Question about HP Designjet 4500ps InkJet Printer
I am receiving error message 01.3:01 but I only have 1 roller installed
Sharp ar-310nt getting an error code h4-01
Fusing unit error.try to cancell by using program/simulation.cancell by 14
Nov 19, 2013 | Sharp Office Equipment & Supplies
Hp photosmart 310c will not install on windows 7
IssueThe HP printer software installation fails to run in Windows 7 on a computer with an AMD C-50, C-60, or Z-01 1.00 GHz processor. After you insert the HP printer software installation CD or run the driver installation downloaded from the HP website, the setup does not open. You might receive an "HP Installer Setup has stopped working" error message.
'HP Installer Setup has stopped working' or Setup Does Not Run When Installing the HP Printer Software in Windows 7IssueThe HP printer software installation fails to run in Windows 7 on a computer with an AMD C-50, C-60, or Z-01 1.00 GHz processor. After you insert the HP printer software installation CD or run the driver installation downloaded from the HP website, the setup does not open. You might receive an "HP Installer Setup has stopped working" error message.note.pngNOTE:This document does not apply to HP LaserJet printers.Preliminary stepThe solution in this document resolves software installation issues only for Windows 7 computers with an AMD C-50, C-60, or Z-01 1.00 GHz processor.
  1. On the Windows taskbar, click the Windows icon (c01319360.gif ), right-click Computer , and then click Properties .
  2. In the System section under Processor , find the manufacturer, model, and speed (GHz) of the processor.
If your computer runs an AMD C-50, C-60, or Z-01 1.00 GHz processor, continue with the steps in the following solution.SolutionFollow these steps to download and install the newest, full-feature version of your HP printer software. Then, download and install a software patch to complete the installation.Step one: Download the softwarenote.pngNOTE:You must download the Full Feature software to resolve the installation issue.
Mar 24, 2013 | HP PhotoSmart Office Equipment & Supplies
I have a camera sony cybershot DSC-W350 and flash is not working. And I receive an error message E:91 01. What do I do?
Hi. Thanks for your question.
To get your camera back in working order you need to reset it to factory settings. Please click on the link below for a video from Sony website on how to perform reset.
http://esupport.sony.com/perl/tutorial-display.pl?tut_id=374&mdl=DSCW50
Thank You for using FixYa.
Jan 14, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Error message: No TR Roller Install the transfer roller
Hi
This error has already been noticed by Brother and they have a fix for this issue. This message will appear on your Brother machine if the ground clip is not present on the Transfer Roller Assembly. The clip can become dislodged due to a paper jam or removal of the Transfer Roller assembly.
To check the fix from Brother visit this link--
Brother TR Roller Install error removal Pictures
Please get back to me if you have any queries.
Daniel Scott
Jun 22, 2010 | Brother MFC-9420CN All-In-One Laser...
Need Help! What does the Error message "Set transfer roller" mean?
"Set transfer roller" means that the set transfer roller is missing or not installed properly. Install or reseat the transfer roller.
Mar 30, 2010 | Lexmark C500n Laser Printer
Error message 917.00 service transfer roller. I replacedn the service roller but still the error message comes up.This is from the IBM Infoprint 1552.
A 917 transfer roll error code on all models at service level may
display if an incorrect level HVPS is installed in a printer that has the erase lamp assembly installed.
Check to make sure the correct level HVPS is installed.
Feb 11, 2010 | Office Equipment & Supplies
Error 322 - see printer message
The fixing assembly (The hot rollers) of the printer is faulty. This need to be replaced by a service technician.
Faxes are received in memory because they cannot be printed.
Nov 11, 2009 | Canon FAX-L350 Plain Paper Laser
Error message 80 01
The error indicates that the controller detects paper that is smaller than letter size in width.
There may also be a problem with either the rear sensor or the main controller board.
I hope it is just the paper.
Hope this helps.
Apr 07, 2009 | Brother IntelliFax-2820 Laser Fax
Can't install drivers for Vista Home Premium
I would suggest you to go for restoring the system to a good known configuration.
Do a System Restore..
Otherwise more info on such issues can be get on Microsoft Article:
http://support.microsoft.com/kb/908267
Jan 07, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP Designjet 4500ps InkJet Printer Logo
173 people viewed this question
Seeker5211
Seeker5211
