
teddyboy
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
