Question about GE Washing Machines
I have a 7 yr old top loader washer and occassinally it will over fill?
    Genius:
  • 1,028 Answers
Remove front panel ..2 clips 1 on each side press down with putty knife.. on left side ck the small hose to side of take pull hose off and be sure end is not pugged with lint clean as good as possible q tip may help..ck to see if water runs in with washer shut off at timer or unplugged from wall if so probably fill valve not shutting off..if all these ck ok suspect water level control may be at fault..if problem is there water will shut off when washer is shut down
Posted on Aug 06, 2008
SOURCE:
LG washer drains withour washing!!!!
Call LG customer service. The unit is probably still in warranty. If not contact a certified LG repair shop and have them come examine and if possible repair the machine.
Apr 09, 2015 | LG WFT1071TP Top Load Washer
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
I have a 6 yr old maytag top loader washer that does not wash or spin. It filled up with water and then stopped working. The power light is on but it does nothing . Any suggestions?
There is plainly no drive to the drum, it could be a broken drive belt or a dead motor.
Is there any humming from the motor?
If all is silent it could be the motor has died. If there is any sign that the motor is turning, then the drive belt could be gone.
Remove the back and look at the drive.
Alternatively the driver circuit board may need replacement.
Sep 02, 2010 | Maytag Atlantis MAV6000 Top Load Washer
WASHER WILL NOT AGITATE OR SPIN WILL FILL AND DRAIN KENMORE 800 TOP LOADER APROX 13 YRS OLD
sounds like your motor coupler bad if its making a ratchety kind of noise
Jan 15, 2010 | Kenmore 23822 Top Load Washer
Washer will fill and drain but not agitate
Check the lid switch if it is a top loader.
Nov 04, 2009 | GE Washing Machines
My etw4300tq0 washer will fill up with water, then stops.
etw4300tq0
Same problem... any help out there I see this post is over a yr old... it is now dec 29, 2010 and I have the same problem.
Mar 23, 2009 | Estate ETW4400VQ Top Load Washer
Roper washer
I have the same damn issue with my Samsung washing machine(Top Loader) Not quite sure why it does it.Help please really annoying.
Jun 05, 2008 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
54 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
