Question about Serif Photoplus X4
Failed to open document, why is this - Serif Photoplus X4
Problem with document on laptop HP
G7 what (G7-1150us)??? 7 years old?
only 3 ways, to corrupt a file
1: PC is virus infected.
2: Hard disk is bad, if S.M.A.R.T disk test fails, it is bad.
3: you somehow, turned off power with the word fail open and this wrecked the fail (xyz.docx)
make sure the Laptops battery is good, try new one? be wise !
make sure to keep the line cord plugged in at all times.
so if you lose power to the home, the battery saves the day
if the battery is bad (old ones are & never seen a 7 year old battery good in my whole life time (50 years on the job)
sorry. for your file loss.
when editing files save it to a new name each time.
like this
myBIO1.docx. myBIO2.docx,
then when the last one is corrupted, the previous is ok
that is if not #1 or for sure #2 caused.
With the line cored (HP 19vdc power pack plugged in)
run crystaldiskinfo...... now.
down load it and run it
and post your results.
this simple program scans the HDD, for errors
Hard drives actually know when they are bad.
(weak HDD are drives with unrecoverable sectors or clusters)
the UN word is the key, there,
http://www.majorgeeks.com/files/details/crystaldiskinfo.html
Apr 27, 2018 | HP Computers & Internet
Scanner fails to format image
Turn off your scanner. Exit the Smart Touch program.
If XP, navigate to this path: C:\Documents and Settings\[User Name]\Local Settings\Application Data\Smart Touch\[Scanner Model]
Windows 7 or 8: C:\Users\[User Name]\AppData\Local\Smart Touch\[Scanner Model]
Delete the "Sys" folder. Turn on the scanner. Re-open Smart Touch. You will see the Sys folder repopulate in the root folder.
Mar 27, 2014 | Kodak i1220 Pass-Through Scanner
Empting trash
Sometimes there is a single document that it won't delete, and if you include that document in the delete request, the request will fail.
Open the Trash folder, select only the top several documents in the trash, and ask for those to be deleted. If this works, keep selecting several documents at a time till you find the one(s) it is objecting to.
If you have been able to delete everything else, and are left with just one or a few docs, check that the app that opens them is completely closed, and has no processes running. Then it should be possible to delete those last troublesome files.
If this is not what is causing the problem, please post more details.
Jan 29, 2014 | Computers & Internet
Linkid 104288 Problem Event Name: BlueScreen OS Version: 6.1.7601.2.1.0.256.1 Locale ID: 1033
Hi Vasava,
Before solving your problem.
Q.1. Is it only happening for this single document? Try to open other documents too. If you can open other word docs, you can eliminate the issue with Win Word application problem. The problem is in your document itself. If you can't open any other word docs, than this is the application problem.
Q.2 This is for Win Word application problem. Can you find "Microsoft Office Application Recovery" under "Start menu-->All Program-->Microsoft Office-->Microsoft Office Tools". Try recovering your application with this tool. It solve my problem with Ms Excel.
Q.3 Do you have Ms Office setup cd with you. This is if the above 2 fails. You will need to reinstall Ms Office.
My guess for you problem is, you have a defected document file.
Please try the above and let me know, if I can help further.
Sep 23, 2013 | Computers & Internet
Please help! I keep getting an error code: 0 x 80004005 when trying to open a document. What does it mean? Thanks
It means that the operation (opening the document) failed for unspecified reasons. These errors are quite common, and can be caused from any number of things.
To assist you further, I require the following information:
What program you are trying to use to open the document?
What version of Windows you are running (Windows XP, Vista, or 7)? Does the error come up when you try to open other documents?
Mar 28, 2011 | Computers & Internet
HP lazerjet 3055 is showing document loaded and will not clear how do I clear this. please advise.
Try this:-
Go to your printers folder. You may access it from start/control panel or simply start/printers and faxes depending on your operating system. there right-click on your printer and click open. When it opens, select the sent documents shown and click on delete. You may need to repeat the procedure to completely clear all sent documents that failed to print.
God bless & Good luck!
Mar 01, 2011 | HP LaserJet 3055 All-In-One Printer
SOWING YOUR DOCUMENT PRINT ARE FAILED
please check the printer connection to your pc .... open printer and faxes check your printer status ..( it should be ready ) and cancel all the document are in pending ........ reinstall the printer driver and check ...... please replace your printer data cable and check ...if its still not working its may have problem with your printer connector ......... Best of luck
Jan 04, 2010 | Computers & Internet
EPSON POS PRINTER does not print receipt
Try to clear your printer's queues up messages of all print commands that failed to print. See, what happens it when you send a document to printer, if it fails to print, and you send another, it queues up behind the first that failed to print. So instead of printing the second document it prints what you are seing, special characters etc.
Solution:
Go to start/priners and faxes and right click on your printer and select open. You will all the documents for print so far queued up. select and delete them. Restart your system and the printing should be Ok.
Sep 17, 2009 | POS X POS-X XR210 Thermal Printer
Hallmark card studio 2005 deluxe failed to create empty document
I deleted event planer before I reinstalled the program again and it worked.
Jan 10, 2009 | Sierra Hallmark Card Studio Deluxe 2005...
Word Document Opening Problem
go to search typed normal.dot
deleted the files
then start MS word
Aug 28, 2008 | Microsoft Word 2003 for Students &...
Serif Photoplus X4 Logo
107 people viewed this question
Top Serif Computers & Internet Experts
Martin Murray
Jax Planet
Jax Planet
 Grubhead
Grubhead
Are you a Serif Computer and Internet Expert? Answer questions, earn points and help others
