Question about Carrier Beverage-Air MM14 Commercial Refrigerator
My Beverage Air mm14ge wont cool. IT sounds like it's running, then after about 25 seconds it will click once, then once again a second or 2 later, and keep repeating that cycle. The fan is working. Is it just the start relay?
  • 122 Answers
Could be the start relay. could also be the compressor itself. need to either check continuity of compressor or use a compressor analyzer to see if shorted or open.
Posted on Apr 05, 2011
Adding freon to a commercial beverage air mm14ge cooler
If it needs gas it has a leak. These coolers generally don't come with gauge access ports and need to be silver brazed into place. These systems have a critical charge and will not operate right unless the exact ounces of refrigerant are in the system. The temperature controls measure coil temperature instead of cabinet temperature. The wrong charge makes them run and run and they cant control temperature. Hope this helped.
May 25, 2014 | Beverage-Air Refrigerators
I have a beverage air MM14GE cooler that hasnt been on for over a year when i plug it in it turns on but doesnt cool, what can be the problem?
Verify that the compressor is actually running. You should feel it vibrating. If the compressor runs with no cooling most likely the refrigerant level is low.
Oct 12, 2013 | Beverage-Air Refrigerators
Duo therm rv air conditioner repair
Sounds like thermostat is failing. There is a factory set resistor that helps the thermostat keep a 2 degree accuracy. Second possibility is that you have a fan or direct airflow from the cooling system, being devirted, that is allowing the cool air hit the thermostat on the wall.
Aug 17, 2013 | Heating & Cooling
2000 dodge intrepid wont stay running
Have fuel pressure tested in both situations. I've seen fuel pumps quit once they get heated up, then when they cool, pump again. Perhaps try WD40 sprayed in to throttle body inlet when no start, and that will tell you if it's a fuel delivery problem. Just remove air cleaner intake hose at front of throttle body, and open throttle and spray for a second or 2 then try to start. If it fires up and runs for a second or 2, then it's a lack of fuel issue.
Jun 06, 2013 | 1999 Dodge Intrepid
My Bev Air UR30G runs, but only warm air comes out...how can I fix?
make sure the compressor is running if not check the thermostat. or could have leak and lost coolant
Sep 27, 2010 | Carrier Beverage-Air UR30GEFD Beverage...
My Beverage air model # mm14ge blows hot air. why, and what must i do to fix this please.....thank You
Check the start relay and capacitor on the compressor.
Check the fan motor on the compressor.
Mar 19, 2009 | Refrigerators
Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Mar 11, 2009 | Carrier Heating & Cooling
Carrier Beverage-Air MM14 Commercial Refrigerator Logo
374 people viewed this question
Top Carrier Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Davor Krstevski
Davor Krstevski
Are you a Carrier Refrigerator Expert? Answer questions, earn points and help others
