Question about Bosch Indoor Gas Tankless Water Heater 1600H-NG Natural Gas
Bosch 25E natural gas heater has stopped heating the water Is there something basic I can do to correct this Thanks, Sam
1) Call service technician, and when that person arrives, ask about tips and tricks for maintaining tankless water heater.
2) Open following link for basic troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
3) Add a comment with your experience so others with same problem will benefit.
4) Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call, but does not take place of service call since you will be doing the work yourself, on a complicated appliance that is affected by perfect cooperation of internal parts, and external factors.
Posted on Apr 08, 2011
Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater. Problems with constant hot water. The heater turns ok but (i think) when i turn on the cold side the heater stops. at...
Possible flow sensor issue. Check to see if your water pressure fluctuates a lot or is fairly steady. These units are sensitive to the pressure. take care.
Feb 19, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch 25e water heater wont ignite
combi or standard if combi pressure too high and will be blowing off your high pressure release valve which would stop your boiler from igniting best of luck
Oct 27, 2009 | Bosch Water Heaters
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Takes a long time to heat water. Brand new Ge 50 gallon water heater. Once heated it right temp,just a long time to heat it and then won't maintain hot water. Is gas line to small? 3/8 copper line. Thanks
If you are using a 3/8" copper line for your gas, get it replaced ASAP. It will fail. 1/2" Black Iron is required with natural gas. 50 gallons is a lot of water to heat. Look on the heater label for the recovery rate.
Feb 27, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Won't get hot enough or last as long as it used to
You could try to adjust the thermostat to a higher temperature. Let me know the results.
Good luck...
Aduz
Feb 22, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch water heater won't heat as hot or as long as it used to.
Is it protected by a water softener?
Have you cleaned the inlet screen and flow valve?
Your problem is likely in one of those areas. If not them then you may have to backflush the heat exchanger (if you don't have a softener). The manual tells you how to do that.
Mike
Bosch 1600h NG not heating water hot enough
it sounds to me like the dip tube has failed. this is a plastic tube that is inside the water heater on the cold side. It is designed to put the incoming cold water at the bottem of the tank allowing heated water out at the top. when this tube deteriorates the cold water mixes at the top of the tank instead of the bottom. a new dip tube is about 5 bucks but must be inserted on the cold side by someone with plumbing experience.
Jan 08, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch Indoor Gas Tankless Water Heater 1600H-NG Natural Gas  Logo
150 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
