I have a 36" Toshiba TV model 36A50. When I turn on the set it has a 1/4" bright line with color and movement/black background. I have sound. In the past I could turn off the set or unplug and it would correct it. Two months ago I took a low pressure air nozzle for the first time and blew out the inside with alot of dust on the circut board and tube. We use this set about 40 hours a week. Could it be time to replace the set if too costly for repair.
  • 1,512 Answers
HO
You have what is termed a vertical collapse, or complete failure of the vertical circuit. It is probably dry solder joints about the vertical output IC. Resolder and replace capacitors that are near the IC heatsink also. They probably caused the failure of the soldering in the first place from overheating. Replace the chip also if you have no success. Check also low value resistors about this stage that supply power to the IC. If this makes no sense to you, contact a repair guy. May cost you $80-150 depending on how many parts need to be replaced.
robotek
Posted on Aug 06, 2008
  • Graeme Ross
    Graeme Ross Aug 07, 2008
    Hi again, how did you go getting your problem resolved. Can I assist you any further?
    robotek
  • 1,586 Answers
I think that you may end up better off getting a new set, to be honest. My 48" rear projection JVC TV lost all three of its guns after a few years. Total repair cost was $900 (thankful for warranty now - that was not much below the purchase price of the TV). The unfortunate thing is, labor and parts rates are so high in many ways that it's almost as if the TVs are becoming throwaway items. More than a small problem, and you spend a tremendous amount of money repairing it, when you could likely spend a few bucks more and get a new TV with a new warranty. The fact that you were once able to clear the problem by unplugging it, and now you can't, shows that the issue is getting more serious and parts are going to die before too much longer.
I'd call around town, find a repair shop that deals with TVs, and ask them at least for an estimate on the cost and timeframe of repair. I have a feeling that a couple of opinions from shops will show you very clearly that you may want to seriously consider upgrading or replacing your existing TV with a new one.
I have a Sony, 54" Projection Screen HDTV that I bought in 2002. I believe it is a 1080i. When I am waatching TV, I notice that when the screen is mostly black, for instance a night scene, the black areas...
Confirm the actual model number as the one indicated in the title is not HD.
Some of these sets had bad picture tubes that on a black screen or blank video input may in your case show faint curved lines and or some color (red,green or blue) present in the background.
If this is the case there is a fairly simple way to attempt to adjust something for this--not in the customer menu but fairly easy to get at and try.
Most of these sets were KP51ws500, 57500 etc.
SD TECH
May 11, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
The brightness is very dark. Any nightime scene
Your CRT's getting old. Plus dust on lenses don't help much. You have to open front frill (below screen) and back of the TV. Clean up lenses using dry paper towels, do not wet.
In front of the TV after grill remove center cover and locate "black box" that have 6 potentiometers on it that looks like plastic adjustment screws for philips #2 screwdriver slots. 3 of them should read "Focus" These you don't touch. Another 3 reads "Screen". Put some still image on your screen (like paused DVD movie frame). Carefully add brightness in all 3 colors trying to avoid horizontal lines appearance. If lines show up, just turn it back a little. Try to keep color balance looking at the picture.
This procedure will brighten up image but further reduce CRT's life.
In case that you posted wrong model here and you have DLP Projection TV - just replace the lamp.
Mar 09, 2010 | Pioneer SD-643HD5 64" Rear Projection...
Red arching lines showing up on screen promident when a dark background is present
Red picture tube needs screen voltage adjust. Open fornt or back of TV and look for a black square looking box with adjustment knobs. Look for red screen adj and slowly turn rt or lft until lines just disappear. If screen goes too bright tv will shut down, just turn back on again and retry
Dec 04, 2009 | Sony Televison & Video
I have a sony 50 in rear projection. 9 years old
Sounds like the CRT tubes are going out which is fairly common on Sony. Inside the back of the TV there are 6 knobs - 2 for each color...one is for focus - dont touch - the other for brightness...turn down the brightness just a hair untill the lines go away.
Dec 01, 2009 | Sony KP-51WS510 51" Rear Projection...
Very fine blue lines veiwable when the background has black in it
You need to adjust (actually bit decrease) G2 volts (calls Screen volts) of Blue gun.
If you are familiar with big TV repair and have electronics knowledge then let me know to guide you further.
thank you.
Dec 13, 2008 | Sony KP-51WS500 51" Rear Projection...
Picture Problems: Snow, color, lines
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 23, 2008 | Sony KP-53XBR200 53" Rear Projection...
Green picture
Your red and blue cables are unplugged from either the source or at the tv.
Component video uses a red green and blue signal. If the red and blue are pulled you will onle see the green. If the green is pulled you will see nothing.
Check your cables 9 out of 10 times its a loose connection or bad interconnect cables.
Jul 03, 2008 | Sony KP-51HW40 51" Rear Projection...
Projection defect
Good Day;
It sounds like you may need to re-adjust your G-2 controls, located at front, remove front panels. Look for small block with screen /focus controls on item, first turn color down, reset brightness, contrast controls. Adjust until lines are at min. and picture is a good black and white (grays). Good Luck, big IRISH.
May 21, 2008 | Panasonic PT-52LCX65 44" HDTV
Hi toshiba 43 rp
You have a confusing mixture of data......Please provide
Make,model,age and chassis off sticker on back of set.....T.
Nov 26, 2007 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 65hx81 65" Rear Projection tv. black & white color/green
Yep, your problem is a relatively easy one to repair if you know how to solder. You better repair it before it blows the fuse though. There are two capacitors in the main power supply that are coming loose and need to be re soldered. There is a Toshiba service bulletin about it. They are marked C809 and C810 on the main power supply board. Good Luck
Sep 05, 2007 | Toshiba 65HX81 65" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
