Question about Acer Computers & Internet
I want to replace my laptop monitor - Acer Computers & Internet
    Scholar:
  • 91 Answers
Very easy
im in the proccess of doing one right now
if the screen is cracked it needs replacing, otherwie you might just need to re seat the cables
Simple google the name of your laptop (find the exact model on the back of the machine)
Buy you screen, i just paid £88.70 for a screen which arrived today, that was with VAT and delivery
Simply
Use a flat head scredriver or a knive to pry the front bezel off the laptop screen
This will reveal some screws, take these out and rest the screen on the keyboard, put some kitchen roll or other on the keyboard to rest the screen so it doesnt get damaged
There will be 2 cables, a power cable and a ribbon cable, detach both of these
Simply fit your new screen, attach the 2 cables, re fit the screws and the front bezel
I am charging the lady £45 to fit her screen
So if you can do it yourself youll make a nice saving
If your not comfortable then find a local PC repair service
Goodluck
Posted on Apr 05, 2011
Love my computer, but my monitor is fading on the left side facing me and getting vertical lines on it. I think I am about to lose the monitor. Is it possible to add a monitor to it? How?
You can add a monitor connecting it to VGA output, similar to that of any desktop computer. Some laptops have HDMI outlet.too.
You can replace ba bad monitos though they are quite expensive. Recently a friend replace a screen for his HP for about 100 USD! though maybe you can get a cheaper one.
Just FYI, if you get same screen problem with an exterrnal monitor, your problem is the videocard.
Just to have an idea how a screen is replaces, watch these videos:
How To Replace Broken Laptop Screen
Laptop screen replacement How to Repair replace LCD screen in laptop
Laptop Screen Replacement Repair How to Replace Laptop LCD Screens
Instructions How to Replace laptop screen
Aug 22, 2015 | Computers & Internet
Black screen on acer laptop
Black screen is a number of things.
*If you`re laptop turns on but you see no display at all..does`nt even post,Then its the GPU on you`re motherboard thats faulty & will need replacing. Or
*Its you`re screen inverter which is a small circuit board located inside on the bottom of you`re LCD screen which needs replacing.Theyre cheap and not expensive.
*Do a test for example : Connect you`re laptop to a PC monitor Via VGA to VGA cable.Connect to youre laptops PC input to your monitor PC input,Then turn you`re laptop on.If it displays on you`re monitor then its the problem with your LCD laptop screen,Or the inverter needs replacing.
If theres no display on the pc monitor then its You`re motherboard onboard GPU (graphic Card) - Which you will need to replace the motherboard.
Oct 18, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer monitor is used as secondary monitor, running off laptop. video card replaced in laptop, now acer monitor comes on, but blinks on/off. Any suggestions ??
It acts like it is not getting the signal from the laptop video port, you should try it with another monitor also, and by the way, did you use the Fn key and either F5, 6, or 7 (depend on the laptop brand and model) to select Internal, External, or both monitors?
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 01, 2010 | Acer AC713 17" CRT Monitor
Blue vertical line in the middle of my laptop monitor?
Anytime you get lines inside of a laptop monitor, its a problem with the screen itself. You can verify this by hooking up an external monitor to the laptop and switch the output to it and you won't have lines on the external monitor. Get the laptop screen replaced.
Jun 09, 2009 | HP Computers & Internet
HP DV 1000 screen goes dark after boot up. Plug in external monitor and it works fine. Toggle between internal and external and I can get the laptop monitor to come back on for a few min. Turning...
Your laptop's monitor went bad and needs to be replaced. I had the same problem on an IBM laptop I had. Replacing the monitor costs between $120-220.
Apr 15, 2009 | HP Pavilion DV5-1000US Laptop
Laptop monitor have vertical lines apearing out of nowhere...
LCD needs to be replaced.
Common problem called "Tab separation".
Jan 10, 2009 | Toshiba 14" LCD Monitor
I want to use my laptop as a monitor for my desktop
Check VGA cord connection, possibly try another, shorter VGA cord, plugging in cords BEFORE booting up computer, with monitor power on also. No signal is just computer telling you that it is not connecting.
You may have to go into Setup when computer boots up and turn on or select external monitor as some laptops may require this. Good Luck!
This is a great place for solutions that will save you lots of $$$$. I love it and it is my first contact with FixYA! jaballou
Nov 15, 2008 | CMB T43 750 Notebook
Gateway flat LCD dead
I'm not sure if your referring to the lcd monitor (gateway brand) or a laptop's lcd screen not working anymore.
1. if it's an lcd monitor...
a. test monitor in a different pc before assuming the problem is the lcd screen
b. replace the monitor if after testing monitor is in deed the item failing.
2. if it's the lcd screen from your gateway laptop.
a. you may be able to attach a regular analog monitor to the paralel port on your gateway.. test and see if the monitor that you attach will give you a picture (you may have to toggle with some some keys on your laptop keyboard to make have the signal going to the "externa" or attached monitor.
if the other monitor does not work either.. you video controller on your motherboard on your laptop may be failing and you may not have other options that to replace your laptop.
b. if the external/attached monitor works.. very likely the problem is the lcd screen for that you need to get a replacement and you may have to contact gateway to find out about pricing (or places to send your laptop for service if you're still within warranty). if you have an old laptop you may have to considere simply replacing the unit as buying a new lcd screen may very likely be more expensive than the same working laptop.
Oct 02, 2008 | Computers & Internet
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
