Question about Pyle PLTTB3U Turntable
Pyle plttb3u record player what is the replacement stylus? what cartridge does it have? my stylus has worn out AND I need to replace it contacted PYLE by email but they have not returned my email
    Brigadier General:
  • 8,546 Answers
Cast your eye on it and LOOK to see what cartridge it has. Then Google a replacement stylus. OR, if it's some no-name pos (which they don't actually name in the specs) get a whole new cartridge of your own choice.
Posted on Apr 05, 2011
My player drags and changes tempo when the needle is first put on the player. After time it seems to fix itself but would like to remedy this as soon as possible. Can you tell me how to fix this?
Generally it is caused by the cartridge and stylus pressure not being right. At the end of the tone arm (not the cartridge end) you should find a weight. This needs to be adjusted. If there are numbers on it, start by moving it to a lesser number than the current setting. Move this only slightly. Then try a record. The stylus should stay in the groove, not rumble and not drag. It's best done via headphones. If it comes out of the groove too easily move the weight in the other direction and then test. You have to keep doing this till the sound is good. Too much rumble - reduce the weight, jumping out of the groove increase the weight.
There might also be another control called an anti-skate control. This might be be helpful in your case as it will reduce the effect of the arm being pushed into the center of the record. Once again the settings of this control are based on trial and test like before.
If you have had the stylus for some time also you might want to replace it, as stylus that are worn could cause it.
Aug 13, 2015 | Crosley Conductor CR73 Turntable
My awa turntable with cassette, cd player and recorder (e 6906) has a problem. At the end of the tone arm, the part that holds the stylus is on an angle of about 10 to 20 degrees. The stylus is not...
This model uses a ceramic cartridge. Sometimes the stylus holding part can become damaged. It should be possible to get a new cartridge and stylus for the unit. It looks as it will either screw or just clip into the headshell. Either way look around for a replacement cartridge. If it has a number on the cartridge quote that. Remember it's a ceramic type - not magnetic.
Jan 02, 2015 | Audio Players & Recorders
How do I replace the needle cartridge?
That does not appear to be a part that is readily available. Contact information is here: http://www.pyleaudio.com/ContactUs.aspx
Oct 09, 2014 | PyleHome VINTAGE PTCDS2UI...
MY TONEARM ON MY TECHNICS 1200 SLIDES TO THE MIDDLE OF THE RECORD! DOES IT NEED TO BE REPLACED & HOW MUCH WILL IT COST?
No it's either the stylus or the pressure to the stylus is not enough. The weight at the end of the arm will increase the pressure on the stylus. Turn it up in slightly testing a record till the stylus tracks in the grooves. The trick is to get it so that it stays in the groove without creating a rumble sound. Remember though a worn stylus will not track at all.
Most cartridges track at 2 to 3 grams. If the Weight on the arm has numbers they will correspond to the weight in grams. If you have to raise it very high the stylus is too worn.
Jul 30, 2011 | Technics SL-1200MK2 Turntable
Cannot locate a replacement needle without a make. Can you help? I have the number on the needle being T50HD. Is it ceramic or magnetic? I also need a manual. Thank you
The make is probably printed on the cartridge rather than the stylus but it could well be this one (ceramic)
http://www.stylusplus.co.uk/bush-t50hd-stylus-1890-p.asp
Personally I prefer to change the whole cartridge rather than just the stylus for better sound quality. At least replace the cartridge every 2nd or 3rd needle change -
You don't specify the make of equipment you need a manual for but the best place will be the support pages of the website of the original manufacturer. If you need a manual for a record-player cartridge they usually come in the box.
Feb 24, 2011 | Audio Players & Recorders
Broken needle on thorens TD 158 turn table.
Needle is a term used with 'record players' from the 60's. A turntable has a Phono Cartridge with a stylus. Depending on the brand / model of said cartridge the stylus may be replaceable. The cartridge certainly is. The tonearm is a delicate precision mechanism that will last lifetime if handled properly.
If you don't understand any of this I discourage you from taking any further actions without a knowledgeable mentor / technician looking over your ahoulder.
Mar 22, 2010 | Audio Players & Recorders
Record PIN needs to be changed, where can i get spare in Bangalor
It is called a stylus and is part of a cartridge. There is a small release lever or it comes out as a plugin device. I cannot see where you are but eBay will have your stylus/cartridge for your turntable if a stereo shop is not nearby. Also any TV repair shop can order it for you. Steve Medley
Feb 07, 2009 | Philips Audio Players & Recorders
Pyle PLTTB3U Turntable Logo
314 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Gerhardus Stroebel
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
